Old Nov 18, 2012, 09:25 PM
Eddy is offline
Find More Posts by Eddy
Malibu Ca
Joined Feb 2000
Best radio for a sub?
It seems 72MHz is not that good and 2.4 is even worse, what gives the best range for this application?
Eddy is offline Find More Posts by Eddy
Old Nov 18, 2012, 09:36 PM
Cliff Hanger is online now
Find More Posts by Cliff Hanger
California Desert... 7 miles from nearest town
Joined Jan 2010
72MHz is not good because it is reserved for aircraft.
75MHz is what most use here in the USA. Reserved for surface use.
Submarines are considered surface use.
2.4GHz does not work because the signal does not penetrate the water more than a few inches if at all. It's reflected.
The issue is that the 75MHz & 72MHz radios and receivers are being phased out here for the 2.4GHz. We can still get 75MHz receivers made in Canada. New transmitters are becoming harder to find.
Cliff Hanger is online now Find More Posts by Cliff Hanger
Old Nov 19, 2012, 12:52 AM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
WFly still makes them & you'll find several in the States selling with Sub Driver offering the best price. I have one & can recommend the brand.
http://www.sub-driver.com/electronic...receivers.html
http://www.nacrc.com/wfly-wft08s-24g...ion-p-787.html
Here's a link to the WFT08 manual:
http://www.moonrakers.com/submarines/WFT08manual.pdf
herrmill is offline Find More Posts by herrmill
Old Nov 19, 2012, 08:01 AM
Aeroengineer1 is offline
Find More Posts by Aeroengineer1
Mesa Falcon Fld, Arizona, United States
Joined Sep 2004
I use an old Futaba 8u. The great thing about it was that it was cheap because it was "old" technology, and it allows the usage of rf modules. This allows the entire rf section to be removed and replaced with 72MHz, 75MHz, or your favorite 2.4GHz flavor.
On a side note, it is sad to me that so many of these radios cost so much. There really is not all that much that goes into them. The programming is not terribly complicated. I know that there are some open source efforts out there as well.
Adam
Aeroengineer1 is offline Find More Posts by Aeroengineer1
Old Nov 19, 2012, 08:34 AM
Carcharadon is online now
Find More Posts by Carcharadon
Joined Sep 2004
At one time I used an AM Futaba that worked great but I sold it with the sub. Currently use a HiTec.
Carcharadon is online now Find More Posts by Carcharadon
Old Nov 19, 2012, 09:35 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
what is the best range you guys get on your radios with depth and distance?
Old Nov 19, 2012, 12:57 PM
Joined Sep 2004
30ft (or more) in depth and to where I can't see it. (see end)
Disney Nautilus RC Submarine (2 min 14 sec)
Old Nov 22, 2012, 10:31 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Once it fully submerges, there is only danger in running deeper.
cyclops2 is offline Find More Posts by cyclops2
Old Nov 23, 2012, 06:28 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The SombraLabs SL-8 can be programmed to any 75 Mhz channel(as well as 72), as for the Tx you can use a Futaba/Hitec module based model like Futaba 9C or Hitec Eclipse-7 with a 75 Mhz surface module(still available as new or used):
http://www.sombralabs.com/store/prod...roductid=16143
There is two SL-7 for sale right now in the W/FS forum:
http://www.rcgroups.com/forums/showthread.php?t=1772577
coriolan is online now Find More Posts by coriolan
Old Nov 23, 2012, 10:39 PM
philong2005 is offline
Find More Posts by philong2005
Joined Aug 2012
what about 35 mhz
philong2005 is offline Find More Posts by philong2005
Old Nov 30, 2012, 04:28 PM
cbk21 is offline
Find More Posts by cbk21
Switzerland, GE, Corsier
Joined Feb 2005
Originally Posted by philong2005 View Post
what about 35 mhz
No problems! I have a 40 mHz (MPX MC 3030) wthout any problems.
Christophe
cbk21 is offline Find More Posts by cbk21
Discussion Best Radio Tx Rx for S800? Volandos Multirotor Talk 2 Feb 19, 2013 04:24 PM
Discussion What is the best radio system for professional use Videographia.it Radios 12 Aug 06, 2012 02:24 PM
Question What is the best Radio to use for FPV? easystarfpv4 FPV Talk 12 Apr 27, 2012 09:06 AM
Question best radio for around 400 bucks VENOMiTry Electric Plane Talk 21 Mar 31, 2012 12:38 AM
Discussion Dare I?: Best sub $500 radio? Grips Multirotor Talk 43 Sep 28, 2011 12:58 PM
