Old Nov 18, 2012, 04:18 PM
aerofrutasd is offline
Find More Posts by aerofrutasd
Joined Nov 2012
Question
E-flite 20 amp mini esc. how to set up properly?
Could someone post a solution for this trouble?
Originally Posted by digsy
I have an E-Flite EFLA105 20 AMP ESC with Brake.
When I push the throttle stick forward nothing happens till the stick is 1/3 of the way forward. Then it springs into life.
But it seems like 3-4 clicks is about as much as I want to be moving it.
As part of setting the ESC up the instructions say "You must first properly set up the transmitter. Turn on the transmitter and place the throttle control stick in the center position. If you have a computer transmitter, adjust the throttle ATV to 100%."
Does it really mean put the throttle stick in the middle ? Or put it in what is normally the fully off position ?
I'd kinda like to have the throttle come on as soon as I start pushing the stick.
aerofrutasd is offline Find More Posts by aerofrutasd
Old Nov 18, 2012, 04:30 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
First thing to do is take the prop off the motor if you haven't yet.
Then try powering it up with the throttle stick in the middle as per the instructions. This is most likely some type of throttle range calibration that tells the ESC what PWM pulse widths correspond with which throttle settings.
Also make sure that the throttle trim is centered. Use it to fine-tune the startup position once you've set up the ESC and transmitter according to the manual.
Piece is online now Find More Posts by Piece
Old Nov 18, 2012, 05:59 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That is standard procedure for Eflite ESCs. Having the throttle stick in the center keeps the ESC from arming while everything is plugged in and turned on. Once the transmitter is turned on and the battery is plugged in, moving the throttle stick to the lowest position arms the ESC and tells the ESC what the minimum throttle setting is. The motor should start running as soon as you move the throttle one or two clicks from the low position.
Larry
Lnagel is offline Find More Posts by Lnagel
Discussion setting up E Flite 30Amp ESC ledpole Power Systems 5 Oct 15, 2012 05:57 AM
Sold E-Flite 450 BL Motor and E-Flite 20 amp esc rcjames1 Aircraft - Electric - Power Systems (FS/W) 2 May 26, 2012 12:18 PM
Sold E-flite 20 amp mini esc w/brake EFLA105 - SOLD Emile_Beaulieu Aircraft - Electric - Power Systems (FS/W) 2 Dec 17, 2008 11:13 AM
Sold "SOLD" E-Flite 40 ESC & E-Flite 20 ESC "SOLD" Yardbee Aircraft - Electric - Power Systems (FS/W) 3 Nov 13, 2006 12:02 PM
E-flite 20-amp Mini ESC #EFLA105 $15 PPD David Ponder Aircraft - Electric - Airplanes (FS/W) 5 Jan 23, 2004 06:55 AM
