Old Nov 18, 2012, 07:53 AM
Xascent is offline
Find More Posts by Xascent
United Kingdom, England
Joined Oct 2012
To Oil or Not to Oil
Just wondering if it is ok to put a drop of light oil on your bearings ? Radial type that may have been pre greased.
Heard somewhere that lubricants shouldn't be mixed.
Xascent is offline Find More Posts by Xascent
Old Nov 19, 2012, 02:58 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
True, but running the bearings dry is much worse. Use Triflow and keep using it.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 19, 2012, 03:42 PM
nitrodude71 is offline
Find More Posts by nitrodude71
r/c addict
USA, LA, DeRidder
Joined Jul 2004
heres a little basic maintenance tips for you based on one of my experiances with the align trex 250se which consist of oiling. while i cant say much for the align motor or any other as i only run the scorpion 3900 (I oil mine every 15 to 20 flights) or so you should oil (one small drop) both the top and bottom bearings. i use the Scorpion Motor Bearing Lubrication Kit for my "motor only" http://www.readyheli.com/OilKit-Scor...t_p_35764.html and the triflo oil kit (use sparingly) for bearings and all other parts of the heli http://www.readyheli.com/TF21010-Tri...e_p_36037.html but just remember the scorpion motor bearing lube is only used for the motor bearings due to it being a bit thicker. ask me how i know this lol? because i thought if its so good for the main motor than is should be good for the rest of the heli. (WRONG) when i put it on the mainshaft and swash the pitch was so sticky when i gave it pitch input nothin would happin so i thought hmmm let me give it a little more. and all of a sudden "zoom" she was out of site lol so then i fought to get er back in. then thought about it for a minute then cleaned the scorpion motor lube off the swash an mainshaft then.. "and then and then and then" added what i usualy use (triflo) then bam she was once again as smooth as a babys bottom.
so good luck and just have fun with it
nitrodude71 is offline Find More Posts by nitrodude71
Old Nov 19, 2012, 03:53 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
Been using Dupont Teflon Lubricant on bearings and sliders, seems to get everything freed up pretty good. I believe it is around the same as Tri-Flow.
ASTREA1 is offline Find More Posts by ASTREA1
Old Nov 19, 2012, 04:26 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I've just adopted a new oiling routine. I dab on a bit of sewing machine oil with a Q tip on my tail rotor shaft and mainshaft, having first cleaned the shafts with another Q tip, at the start of every flying session. I've been monitoring a Gotek 9257 tail servo that has been running up to 130f - but since I started oiling, I've not seen it get to more than 105f. I know it's not a particularly well controlled experiment, but it seems encouraging.
2Doggs is offline Find More Posts by 2Doggs
Old Nov 19, 2012, 04:47 PM
Xascent is offline
Joined Oct 2012
Ok thanks all, I have some of the scorpion bearing oil and it was that which I wondered would be ok for bearings, I guess not. Will get some of the triflow stuff or would liquid silicone lube be ok.
Old Nov 19, 2012, 04:56 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Nothing wrong with the Scorpion bearing oil. It might be easier to get the Triflow into some bearings though. Without stripping your motor, you can't easily oil the inner bearing of the pair used at the opposite end to the pinion, but most of the other bearings on the heli may be somewhat accessible with a needle or similar thin probe.
Discussion 694ZZ bearings: to oil or not to oil Pheliciano Power Systems 1 Oct 01, 2012 01:52 AM
Discussion To oil or not to oil the bearings? blueviewlaguna NeuMotors 1 Sep 03, 2008 06:08 AM
To oil or not to oil? olddog Electric Plane Talk 22 Jan 18, 2005 11:43 AM
GWS 300C "B", Oil it or not? KeithLuneau Parkflyers 4 Jul 27, 2002 08:55 AM
