Old Nov 18, 2012, 09:02 PM
crashtested is offline
Find More Posts by crashtested
crashtested's Avatar
USA, RI, East Providence
Joined Jun 2010
Data
THE Cinestar 8 - Flight Time - Thread
I couldnt find a good thread on max flight time with the CS 8
Figured a single thread dedicated to the science of balancing weight with power of battery, prop size and style, and load capacities needed could benefit us all
Please feel free to link me to an existing one if there is one already...
Standardizing the format will help compare apples to apples.
Let me know if im missing anything.
Me:
MAKE----------------------------------------CS 8
MOTORS-----------------------------------Stock
ESC-------------------------------------------MK
PROP----------------------------------------Stock 14x5 APC
4s/3s------------------------------------------4s
BATTERY------------------------------------2x 3300mah Turnigy
FC---------------------------------------------MK
GIMBAL--------------------------------------360 gimbal
GIMBAL STAB------------------------------hoverfly
GIMBAL BATTERY------------------------quadropower 1000mah
CAMERA------------------------------------NEX 5n (18-55mm lens)
FPV GEAR----------------------------------Iftron 5.8 vtx, HDMI converter,
FPV BATTERY------------------------------quadropower 1000mah
AUW-------------------------------------------its in my van... ill weigh it and edit.
LOADED LANDING VOLTAGE--------14.7
------------------FLIGHT TIME-------------5min (ouch...help!)
CUT AND PASTE (or edit and post)
crashtested is offline Find More Posts by crashtested
Old Nov 19, 2012, 07:54 AM
Joined Jun 2010
-BUMP- To Get this going
someone's gotta be getting more than 5 min with a nex on the 360 gimbal...
Old Nov 19, 2012, 08:41 AM
Michael64 is offline
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
I have to say you are using a very low mah battery to start with. Two 5000 is the least that should be flown with that size multi for sure. And if these are QC motors you may even what to go to 5S batteries as well,but 3300 mah is for alot smaller and lighter machines.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Nov 19, 2012, 09:17 AM
Joined Jun 2010
Im flying two 3300's and have tried two 4200's
Still low flight times imo.
Quadrocopter ships these with a single 6200 no?
Curious to other peoples setups.
There must be a diminishing returns plateau when increasing the battery size/weight.
Old Nov 19, 2012, 09:49 AM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Well you are nowhere near that.
As M said you need a min of 2 5000mAh 4s batts for that rig.
You can even go dual 6000mAh.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Nov 19, 2012, 09:59 AM
Spyde is offline
Find More Posts by Spyde
Denmark, Region Zealand, Jyderup
Joined Jun 2010
I found out that the propellers are very important. I have tested different types and so far the stock apc 14x4,7 has the best flighttime.
Spyde is offline Find More Posts by Spyde
Old Nov 19, 2012, 10:18 AM
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
You are landing way to early, loaded landing voltage should be around 14v for a 4s battery.
hugy is offline Find More Posts by hugy
Old Nov 20, 2012, 06:09 AM
coachbird is offline
Find More Posts by coachbird
Estonia
Joined Dec 2011
MAKE - CS8
MOTORS - Tigermotor MT2814-10 770kv
ESC - HobbyKing 40A BlueSeries flashed with SimonK firmware
PROP - APC 13x4.7
4s/3s - 4S
BATTERY - 2x ZIPPY Flightmax 5000mAh 4S1P 30C
FC - APM 2.0
BEC - 2x Castle Creations 10A BEC [One for FC (5V), second for Camera stab servos(6V)]
DC CONVERTER - 4S Voltage to 12V for navigation LED strips
GIMBAL - Cinestar 360 gimbal
GIMBAL STAB - FreeIMU 0.4.3r3 + arduino pro = MultiWii
GIMBAL BATTERY - Zippy 1000mAh 3S
CAMERA - Canon EOS 550D/T2i (Tamron 10-24mm lens)
FPV GEAR - TS351 5.8G 200mW transmitter, mini-HDMI converter
FPV BATTERY - Sharing with Gimbal stabilizator
BEC - HobbyKing UBEC 3A (for Camera Gimbal stab, FPV and hdmi-converter)
AUW - 5.5kg/12.1lbs
LOADED LANDING VOLTAGE - 15.2V
FLIGHT TIME - ~7min (light cruising)
coachbird is offline Find More Posts by coachbird
For Sale CineStar 6, CineStar 8 for sale! ZMInteractive Aircraft - Electric - Multirotor (FS/W) 6 Nov 03, 2012 01:32 PM
Discussion 4S 8" props vs 3S 10" props Performance & Flight Times GuerillaFilm Multirotor Talk 12 Sep 16, 2012 06:50 PM
Sold cinestar 8 with cinestar 3 axis gimbal Tretch5000 Aircraft - Electric - Multirotor (FS/W) 5 May 03, 2012 02:05 PM
For Sale CineStar 8 with CineStar camera mount.. Beauregard Aircraft - Electric - Multirotor (FS/W) 1 Mar 27, 2012 01:58 AM
Discussion cinestar 8 with cinestar gimble kjella Multirotor Talk 1 Dec 06, 2011 01:55 PM
