Old Nov 18, 2012, 11:46 AM
sdculp is offline
Find More Posts by sdculp
Joined Jan 2005
Bad Batteries??
I have a S.E.5a Slow Flyer. I am using the recommended motor and batteries. It is 2 or 3 years old. The motor runs with a pulsing sound with either of two batteries. I am sure this is responsible for somewhat sluggish behavior. I don't recall if it was this way, initially, but I think not.
I have tried recharging several times, but it doesn't help. None of my other planes/batteries behave this way.
Is this a battery problem?
sdculp is offline Find More Posts by sdculp
Old Nov 18, 2012, 12:38 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
The pulsing you described sounds like a "soft" low voltage cutoff (LVC). If so, that would mean that your battery voltage is sagging too much (a symptom of weak battery packs) or the LVC is incorrectly set for the battery packs you are using.
Pete
PGR is offline Find More Posts by PGR
Old Nov 18, 2012, 12:55 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Are the batteries as old as the plane? If so, it's probably time to get new ones... Especially if they've been stored for extended periods of time above storage voltage.
Piece is offline Find More Posts by Piece
Old Nov 18, 2012, 12:58 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Swap the batteries with planes that do not pulsate.
Simple enough to test ?
cyclops2 is offline Find More Posts by cyclops2
Old Nov 21, 2012, 06:09 AM
sdculp is offline
Joined Jan 2005
Thanks for the response.
I put the battery from my EP Falcon into the SE5 and it pulsed in the same way. Then I put all the batteries in the Falcon and they sort of pulsed. I built the Falcon last winter and got the battery about the same time. All are 2 cell. The 3 cell batteries I have been using for a few years in my Magpie have never behaved this way. Maybe this is a characteristic of the smaller 2 cell batteries?
Batteries are supposed to be stored “for long periods” in the storage mode, but “for long periods” is not defined. Weeks? Months? I am probably guilty of not using the “storage” mode.
Maybe my previous post “Cold Weather??? http://www.rcgroups.com/forums/showthread.php?t=1766032 is not all about temperature, because the 3 cell Magpie seems to do fine in the cold.
The flying season is about over here in central New York State, so if it’s new batteries I need I’ll wait until Spring to get them, because the Falcon battery seems to be shot in less than a year.
Do the small LiPo’s wear out in a year or so?
Old Nov 21, 2012, 06:32 AM
cyclops2 is offline
Joined Mar 2003
I am with PGR on your ...........LVC starting to just cut off.
ESCs DO NOT really like 2 cells...........LVC setpoints can be touchy at 2 cells Try a different brand of .......2 cell RATED esc.
Post that question in the ESC electrical sections
Can you reprogram the LVC points in your E$SC ?
My little 6 & 10 amp ones have several LVC cutoff points. Not cheap tho.
Old Nov 21, 2012, 06:46 AM
cyclops2 is offline
Joined Mar 2003
My Feigao 2 cell 6amp & 10 amp ARE TRUE 2 cell ESCs.
LVC is 2.6.......... 2.85.............. 3.1 volts.
Old Nov 21, 2012, 03:10 PM
sdculp is offline
Joined Jan 2005
My Electrifly ESC says cutoff occurs at .67v. If you assume the charge was 4.2 volts, that makes .67x4.2=2.8v. According to Wickipedia anything below 3.0 is supposed to damage the cell.
I guess the only way to really know is to monitor the voltage while the motor is running, but I doubt that voltmeters could follow the pulses.
I just went out with the 3 cell batteries and they flew great. Guess I'll wait til spring to get some new 2 cells. I don't know how long the local hobby shop had them on the shelf, so I'll get the new ones online.
Old Nov 22, 2012, 05:29 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
Does the ESC recognize the battery as a 2 cell?
Does it beep twice, or 3 times?
aurorae is offline Find More Posts by aurorae
Old Nov 23, 2012, 03:46 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Yes, time for new batteries.
Storing batteries fully charged shortens their life but over discharging is probably the worst thing. Use a timer with flight time adjusted by trial and error so that when you measure voltage shortly after a flight you have about 3.7v per cell minimum. Try to avoid ever running all the way down to LVC.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Nov 25, 2012, 02:54 PM
sdculp is offline
Joined Jan 2005
ESC beeps twice. There is no cutoff adjustment, but I never fly that long, because the planes donít have enough power to fly long before that.
Although the 3 cell batteries still give good, everyday performance, I realize that all my batteries are getting a little tired. I decided to take a close look and hook up the USB to the charger and computer. The attached pictures tell the story. Storage voltage and current 1 refer to the 3 cell and Storage voltage and current 2 refer to the 2 cell. I donít have any new batteries for comparison (Iím waiting Ďtil Spring).
First, note that the voltage curves should remain flat until nearly discharged. Not so here.
In the case of the 3 cell, note that the voltage drops from 12.6 to 12.34 volts immediately upon application of the 0.4 amp discharge current. A little oversimplification of the equations says that R=(12.6-12.34)/0.4=0.26 ohms. The most current you could pull, instantaneously, without hitting the cutoff voltage is I=(12.6-11.4)/0.26=4.6 amps. This is enough to keep the larger plane happy, although not enough for full power activity.
The two cell battery is a different story. The voltage drops from 8.4 to 8.23 immediately with the 0.4 amp storage current. In this case R=(8.4-8.23)/0.4=0.425 ohms. The most current you could pull without hitting the cutoff voltage in this case is I=(8.4-7.6)=1.88 amps. Iím sure this is why the little motors are pulsing.
The motors are not purely resistive and the battery voltages are not constant with time, so a more thorough graphical analysis would have to be done to get the complete story. Also, the resistance of the battery leads enter into the picture, although I wouldnít expect it to be that much at these low currents. This is all an approximation, but it does show that the battery voltages donít remain flat, and full battery voltage is not available to the motor, initially. The milliamp-hours are way low.
Alert DO NOT Mail back bad Li-Poly Batteries, Unless you like Federal Prisons! 2dogrc Batteries and Chargers 4 May 13, 2012 04:41 PM
Discussion Bad crash! Hot battery. SquireM Batteries and Chargers 7 Apr 14, 2012 09:55 PM
Question Bad battery? thinman Batteries and Chargers 7 Mar 22, 2012 11:55 AM
Discussion Do batteries go bad to the point of an "open circuit" error? lawlist Beginner Training Area (Heli-Electric) 3 Mar 16, 2012 09:57 AM
Bad battery... NImh bad , bad... gulio Batteries and Chargers 7 May 24, 2005 08:16 PM
