Old Nov 18, 2012, 07:07 PM
13KenH46 is offline
Find More Posts by 13KenH46
Joined Dec 2011
Motor gearbox for a tug
I'm going to start a tugboat and was wondering if anyone has used this type of gearbox from Hobby King?
http://www.hobbyking.com/hobbyking/s...dProduct=15245
I know it's only a 4:1 ratio but I'm thinking of a low Kv brushless motor with a marine ESC. I fly RC models but my boating experience has been limited to rc sail so far.
KJH
13KenH46 is offline Find More Posts by 13KenH46
Old Nov 19, 2012, 12:55 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
I've used a similar Maxx 3:1 gearbox in the past, but have found plenty of low Kv out-runners tthat don't need a gearbox, depending on the prop size anything from a 700 Kv to 1000 Kv works well on 2 cell lipo or 6-8.4 volt (nimh ), the gearbox becomes useful if you want to run higher voltages and/or big props.
What size prop do you intend to use? check out my blog for the article I wrote on this subject
Nick
nick_75au is offline Find More Posts by nick_75au
Old Nov 19, 2012, 08:23 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Agreed, should be fine, and the gears look quiet enough (brass pinion on nylon gear, relatively fine pitch). As Nick says, the prop diameter will dictate the required output speed, and from there you can look at various kV's and ratios.
See my article for a typical prop speed chart:
http://matthewsmodelmarine.wordpress...all-geared-up/
patmat2350 is offline Find More Posts by patmat2350
Old Nov 19, 2012, 03:12 PM
13KenH46 is offline
Joined Dec 2011
The tug I'm working on is a 900mm long and I have a Billings 50mm brass prop. My original intention was to use a brushed motor but I havent been able to find a suitable gearbox. When I saw the Hobby King gearbox which takes a 28mm brushless motor, I thought that it might be a possibility. There are several motors around the 1000Kv available. The thing that has worried me is the usual brushless motors are low mass compared to brushed motors and consequently over heating in a boat might be a problem. Electric powered boats is a new field for me.
Nick
Your other comment about 700Kv or under motors maybe not needing a gearbox is interesting. And how do I find your blog?
KJH
Old Nov 19, 2012, 03:18 PM
13KenH46 is offline
Joined Dec 2011
Patmat
I have read your article and filed it away for future reference. A quick check with Hobby Lobby doesn't show any of those gearboxes being in stock. Or else I haven't figured out how their site works yet. Thanks for your reply.
KJH
Old Nov 19, 2012, 04:13 PM
nick_75au's Avatar
Joined Mar 2007
Hi,
Just click on my user name, its a PDF file. I've never had a over heating problem the watts are relatively low in comp. to an airplane motor.
Cheers
Nick
Old Nov 19, 2012, 04:53 PM
tsenecal is online now
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
if you want to go direct drive brushless:
http://www.engel-modellbau.eu/catalo...oducts_id=2426
tsenecal is online now Find More Posts by tsenecal
Old Nov 19, 2012, 05:04 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Sorry, old article... Master airscrew is no longer available, and HL stopped carrying Graupner. See graupner-usa...
Old Nov 19, 2012, 09:49 PM
CaptCB is online now
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Gearbox
This one is made by KYOSHO, costs about $10.00, uses metric r/c car pinion's, they cost about $5.00. I am running about 3-1, the motor is an Enegy 55turn, lathe motor. It is driving a 2'' Prop Shop prop,in a Robbe nozzle. Has shown NO wear, in the approx. 6+ years, it has been in the boat. CaptCB
CaptCB is online now Find More Posts by CaptCB
Old Nov 20, 2012, 04:17 AM
13KenH46 is offline
Joined Dec 2011
Thanks everyone. I like the idea of a direct drive so I will order something with a low Kv and see how it goes.
KJH
Old Nov 20, 2012, 09:40 AM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
Tower hobbies has a gearbox with a few ratios .
jmolwitz is offline Find More Posts by jmolwitz
Old Nov 21, 2012, 07:26 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Note that kv isn't everything... With direct drive, you'll need a hefty motor. With gearing, you can get good power with a smaller motor running faster.
Old Nov 21, 2012, 07:40 PM
13KenH46 is offline
Joined Dec 2011
Point taken. I have probably gone overboard but I have ordered a 530Kv 800W motor. You can't get small motors under 700Kv it would seem. If it proves the wrong choice I can always build a "big" plane.
I come from a electrical background and my thinking is the prop will require a certain amount of energy to spin it at a certain speed in water. So, if I'm on the right track, a small high speed motor working through a gearbox and a low speed motor with direct drive should bith draw about the same current.
KJH
Old Nov 22, 2012, 12:59 AM
nick_75au's Avatar
Joined Mar 2007
DT 700 is a very good motor for a 50 mm prop on 6-8 volts
http://www.hobbyking.com/hobbyking/s...ner_700kv.html
expect no more than 10 amps draw,
Your right about low Kv small motors, there's not a great deal out there. The 28mm and 36 mm motors are similar physical size to the standard brushed motors and from experience your spot on with this
So, if I'm on the right track, a small high speed motor working through a gearbox and a low speed motor with direct drive should both draw about the same current.
providing the prop shaft speed is the same.
Cheers
Nick
Old Nov 22, 2012, 04:19 AM
13KenH46 is offline
Joined Dec 2011
Cheers
Nick
I have one of those in my box of bits. Bought for an aircraft that has yet to be finished. I was looking for something lower in Kv but now I will have two possible motors to experiment with,
KJH
Question Motor, ESC, and Battery for Dumas Army Tug?? Gimpdiggity Scale Boats 1 Sep 15, 2012 04:40 AM
Sold Complete motor, Esc, and Gearbox Package NIB Rudderman98 Aircraft - Electric - Power Systems (FS/W) 5 May 24, 2012 09:26 AM
Help! Gearbox for Neumotors Neutron motor? nekoji Power Systems 2 Mar 06, 2012 04:55 PM
Sold Ar6400l, 2 servo's, p-51 motor/gearbox/prop 3d astronaut Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Mar 06, 2012 10:33 AM
Question Mounting GWS 5x4.3 to E-Flite UMX Extra 300 motor/gearbox BladeScraper Scratchbuilt Indoor and Micro Models 12 Feb 29, 2012 03:35 PM
