Old Nov 18, 2012, 12:47 PM
Ala Flying Dude is offline
Find More Posts by Ala Flying Dude
Ala Flying Dude
Ala Flying Dude's Avatar
United States, AL, Prattville
Joined Jun 2012
Need 4 stroke identified? tks
Hi, I have been in to electrics for 2 years.
So I am not up to speed on 4 stroke motors.
Refer to 2 pictures This is a t-4 90 overhead cam 4 stroke, the seller doesnt know the manufacturer,
One factor is the drive belt off the motor that turns the prop. Obviouslly one would need spares
Any one know manufatuurer as well as a parts source.
Tks Dude
Ala Flying Dude is offline Find More Posts by Ala Flying Dude
Old Nov 18, 2012, 01:42 PM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
Those images don't open up ... so they remain too small to be seen.
bogbeagle is online now Find More Posts by bogbeagle
Old Nov 18, 2012, 02:12 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well I can't see the pics they are too tiny. But if you say it is a T4-90 that means it is a Webra engine. They used to make the rotary valve four stroke engines for quite a few years a long time ago.
earlwb is offline Find More Posts by earlwb
Old Nov 18, 2012, 06:10 PM
Ala Flying Dude
Joined Jun 2012
Tks
Tks for the help so far, I took those pics fro a ad the fellow had, its on ebay on used rc airplanes a japanese zero,
Appreciate it
Dude
Old Nov 18, 2012, 06:33 PM
williame3590 is online now
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
100% correct Earl.
Bill
williame3590 is online now Find More Posts by williame3590
Old Nov 19, 2012, 03:25 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Appreciate it
Dude
A"T4-90." is a Webra engine.
http://www.ebay.com/itm/63in-Japanes...item2ec393369a
The belt drives the rotary valve in the cylinder head, not the crankshaft.
IMO, forget it unless you like to tinker. Webra is gone and parts for these have gone to the collector status and are getting pricey.
Hemikiller is offline Find More Posts by Hemikiller
Old Nov 20, 2012, 12:16 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Appreciate it
Dude
This is the engine in question. It is very heavy. I used to make boat-anchor remarks when talking about it in the past. In short : I would not suggest starting with this one, espescially when it has been fiddled with by some previous owner. The correct setting of that headvalve is a nightmare. A clubmate of mine at RBWings club did make considerable changes to his at the time with good results. This is an engine from that period when every manufacturer was jumping on the 4-stroke horse.
Reginald is offline Find More Posts by Reginald
Old Nov 20, 2012, 03:03 AM
Joined Mar 2007
These engines have the benefit of being quiet and easy to handle.
Quite collectible, I believe.
Modest performance.
If it were mine, I'd keep it for its novelty-value. I reckon it would be a pleasure to see it running.... perhaps in some big vintage model.
Old Nov 20, 2012, 03:07 AM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
A fella from a previous club of mine had one and for its capacity it was huge . Not that that means anything , just saying is all ,Cheers the pope
the pope is offline Find More Posts by the pope
Old Nov 20, 2012, 05:36 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I bought and used a Webra T4-80 for a long time on a P51 Mustang many years ago. The engine wasn't all that powerful, but it had a distinctive sound that was different from the Saito or OS four stroke engines. So it sort of sounded a little better and more scale like. in comparison to the other model engines of that time period.
Nowadays, the belt for the top end are next to impossible to get. Fortunately the belt doesn't wear out for a long time. But since there aren't any replacement belts, it does make it a problem should you ever need one. Setting up the timing on the rotary valve can be tricky. But I forget what one does to get it set anymore. Thus I agree with Reginald in that I would not want to run the engine.
Old Nov 20, 2012, 06:33 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
The one Reg has pictured is the super charged one, it has crankcase supercharging like a YS, but uses one way valves instead of a rotary valve. This is the un supercharged version, note plates where one way valves go. Mine is a T-4-.87. Picture #2 is another one, note plastic idler pulley bracket, mine was broken so I made an aluminum one like in Reg's picture
I TOBOR is offline Find More Posts by I TOBOR
Old Nov 20, 2012, 09:50 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
I do have an original spare Webra belt for the 90 but seem to remember I did order a replacement version at our local Industrial Parts shop for someone and there was no problem with the size, even made from the same material. I can find out if you like. Beeing Webra thus German it is likely that they bought off the shelf belts on the market. The main problem with the T-90 was the shims for adjusting the vertical conical valve, inspired by the full-size Aspin valve. Leading the mixture trough the crankcase was to make use of crankcase pressure. This happens twice during every cycle. This kind of supercharging did not lead to great results with the T-90 and was abandoned in later versions, a set of close-off plates and gaskets could be bought separately from webra for owners of the first version. If someone is interested I can ask my clubmate what he did change on the valve. I flew the one in the pictures on a large Telemaster but was never happy with the running of the engine. The first version used a reed valve under the carburettor.
Old Nov 20, 2012, 10:47 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Reginald, thanks for the offer, but I sold the engine and plane years ago. I doubt I'll get another one, unless the price was really good. But if you knew the part numbers or specs of the belt, it would be really useful information to have out here on the internet.
Old Nov 20, 2012, 05:44 PM
Joined Aug 2007
Here's mine NIB never run. I would like to have one to run in a big oldtimer.
Bill
Old Nov 21, 2012, 03:14 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Here's the photos out of the ad, ones that are that badly discolored I find it works better to just convert them to black and white.
As for identity of the engine, its right in the title of the sale page:
63in. Japanese Zero rc airplane with webra T4-90 4 stroke
Wingman26 is offline Find More Posts by Wingman26
Discussion I need some help tearing down a FS 91 4 stroke Mike Brizzee Engines 12 Sep 30, 2012 01:49 PM
Discussion Need some help with os 4 stroke motors Mike Brizzee Engines 8 Sep 28, 2012 11:57 PM
Discussion Need a fun fly plane for a O.S. 40 4- stroke engine? eng30 3D / Fun Fly Fuel Planes 1 Sep 17, 2012 03:54 PM
Found ... cherokeenut Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 08, 2012 08:43 AM
Help! Need advise on engine, 2 stroke, 4 stroke? fltekdiver Fuel Plane Talk 1 Jun 08, 2010 08:21 PM
