Old Nov 18, 2012, 06:48 PM
azflyingguy is offline
Find More Posts by azflyingguy
Gilbert AZ
United States, AZ, Gilbert
Joined May 2012
Twin Motor questions
I'm running two HURC power 80 motors 16 x 8 apc E props.
Combined I get 2000watts and 94 amps 6s 4000 mah 30c. Those numbers are not exact. When I run the motors Separately Im getting 1400 watts. Cant remember the amps. So why am I not getting 2800 watts when they are combined? I'm guessing the batteries cannot handle the amps even though they are 30c and sagging. I understand this isnt the Ideal battery because of short run times but I was expecting closer to 2800 watts.
Should I run two seperate batteries so each motor produces closer to 1400 watts? This way I get twice the Mah and more power. The airplane can handle the additional weight.
What problems will I have running two identical packs in the same condition? Should I parallel them? By paralleling them will the amps be split between both packs?
azflyingguy is offline Find More Posts by azflyingguy
Old Nov 18, 2012, 07:11 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Correct your packs are not up to task. You need larger packs that are capable of the draw. I suspect you are seeing VERY short flights too. That is a lot of expectation from small packs.
I would use two (wired in parallel NEVER separate) larger, much larger packs.
Old Nov 18, 2012, 07:49 PM
Gilbert AZ
Joined May 2012
The plane hasn't flown yet. I was just testing the motors. Can I run seperate 4000 6s packs.
What complications will I have?
Old Nov 18, 2012, 07:56 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Separate packs run in parallel will be fine.
You don't want to run them seprately as one motor may draw more and thus that "side" will reach LVC sooner. Not a big issue if you always time flights so long as you leave plenty of extra time.
I just feel it is better to run parallel.
Old Nov 18, 2012, 07:59 PM
Gilbert AZ
Joined May 2012
So is the amps split between the two? Thank you.
Old Nov 18, 2012, 10:15 PM
desertstalker is online now
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Yes, to all intents a pair of packs in parallel behave the same way as a single pack of double the size (provided the packs are the same).
desertstalker is online now Find More Posts by desertstalker
Old Nov 18, 2012, 10:22 PM
Gilbert AZ
Joined May 2012
Thank you
Old Nov 19, 2012, 04:27 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I assume you are using a wattmeter to read the amps and watts.
Also check the volts read out when under load, as that gives a good indication of the battery capability. A big volt drop shows the battery is not really up to the job.
eflightray is offline Find More Posts by eflightray
Old Nov 19, 2012, 08:21 AM
Gilbert AZ
Joined May 2012
I think the voltage dropped to 21 volts under load WOT. I have to look again. I suspect its the batteries not up to the task. I just wanted to test run with this pack anyway. I will try dual Parallel packs and post results here.
Thank. you.
Old Nov 19, 2012, 11:08 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
30C 8000mAh should be able to supply about 80% of 30x8000 = ~192A. Separately your motors draw ~65A each.That parallel pack should be able to supply 130A total easily enough. [at 22v under load that gets you your 2800W]
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 19, 2012, 11:56 AM
Gilbert AZ
Joined May 2012
Dr Kiwi thanks for doing the math. I never been good at it. I could use the extra nose weight anyway with two packs.
Old Nov 22, 2012, 02:43 PM
Gilbert AZ
Joined May 2012
Ok I don't understand this.
Two 4000 Mah 6s 30C packs wired parallel
Combine twin motor run with wattmeter inline.
2005 watts 91amps 22 volts
Watt meter inline with motor #1 and battery
1170 watts
51amps
22volts
Watt meter inline with motor #2 and battery.
1250 watts
54 amps
23 volts.
All test runs were with both motors running. I just move the watt meter from one to the other.
So why am I not getting the combine watts and amps when the wattmeter is inline with both motors.
1170 + 1250 = 2420 watts
51 + 54 = 105 amps.
This is my first twin setup.
Old Nov 22, 2012, 06:17 PM
Gilbert AZ
Joined May 2012
Ok I think I know what is going on. It appears I'm losing something in the harness.
When I hook up both batteries directly to the ESC's I'm getting 1250 watts, 52 amps and 23 volts per motor. These numbers are exact but +- 10 watts of each other.
So I'm about to forgo the wire harness all together and just time my flights so one motor doesnt hit LVC before the other.
Maybe I have a bad solder joint.
Old Nov 23, 2012, 02:27 AM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Or resistance/inductance losses, more likely. Try a very compact adapter instead of a wire harness, as close to connector-on-connector as possible.
acetech09 is offline Find More Posts by acetech09
For Sale Multiplex Permax Motor: Easy Star, Twin Jet, Twin Star, Mini Jet, Mini Mag FourDollaRacing Aircraft - Electric - Airplanes (FS/W) 0 Jul 25, 2012 02:15 PM
Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors SARCFAN Dock Talk 5 Jul 02, 2012 11:58 AM
Discussion 160 4-stroke twin question Big Nuts 181 Scale Fuel Planes 9 Apr 27, 2012 09:44 AM
Discussion New Twin Questions viper1216 Scale Fuel Planes 6 Mar 16, 2012 06:47 PM
Discussion Lipo question for my new plane twin air from robbe FedericoA Batteries and Chargers 10 Mar 07, 2012 09:49 PM
