Old Nov 21, 2012, 09:02 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Originally Posted by SENTRY 62 View Post
Ok - DAVID22 is a great pilot - and a great non-OSD pilot in areas that he knows well. But it's VERY dangerous for inexperienced guys to listen to what he says about RSSI is not needed.
I have flown 22 miles away. But sometimes in the wrong environment when you are flying towards a 433mHz emitter - you can see your RSSI dropping off MUCH faster than normal. This is a great indicator that you likely won't be able to pull off long range at that site (or taking that flight path).
NON-osd flights are fun - but make NO MISTAKE about it - proper failsafes (w/out an auto-pilot) will NOT save your plane if you get in bed w/ an emitter that has been steadily chopping down your control for a few miles w/out you having any way to notice. Once you get close enough to that emitter to start failsafes, you may never regain control or be able to turn the plane back towards home.
Tread SLOWLY and lightly on long-range flights where you can't monitor RSSI.
If you fly unstable plane like a wing as example then hard to get plane to,turn around slowly and smoothly
But you should have say UHF system that is able to be set in the air
Fly as normal as if you would going long range with OSd or not
Usually flying long range you go up and out in steady fligHt
Or if you are new to place fly around slowly and get to know the area in lots of ways
Like if uhf does not work well in certain areas, or,if video cramps out
But set your fail safe to make your plane glide around in a circle
Always fly into,wind if going long range so the plane will come back in fail safe
You will regain control,of the plane
As you fly just because you get poor rssi or failsafe don't let this stop you from going further
Flying long range with no OSd is not easy and some what complicated
Experience is worth more than words
Even a fun jet as example can be set for fail safe to glide around in circles
Until, control is regained
It's complicated to explain how to do some things for me
Like as example low rssi is basically fail safe right
So set rudder as example to move left just slightly with elevator
Low rssi ie fail safe will make rudder and elevators Move intermitently
Just for split second, it's indicator of,low,rssi with no OSd
You can hear servos move and plane move a bit
Like pan or,tilt servo,for,camera is perfect example
Jitter in camera, you set fail safe for camera just,off straight forward
You will then see low rssi
When you conduct proper ground testing and walk away with plane you will find area that fail safe and low rssi happen
It is very intermitent area on the ground
But in the air it is much larger distance to play with
Ie
You don't need rssi but can utilize fail safes when set properly in the air
I fly through rough rssi areas by flying through them to get to clear airspace further away
It's not uncommon to get intermittent fail safes or low rssi
Flying with no sod is complicated in a way
But not really
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Nov 21, 2012, 10:17 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
I think many of the considerations that you've spoke of are all really for like... SUPER long range flying. Me, if I go UHF, heck I'd probably only fly out a mile or two just for fun.
Dan
DJO is offline Find More Posts by DJO
Old Nov 21, 2012, 10:22 PM
David22 is offline
Joined Apr 2008
Dan
Then you for sure not need osd
I used to fly 2.4 for rc control,when I first start,out fpv
Actually thank god there was failsafe indicators
But Daniel wee is absolute genius
He should,of patens pending the set failsafe in the air
Very very smart idea setting failsafe in the air
As Daniel invented
For a reason before rssi was invented for,OSd
Range video invented rssi and OSd
I,got very first version range video OSd capable,of rssi reading, still on my bench at home
He write and make program , elcheapo, is the guy, for my OSd as requested by me as favour from Thomas, Thomas mad at me for never useing rv OSd he helped develop or ask elcheapo,make work to,let me,see,rssi
So I actually have very first ever OSd still, on bench at home, to see on OSd and rssi readings formuhf but never needed it
It's a collector edition with elcheapos signature on it, he sighted it or initialed it with date etc.
