This thread is privately moderated by efflux RC, who may elect to delete unwanted replies.
Old Nov 18, 2012, 04:07 PM
efflux RC is offline
Find More Posts by efflux RC
Trader Rating: 4
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Trader Rating: 4
Sold
Neumotor....28 x 56mm....5mm shaft.....1925kv
I have a number of these Neu motors available.
MR028-056-1800-V2-5
  • KV: 1925
  • No load current(lo) : 1.3A
  • Internal Resistance: 0.020 ohms
  • Diameter: 28 mm
  • Length: 56 mm
  • Weight: 153 grams
  • Shaft Diameter: 5 mm
$75.0 shipped to CONUS
Add $15 for int'l shipping.
Probably a good motor for the CS 70 EDF on 5s - 6s if you have a 5mm shaft adaptor. Do not spin the CS70 10 blade rotor faster than 46k.
Please PM me if interested.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Nov 18, 2012, 06:27 PM
hawkpilot is offline
Find More Posts by hawkpilot
Trader Rating: 13
Kettle Korn Factory
hawkpilot's Avatar
United States, NC, Winston Salem
Joined Nov 2008
Trader Rating: 13
Will it work in an 80mm fan, such as the Mach?
hawkpilot is offline Find More Posts by hawkpilot
Old Nov 18, 2012, 06:35 PM
Trader Rating: 4
efflux RC's Avatar
Joined Aug 2009
Trader Rating: 4
The Mach 80mm EDF accepts 36-39mm dia motors only.
Do not run it in the E-flite 80mm fan on 8s, 7s maybe.
PM sent regarding the Mach 80.
Site Sponsor
Old Nov 19, 2012, 03:26 AM
jentres is offline
Find More Posts by jentres
Trader Rating: 12
United States, NC, Rowland
Joined Dec 2001
Trader Rating: 12
I will take one. PM sent
jentres is offline Find More Posts by jentres
Old Nov 19, 2012, 02:18 PM
turbonut is offline
Find More Posts by turbonut
Trader Rating: 33
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Trader Rating: 33
How about 8s with a wemo or eflite?
jentres is offline
Trader Rating: 12
Joined Dec 2001
Trader Rating: 12
Paypal sent!!
Old Nov 19, 2012, 03:02 PM
Trader Rating: 4
efflux RC's Avatar
Joined Aug 2009
Trader Rating: 4
Scott,
The motor has a 5mm Shaft.
You might take a Wemo 90mm or E-Flite80 mm rotor and cut it down to 70mm and run some bench tests. I'm not cutting down rotors at this point.
Not suitable on 8s in a 80mm EDF.
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Dec 02, 2012, 09:35 PM
joe1 is offline
Find More Posts by joe1
Trader Rating: 57
United States, OH, Dresden
Joined Mar 2004
Trader Rating: 57
Motor
Hi :
What is the continous rated amps and max amps on that motor.
I also need to know if you have run that on a 4 cell setup , I plain on running it on 4 cell and using a 7x6 prop on a FunJet , whats your input ??
Thank You
joe1 is offline Find More Posts by joe1
Old Dec 02, 2012, 10:00 PM
Trader Rating: 4
efflux RC's Avatar
Joined Aug 2009
Trader Rating: 4
Originally Posted by joe1 View Post
Hi :
Thank You
The rated and max amps are not specified.
Here's the mfgr spec and suggested cell count for this motor.
"This motor has a 28mm OD and is 56mm in length. The shaft is 5mm. It has 16x19mm M2.5 mounting holes on the front Kv is 1925. It is the perfect match of the MniFan . On 8S it will draw 40 amps and produce 60oz of thrust.
For speed planes use a 3 to 5S battery. With 3S a 7x6 prop will draw 42 amps and on 5S a 5.5x5.5 prop will pull 45 amps"
Only 2 motors left.
Hope that helps.
Gary
Site Sponsor
Last edited by efflux RC; Dec 02, 2012 at 10:06 PM. Reason: correction/ added text
Found Collet Prop Adapter for 5mm Shafts Khosravi Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2012 04:59 PM
For Sale Venom V-28 & V-35 Propeller Prop Nut (4.5mm & 5mm Shaft) carn157 Aircraft - General - Miscellaneous (FS/W) 2 Nov 22, 2011 06:42 PM
Wanted neumotor 1527 1.5y w/5mm shaft demetrius Aircraft - Electric - Power Systems (FS/W) 0 Apr 16, 2009 01:08 PM
Wanted 2" spinner for 5mm shaft, 11 x 8.5E APC prop Megowcoupe Aircraft - Electric - Power Systems (FS/W) 0 May 13, 2007 01:17 PM
Mega 16/15/X with 5mm shaft is here! henke Power Systems 3 Jul 23, 2003 06:48 PM
