Old Nov 19, 2012, 12:11 AM
Rain4LA is offline
Find More Posts by Rain4LA
Rain4LA's Avatar
United States, IL, Chicago
Joined Nov 2012
Easiest way to make a CB180Z (pro) DEVO compatible?
I'm new to all this, though I have become thoroughly obsessed quickly. If anyone could help me, I would really appreciate it. I would just like to be able to use a Devo 8s with a CB180z pro and don't know if if it's just a matter of changing the reciever - if so which one, and how hard is it?
Thanks in advance, guys...
Rain4LA is offline Find More Posts by Rain4LA
Old Nov 19, 2012, 01:23 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Walkera no longer makes PCBs for flybar helis. They are obsolete and have been since before Walkera switched to Devo. The only one that might work is the one used in the V400D02, which is also obsolete and it's real iffy. Your best option is enjoy your CB180Z the way it is for now and move on. You won't find parts for long.
Balr14 is offline Find More Posts by Balr14
Old Nov 19, 2012, 04:27 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
You can use a third party firmware called deviation. It will make your Devo 8S compatible with the old 2801 / 2601 / 2401 protocols as well as Spektrum DSM2 and others. www.deviationtx.com
Deviation For DEVO10 (6 min 22 sec)
zadaw is offline Find More Posts by zadaw
Old Nov 19, 2012, 09:33 AM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
Thanks! Very cool. I looked at the site, and if I understand correctly, I can bind my Nano cpx to my 8s using Deviation? Wow, that means I can look into buying a Trex 250 pro and not worry about the Rx. Sounds too good to be true.
Old Nov 19, 2012, 11:19 AM
zadaw is offline
Hong Kong
Joined Jan 2010
Yes, you can bind the Nano CPX to the Devo 8S. Here is a video of the same modeler using the same Devo 10 transmitter to fly his Nano CPX
Deviation Of DEVO10 Playing With Blades NANO CPX (6 min 9 sec)
Old Nov 19, 2012, 11:42 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Deviation software is a much better choice than trying to find a compatible Walkkera receiver for a CB180.
Discussion Easiest way to make a cowl? Mopar92 Balsa Builders 4 Oct 28, 2012 11:34 AM
Discussion Best/easiest way to remote trigger NEX5N? aForcefulThrust Multirotor Electronics 2 Jul 18, 2012 07:54 PM
Discussion Easiest way to launch a DLG for a beginner nph Hand Launch 10 Apr 03, 2012 11:17 AM
Discussion Easiest way to make a fiberglass tube? gobigkahuna Composites Fabrication 29 Mar 12, 2010 09:19 AM
Discussion what is easiest way to make 3s2p ? submarco Batteries and Chargers 2 Sep 10, 2006 08:27 AM
