Old Nov 18, 2012, 11:59 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Motor deals!
Check out the motor deals--one of these might be a good fit for you next racer or hotliner project. http://www.neumotors.com/store/page1/page1.html
Steve Neu
sneu is offline Find More Posts by sneu
Old Nov 18, 2012, 01:42 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
What is this MR motor Steve, is it one of yours? How many poles?
Looks like something I'd be interested in. The 5mm shaft is nice for running big power.
Steve C is offline Find More Posts by Steve C
Old Nov 18, 2012, 01:53 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
It is a 28mm motor with 4 poles. Same manufacture that made the Medusa motors ....but with some improvements.
Steve Neu
Old Nov 18, 2012, 01:54 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Could I run the 1410/2Y/SE on 4 or 5S on a prop plane ?
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Nov 18, 2012, 02:50 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Yes-- and since this motor has about the same Kv and resistance as our 1509/2Y you can use the motor calc program to see what different props would do. A 6x6 prop on 5S would pull about 60 amps and have a prop pitch speed of 170mph and give around 100oz static thrust.
http://www.ecalc.ch/motorcalc_e.htm?neumotors
Steve
Old Nov 18, 2012, 05:05 PM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
Are the medusa motors KV corrected to be more accurate now or has the winding changed? Also are they all available in 1/8 shaft diameter?
biskit is offline Find More Posts by biskit
Old Nov 18, 2012, 05:46 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
All the sale motors have 5mm shafts. The MR028-056-2300 has a Kv of 2590, the MR028-056-1800 is 1925Kv and the 1410/2Y is 1850Kv. I am not too sure how Medusa got their numbers but the above numbers are actual measured Kv for the motors we are selling.
Steve
Old Nov 19, 2012, 04:50 PM
smoothflying is offline
Find More Posts by smoothflying
Joined Apr 2012
Do you recommend good Boca bearings? And if its a good idea which one would be good for the 1115/1Y?
smoothflying is offline Find More Posts by smoothflying
Old Nov 19, 2012, 07:06 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
We use SPB bearings from Japan. Not sure about which Boca bearings are best since they have a wide range of quality.
Older 11XX motors had inch size bearings(.125 inch)--the newer ones have metric(5mm).
Steve Neu
Old Nov 20, 2012, 04:03 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Not related to the topic of the thread, but since bearings came up:
Steve, I have a 1115/1Y and it has developed a slop in the shaft. I can move it about 2mm in and out, and it runs "hot". Any suggestions?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 20, 2012, 11:38 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
Sounds like the brass shim on the front of the rotor has worn and should be replaced. If the rotor moves forward enough the Kv will increase since it is no longer fully covered by the stator which could make it run hot.
If the shaft is not worn then some more shim spacers should be all that it needed--if you want to try fixing it yourself take care when taking out the rotor since the shim washers sometimes get lost in the process of tailing apart. Some heat on the screws holding on the rear end cap helps get the screws free. If you need a few shims and spacers we can send them.
Steve Neu
Old Nov 20, 2012, 11:41 AM
Arcteryxxx's Avatar
Joined Feb 2010
Thanks Steve. Will take a closer look at it soon and send you a PM with further questions if necessary and if it's ok with you.
Sold Motor Package Deal BriGuy82 Aircraft - Electric - Power Systems (FS/W) 0 Sep 27, 2012 02:04 PM
Alert Anyone need a GREAT deal on 4s motors? scorpion1 Racing Boats - Electric 1 Sep 15, 2012 06:08 PM
Sold Brushless motor package deal jbest Aircraft - Electric - Power Systems (FS/W) 2 Sep 12, 2012 05:23 PM
Discussion Twin Motors Do I really want to deal with this. azflyingguy Power Systems 13 Aug 02, 2012 06:17 PM
For Sale Multiple Items. Wemo Fans/Arc Motors/ Etc Package Deal Pepperpete Aircraft - Electric - Jets (FS/W) 1 Jul 10, 2012 07:22 PM
