Old Nov 18, 2012, 03:21 PM
The_Builder is offline
Find More Posts by The_Builder
Joined Nov 2009
spars on solid core molded wings?
For those of you doing solid core molded wings, how are you doing your spars? A routed in spar is pretty straight forward but if the spar was a layer of Uni-Carbon how would you line it up in the mold?
Thanks, Paul
The_Builder is offline Find More Posts by The_Builder
Reply With Quote  (Disabled)
Old Nov 18, 2012, 04:25 PM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Good question been wondering myself....
Kennedy shows the cross section of their spars:
http://www.kennedycomposites.com/maxa.htm
The spar thickness must be so critical... I'd like to know how the halfs come together.
I think the samba stuff is tow piled up, but not sure....
heliwill10 is offline Find More Posts by heliwill10
Old Nov 18, 2012, 05:05 PM
Joined Nov 2009
The the uni strip you simply make it part of the lay-up and the mold presses it to the foam core like a set of mylars. The problem is knowing where to place it. I have lines on the "outside" surface of my mylars I use for lining stuff like this up but in a mold situation there would be no such marks.
You are dead on though for a hollow molded wing in that the thicknesses and placements are very critical.
Old Nov 18, 2012, 05:38 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Are you asking about how I do spars?
Old Nov 18, 2012, 08:50 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
I would make a spar alignment template that indexes in the alignment pin holes of mold.
wyowindworks is offline Find More Posts by wyowindworks
Old Nov 18, 2012, 10:15 PM
Joined Nov 2009
That makes sense, the other option would be marks on the flange. Eventually the template will get coated in resin. I could also paint the mold with a pattern and incorporate the spar into that so it gave me reference points,
Paul
Old Nov 19, 2012, 06:51 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Make a template, and you can even lightly sharpie the spar lines in place after your mold release / paint is applied. Why not have a light black line on top of your black carbon spar?
For the shear web, sometimes I use just the foam and other times I add some end grained balsa. On my current models I use a 4" long 3/16" wide balsa shear web that is cut 1mm shorter than the core and splooged into place to fill the gaps. That 4" length gives me really good rigidity out past the hole where the servos are cut in. This was a problem with a few of the early solid core airplanes (folding at the servo bay)
My current wing is overkill but it's still easily under 120g. (Maybe I take too many pictures)
tom43004 is offline Find More Posts by tom43004
Old Nov 19, 2012, 07:04 AM
Joined Nov 2009
Tom, I don't see a full span spar? If you get a minute give me a call I really want to move on this over the upcoming Holidays so I can have a molded wing in 2013.
Paul
Old Nov 19, 2012, 07:42 AM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Paul,
The sparcap is a piece of 4oz uni that is laid up in the skins.
Old Nov 19, 2012, 08:38 AM
Joined Nov 2009
That makes perfect sense. Thanks Tom.
Paul
Discussion Repairing damage on a solid core molded wing GaryO Hand Launch 16 Oct 17, 2012 09:36 AM
Mini-HowTo CNC Solid Molded Construction- Part One - Creating the mold tom43004 Composites Fabrication 27 Jun 17, 2012 08:59 AM
Discussion How to repair dents on solid core molded wings GaryO Hand Launch 5 Mar 20, 2012 08:15 PM
Discussion How to repair dents on solid core wings GaryO Hand Launch 0 Mar 10, 2012 10:37 PM
Question Why don't molded wings break on launch - unwrapped spars jirvin_4505 Sailplane Talk 24 May 02, 2009 01:55 AM