I watch storage wars and this OSd must be worth money
It's also eligible for free upgrade, elcheapo,would,jump out,of his shoes if I sent in his first OSd capable of rssi readings for,UHF in the history of fpv
I don't need OSd because of Daniels failsafe settings invention
It's very practical and simple
Thus no need for OSd with setting failsafe in the air
Old Nov 21, 2012, 10:23 PM
DJO is offline
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
I figured you'd say that
Old Nov 22, 2012, 12:11 AM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
I lost only one plane in my FPV carrier because I could not find the way home. I crashed so many times because of OSD failure. The most I hate the current censors, they always die on me. So no OSD here , thank you but NO
Blessed Google Earth
tushev is offline Find More Posts by tushev
Old Nov 22, 2012, 10:10 AM
DJO is offline
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Haha, but YES to Google Earth, I love it. Makes flight planning so much simpler + you get a feel for the scenery from above before you fly. Of course, FPV is much better
Dan
Old Nov 22, 2012, 09:30 PM
David22 is offline
Joined Apr 2008
I really like to keep fpv simple so,no failure possible happen
If someone were mathematician the exponential failure rate could be factored out
With adding possible,failures
The ideal set up is a fpv system that can be installed very simple with no extensions, small antennas, no OSd, I try many times to make pod for fpv but found that every plane is so,different in set up
Google earth is of utmost importance for long range
So is practice with eyes closed and fly fpv on simulator
This is the most important factor to fly with no OSd
It will teach you to fly with no OSd the best
Call it a religious experience flying with no OSd and actual eyes closed
Very good practice say david22 lol
Old Nov 22, 2012, 10:36 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
eyes closed? FPV this way, only Jedi master can do
</Yoda>
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Nov 22, 2012, 10:38 PM
DJO is offline
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
HA! Eyes closed, wow. But I guess you'd definitely learn a lot about controls. Of course, it depends on the plane you're flying too
Dan
Old Nov 24, 2012, 07:41 AM
David22 is offline
Joined Apr 2008
</Yoda>
Hands off and not looking at goggles is interesting as well
We got to take some sort of break
It's cool feeling letting go,of controls to actually see what you plane would do in case of serious failsafe or loss of video
But on flight simulators it is highly recommended to actually close your eyes and practice Jedi principals
This will give you much experience to become Jedi
Lol
It's video game and makes you aware of where home is when eyes closed
With fpv you should study area very well,like Jedi
Would so at all,times even with eyes closed you have idea where you are
Can you imagine a jedi useing OSd
His mind is stronger than any osd
Old Nov 25, 2012, 08:58 PM
MrFollies is offline
Find More Posts by MrFollies
Joined Oct 2009
Lol
Dude, you know Jedi are not real right? They are from a fictional hollywood movie.
MrFollies is offline Find More Posts by MrFollies
Old Nov 28, 2012, 12:07 AM
David22 is offline
Joined Apr 2008
Oh I thought there were real Jedi or people that had powers others did not
Are you saying Star Wars is not bassed of fiction
I practiced so hard like a Jedi on the simulator when first starting out fpv with eyes closed to prepare my self for loss of video situations
I comes in handy flying like Jedi
Especially if in case of complete video loss
Once I loose video and actually flew like Jedi for over 5 min
Jedi practice saved my plane
Osd directional indicator would of been useless
Only Jedi could control plane and absolutely no video at all
I highly recomend everyone practice like Jedi on flight sim
Whether you use osd or not
Question How long have you gone without breaking anything? CraigVMN Multirotor Talk 15 Nov 08, 2012 01:49 AM
Poll How far have you flown from Base Poll Bindle83 FPV Talk 36 Nov 01, 2009 06:54 PM
Discussion How far from you have you flown your Honey bee FP? Fairmont Micro Helis 8 Apr 04, 2008 06:30 PM
Who all has an xmod and what have you done to it so far??? aantoin Micro Cars 22 Mar 02, 2007 03:51 PM
Discussion How far have you driven (or flown) to join an event? KingOfTheHill Slope 29 May 10, 2006 08:05 PM
