This thread is privately moderated by JimStanmore, who may elect to delete unwanted replies.
Old Nov 18, 2012, 07:46 AM
JimStanmore is offline
Find More Posts by JimStanmore
Trader Rating: 152
Changing one life at a time...
JimStanmore's Avatar
United States, NJ, Pemberton Township
Joined Aug 2010
Trader Rating: 152
Found
>>FOUND<< 3.3v BEC/UBEC Wanted >>FOUND<<
I am looking for a 3.3v BEC/UBEC along the lines of the AEO 3.3V 3A UBEC. I am going to use it to power a DSM2 module in a Th9x. Don't need the connectors because I have to solder all of the wires anyway. Before sending the money to HP, I thought I would see if someone in the community could use it first.
If you have one lying around that you can let go, post or pm what and how much.
Thanks!
>> FOUND <<
JimStanmore is offline Find More Posts by JimStanmore
Old Nov 18, 2012, 11:13 AM
nitrodude71 is offline
Find More Posts by nitrodude71
Trader Rating: 144
r/c addict
USA, LA, DeRidder
Joined Jul 2004
Trader Rating: 144
would this maybe work
http://www.rcgroups.com/forums/showthread.php?t=1771914
nitrodude71 is offline Find More Posts by nitrodude71
Old Nov 18, 2012, 11:27 AM
Trader Rating: 152
Joined Aug 2010
Trader Rating: 152
Thanks nitrodude71, the only thing wrong with that is my application needs 3.3v out and that provides 5.8v or 5.1v.
I am going to be using a DX5e DSM2 transmitter module mounted in a regular 9x module. The module from the cheapie BNF controllers may work with the 3.3 off of the 9x board, but the DX4/5e module may draw too much power and cause brownout resetting. I have an LM317 and the components to make a voltage regulator, but a BEC/EBEC is a simpler and cleaner installation.
You have to er9x flashed on your radio; it not only changes the channel order to match DSM2, it also has the code to send out DSM2 compatible signals. I used a cheap USB programmer at first and then s_mack gave me a Smartie parts board (thanks again!!!) and that makes life a whole lot easier.
http://www.hacksmods.com/2011/12/spe...e-from-hp6dsm/
http://9xforums.com/wiki/index.php/H...e_DSM_protocol
http://www.rcgroups.com/forums/showthread.php?t=1691703
Old Nov 18, 2012, 11:30 AM
Trader Rating: 152
Joined Aug 2010
Trader Rating: 152
>> Found << one through the Aircraft - General - Radio Equipment (FS/W) thread.
Latest blog entry: Plans On My Build List
Help! HK OSD not working with 3.3v Camera Firepower FPV Talk 0 Sep 02, 2012 01:51 AM
Wanted 3.3v usb>ftdi programming card jy0933 Aircraft - Electric - Multirotor (FS/W) 4 Jul 20, 2012 09:51 PM
Discussion Who Makes/Sells Quality/Reliable BEC's/UBEC's? itsme2 Power Systems 5 Mar 17, 2012 10:27 AM
Discussion Hobbyking 3.3v 3amp ubec aeromaniac Radios 4 Dec 25, 2011 07:40 PM
Question Spectrum AR7000 on 3.3v BEC? Oreo Radios 3 Apr 25, 2007 01:07 AM
