Old Nov 18, 2012, 01:16 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Rudder Question
Thought I would post here instead of vintage since it applies mostly small planes. On designs like most of Ken Willardís small stuff, the rudder is angled. This works fine if you are going to be using some type of pulse or escapement utilizing a u shaped wire over the rudder, but if you are using a servo with a pushrod, it creates a problem. The angled rudder causes the pushrod to bind. If you made the rudder the same area but made it vertical, would this cause a flying problem? In other words, is there any advantage to angling the rudder?
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Nov 18, 2012, 01:52 PM
John Cole is offline
Find More Posts by John Cole
John Cole's Avatar
United States, CA, Santa Rosa
Joined Jun 2001
John, angled rudder hinge line gives a slight 'up' elevator effect when the rudder is deflected. I know what you mean by pushrod binding with this setup. I helped the condition by using a fairly long run of music wire, unsupported, to the rudder horn. Flexible enough to bend with the angled travel, stiff enough to handle air loads.
Hope this helps!
John
John Cole is offline Find More Posts by John Cole
Old Nov 18, 2012, 08:39 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
IMO Rudders on this size models are a waste of a servo.
Aileron and elevator are Far preferable.. If you want / can use positive control that is.
Bare is offline Find More Posts by Bare
Old Nov 18, 2012, 10:41 PM
Joined Nov 2009
Yea, but when it's single channel, kinda hard to do just ailerons.
John
Old Nov 21, 2012, 04:23 PM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
I'm wondering if you simply mount a slightly recessed micro servo in the fuselage say at the top near the front tip of the rudder, run a direct music wire pushrod with "V" bend for adjustment would work. It would keep the pushrod reasonably short. You could slightly over-drill the pushrod horn, so there is a very slight amount of slop to eliminate binding. This may not be necessary since with a smaller diameter music wire would have some flex so it would twist slightly without binding. YMMV.
OkiThumper is offline Find More Posts by OkiThumper
Old Nov 21, 2012, 06:34 PM
Joined Nov 2009
I hear what you are saying, but a short rod as you describe would flex/bend less than one running the length of the fuse. Think I will just try on my next one to have the rudder vertical and see what happens. Thanks!
John
PS. May even try mounting the servo on a plate like a actuator and putting the horn into a recess on the tourque rod like an actuator would work. Should work the same way except it will be proportional.
Old Nov 21, 2012, 07:12 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
I have flown a couple like this, including a TF Schoolmaster. I installed a ball link on the rudder horn, which was easy and completely solved the problem.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Nov 21, 2012, 07:54 PM
Closed Account
Joined Feb 2006
There's more than one way to skin a cat. I guess it just depends how ingenious one wants to get. Ball link makes sense. One could use the original RO torque rod and mount servo in a manner to move it similar to the old RO escapements or magnetic pulse actuators. One could maneuver a flex link to alignment is more true. Use pull-pull cables. Mount servo below rudder to directly torque it.
I've use the pushrod through the back fuselage plate's torque rod hole, bent up and forward to the nylon control horn ala Carl Goldberg style. (See OuterZone Goldberg 1/2-A Skylane plan servo detail found on: http://www.outerzone.co.uk/plan_details.asp?ID=868
That probably provides the longest pushrod and is more tolerant to flexing.
Discussion Question about aileron rudder mix function Riodiler1 Electric Plane Talk 12 May 09, 2012 06:53 AM
Discussion Noobie question about using rudder and ailerons together Riodiler1 Foamies (Kits) 0 Apr 29, 2012 02:56 PM
Discussion Esc/rudder Question 3drcflyer 3D Flying 13 Apr 29, 2012 01:59 AM
Question Pull-Pull Rudder/Tail Wheel Question Homer712 The Builders Workshop 6 Apr 26, 2012 03:11 PM
Discussion 450 trex clone throttle/rudder question stormheli Electric Heli Talk 1 Mar 31, 2012 11:19 AM
