Old Nov 18, 2012, 09:49 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Multiplex BL-27/II and trainer switch problem?
I'm having trouble with my Multiplex BL-27/II ESC and the trainer switch on my 9C. When I have a trainer cable hooked up, flipping the trainer switch, either on or off, will cause the ESC to cut the throttle. In order to start the motor again, I need to drop the stick back to zero and raise it again.
I thought it was a radio programming issue and did some diagnosing HERE. Turns out it's an ESC issue. I plugged two different non-Multiplex ESCs into the Rx on this plane and the problem went away. Has anyone else had issues with this ESC and their trainer functions? Is there anything I can do about it, or am I stuck with it? Thanks for the help.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Discussion LP5DSM Trainer Switch Problem Lberry.88 Radios 2 Aug 09, 2012 11:10 AM
Sold NIB Himax 2816/1220 with Multiplex BL 27/II esc, and folding prop***Excellent Deal*** Joe Pierson Aircraft - Electric - Power Systems (FS/W) 0 Mar 11, 2008 07:35 PM
For Sale NIB Multiplex Easy Glider Pro w/NIB HiMax HC2816-1220 Motor & Multiplex BL-27/II ESC Tank52 Aircraft - Sailplanes (FS/W) 13 Feb 24, 2008 09:20 PM
Sold NEW Multiplex Multicont BL 27 Brushless ESC punkindrublik Aircraft - Electric - Power Systems (FS/W) 0 May 27, 2007 02:15 PM
For Sale NEW Multiplex Multicont BL 27 Brushless ESC punkindrublik Aircraft - Electric - Power Systems (FS/W) 1 May 20, 2007 12:25 PM
