Joined Dec 2008
Ok LJE4357 , but this has a bifurcated dual nozzles so if the normal exit size for a single 70 mm would be say 60mm does that mean 2 nozzles should be 30mm each ?Or does that logic not transfer directly ? Coolerbythelake , I don't know if you would call it open ducting but oversized would probably describe it .I found the FScalc but have absolutley no I dea how to use it .
OK what I meant by open ducting was, there is no separate intake,ie a fiber glass one. Yours just routes through the intakes back to the fan.
FSA calc is pretty simple. You will see (2) green sections. One for shroud inner dia, and bottom one for outside dia of the motor tube. Either metric or imperial measure works. Too make it easy just use metric. Just put those 2 numbers in, it automaticaly does the work. On far right side it will give the exhaust dia for the bifurcated ducts. From 100% to 70%, every 5%. Bifurcated exhausts don't work that way. If I take my Jetfan 90, at 100% FSA is 77.94mm in dia.(Single) Bifurcated ducts at 100% FSA are 55.11 mm in dia. each! You will have to measure your fan for any accurate results. Once you know exactly what your FSA is, measure the area of each intake WxL as close as you can. Then add the 2 together and see how that compares the what you fan FSA is. Exhaust is easier, the calc does most of it for you. It's not 100% accurate, but close enough. Some measuring is involved, but once you figure it out it's easy. |
OK don't know where you got it from , but download this one. this is what I have. http://www.rcgroups.com/forums/member.php?u=114136
Scroll down about half way, it's a zip file. Download and SAVE it. If your like me, remember where you you put it!! I'll check back in a bit.
Joined Dec 2008
Ok the new version works Thanks , However I'm technically inept and still have no idea how to use it ,I punch in the amount and there's an error exclamation point with no answer ..If you know how , what would be the right size for two exits keeping in mind I'm running a 10 blade 70 mm ?
Using 70mm as shroud ID, and guessing motor tube OD at 30mm. this is what you get. Measure the dia of exhaust to see where your dia falls. Post your results.
Exhaust Diameter (bifurcated outlet) 100% FSA44.72135955 95% FSA 43.58898944 90% FSA 42.42640687 85% FSA 41.23105626 80% FSA 40 75% FSA 38.72983346 70% FSA 37.41657387 |
pencon what is the dia of your exhaust?
I have read that also. Never had a CS fan so I really can't comment. Alot of what needs to be done is trial and error now. First, you HAVE to get your exhaust diameters!! You have to know were you started from and go slow. Just a little at a time. As small as those exhausts are the difference between 90 and 95% is very,very small. The rest is in your court. I wish you well. Mark |
| Thread Tools | |
| Sold AirField F-4 Phantom 70mm EDF Local P/U | Snshampton | Aircraft - Electric - Jets (FS/W) | 3 | Aug 31, 2010 09:19 PM |
| Wanted Airfield 70mm F-4 phantom gear | sam51401 | Aircraft - Electric - Jets (FS/W) | 0 | Jul 22, 2010 02:15 PM |
| New Product Combat-up The Airfield F-4 Phantom | redlite | Foamy EDFs | 7 | Mar 11, 2010 11:12 PM |
| Discussion AirField RC 70MM F4E Phantom Figher Jet Unboxing Overview | nitroplanes | Nitro Planes | 3 | Feb 19, 2010 07:29 PM |
| Discussion Airfield F4 Phantom arrived damaged???? | BRUTUS2238 | Nitro Planes | 4 | Feb 09, 2010 10:00 AM |
