Old Nov 18, 2012, 09:48 PM
DJO is online now
DJO
Find More Posts by DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
How far have you flown without an OSD?
Yo everybody,
So I'm just wondering. How far have you guys flown WITHOUT an OSD. Like not meaning a OSD with just voltage, without one that shows you which way is home. I've seen some videos of people going all the way out to over a mile without an OSD at all. How far have you gone? (ballpark of course, because without an OSD you can't be sure LOL) I guess it just depends on the area and how well you know it already, but I'm just curious.
Dan
DJO is online now Find More Posts by DJO
Old Nov 18, 2012, 09:55 PM
pjman is offline
Find More Posts by pjman
Joined Apr 2012
I've been to about a km going by google earth.
pjman is offline Find More Posts by pjman
Old Nov 18, 2012, 09:56 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Unless you're just wandering around aimlessly, direction home is actually a lot less useful
information than voltage and current. Case in point.
http://www.rcgroups.com/forums/showt...1381499&page=1
Daemon is online now Find More Posts by Daemon
Old Nov 18, 2012, 10:02 PM
DJO is online now
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Well I actually have an OSD coming in the mail that's super simple and just shows the voltage of up to two battery packs. I can normally fly for a half and hour and know my limits. I'm not a long range guy either - but sometimes it's very easy to get disoriented.
Dan
Old Nov 18, 2012, 11:15 PM
Hmerly is online now
Find More Posts by Hmerly
Hmerly's Avatar
United States, AL, Huntsville
Joined May 2012
I've gone out a good 4 miles without any osd. However, I did have a Ruby in my plane so I had the safety net of being able to get back home in case something went wrong. I wouldn't recommend it though, you're just guessing at your battery levels and hoping you have enough. It can also be disorienting sometimes and you can lose your bearing. Things look a lot different from the sky, even in familiar territory.
Hmerly is online now Find More Posts by Hmerly
Old Nov 19, 2012, 03:01 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
I fly all the time with no OSd
Gave up on OSd long ago as I have no need for it
My longest record is about 30 km away and 30 km back
Google earth tells the distance flown
It's easy just fly out look down at ground as reference to see how far you go
There is no need for OSd if you are aware of your position of the plane at all times
I am only one who fly long range without OSd
Thomas has to use google earth to verify my records
http://www.webx.dk/rc/uhf-link3/competition.htm
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Nov 19, 2012, 03:13 AM
David22 is offline
Joined Apr 2008
Dan
Voltage as you will get used to will be determined by throttle
And sound of motor
It's important to set. Up plane to fly at low voltages
If you fly for long time
Voltage curves are important aspects to understand
At low voltages it would come in handy to see on OSd all cells voltages
Especially if you use two or more batteries in series or parallel
Setting you lvc to desired setting and listening to motor and feeling throttle is good thing to get feeling for with OSd
Then you will understand no need for OSd
Old Nov 19, 2012, 06:22 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
So far I have come to mistrust the mah readings on the OSD. I rely on the voltage more than anything, and I run a couple planes with Simple OSD. But I would never fly more than a couple miles without a GPS OSD - well maybe if it was a very expendable plane and I knew the geography really really well. Fancy OSD really drive up the cost of a plane, for sure! My decked out planes are like $1500 loss if I lose it. My simplest FPV planes are only $200 loss if I lose it.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Nov 19, 2012, 06:23 AM
DJO is online now
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Awesome! And 4 miles is pretty good. 30km? OK... not sure about that one, seems kind of a stretch IMO. I guess as long as I can turn around and see where to go home I'll be fine. I know the area pretty well now too.
Dan
Old Nov 19, 2012, 08:11 AM
rcall is offline
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
when I fly at my usual field I fly about a kilometer around without OSD...
yesterday I flew at a different place so just after takeoff I circled the field looking for landmarks so I could be able to locate the field and land visually... that's my standard procedure...
after 5 minutes I lost GPS, so no home arrow, or at least a trustable one... no big deal, just looked around and went for a perfect landing...
learn to fly visually and don't rely blindly on your OSD...
rcall is offline Find More Posts by rcall
Old Nov 19, 2012, 08:19 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Three reasons for OSD in my book. Pack volts, motor amps to set throttle, and GPS coordinates constantly displayed should the plane go down. I usually dont use the home arrow too much unless I'm really turned around, or its dark.
One of my planes doesnt have OSD and I only fly that out about 1/2 mile
ashdec87 is offline Find More Posts by ashdec87
Old Nov 19, 2012, 08:23 AM
Exyator is offline
Find More Posts by Exyator
Joined Mar 2011
Iv'e been about 3.5kms without any osd, video from the gopro is here:
FPV to school - Flown w/Dragonlink (4 min 4 sec)
Exyator is offline Find More Posts by Exyator
Old Nov 19, 2012, 03:25 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
Too far (got disoriented, lost the plane)
philthyy is offline Find More Posts by philthyy
Old Nov 19, 2012, 07:01 PM
DJO is online now
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Alright so it's still farther than I thought. I'll feel better now, flying more than 1/2 a mile away without an OSD. But for now I'm having a blast staying in LOS and just flying FPV!
Dan
Old Nov 19, 2012, 09:01 PM
David22 is offline
Joined Apr 2008
Dan
I always underestimate my distances so there is no doubt how far I fly
Thomas takes his customer records very seriously but stopped giveing away
Free rxs to those who go the distance and return home
Besides Roberto montel took the records to such far distances it kind of blew everyone out of the competition, he is expert long range guy, you can see his name on hall of fame many times
But he use OSd and Rth
30 km away with no OSd is not hard to do at all
But does take good navigation skills and how to set up a fpv plane and ground station properly
I fly long range long ago , one of the pioneers of long range, which I am proud of
But now just fly short range, no further than 9 km at most now
Long range can be boring, but very exciting when done with no OSd
Question How long have you gone without breaking anything? CraigVMN Multirotor Talk 15 Nov 08, 2012 01:49 AM
Poll How far have you flown from Base Poll Bindle83 FPV Talk 36 Nov 01, 2009 06:54 PM
Discussion How far from you have you flown your Honey bee FP? Fairmont Micro Helis 8 Apr 04, 2008 06:30 PM
Who all has an xmod and what have you done to it so far??? aantoin Micro Cars 22 Mar 02, 2007 03:51 PM
Discussion How far have you driven (or flown) to join an event? KingOfTheHill Slope 29 May 10, 2006 08:05 PM
