Nov 20, 2012, 04:50 AM
Ireland, County Kerry, Kerry
Joined Dec 2005
Originally Posted by kwmtrubrit
Something I was advised to do when I used MPX connectors on my Dragonfly Strong was: Don't glue both both parts of the plug into their respective area. Leave one "floating." Reasoning is, if the wing should separate slightly from the fuse, electical contact could be lost. So, I decided to glue the wing plug, but leave the fuse plug loose. The chances of the connector going back into the fuse in my model is pretty slim, but if it did it is recoverable easier, but the wing not so without surgery.
Before someone says it, I do use tape at the wing/fuse join, so the separation should never happen, but we've all met Murphy and his infamous Law, right?
Swings and roundabouts. The other side of the argument is that the constant man-handling of the "floating" connector is far more likely to result in a broken wire connection... Plus, I have never seen a wing pull out in flight (on landing, sure, but that's not a problem).
Having said that, I use "floating" connectors unless it's a connection secured by a bolted-down wing panel  !
Chris
