Old Nov 18, 2012, 07:25 AM
Manonthegrassyknoll is offline
Find More Posts by Manonthegrassyknoll
United Kingdom, England, Windermere
Joined Oct 2010
jst connections on 850 3s 25c
..as the title suggests, can I use jst connections on a 25c 3s 850..? At the moment i'm using the battery on my Radian with EC3s but i'm building a 'simple kite' and would like to use the same battery and use jsts, not sure if it would cause problems..
Chris..
Manonthegrassyknoll is offline Find More Posts by Manonthegrassyknoll
Old Nov 18, 2012, 08:32 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
If by JST you mean the little red ones which are used on many small park flyer types then yes. Fact is many small and some not so small LiPolys come with these connectors on them. They are good for around 6A continuous duty as long as they are fairly new in good shape.
Charles
Old Nov 18, 2012, 08:43 AM
Joined Oct 2010
Hi Charles..
yes.. the small red ones.. and could I swap the ec3's on my Radian to jst's..? or would that be asking to much..?
Chris..
Old Nov 18, 2012, 09:25 AM
Southern Pride
Radian would be to much for the JST most likely. Not really sure but my guess is that Radian draws 15 plus amps at full throttle.
Old Nov 18, 2012, 09:47 AM
Joined Oct 2010
I thought as much..i'll make up a ec3 to jst connection so I can run the 3s on the kite..
thanks guys..much appreciated..
Chris..
Data HK Turnegy nano tech 25C 3S 850 everydayflyer Batteries and Chargers 8 Mar 10, 2012 01:41 PM
Sold Hyperion Lipos: 3S-850 CX(25c) packs (4) JoeR Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 06, 2011 11:05 AM
Found 3s 1500mah and/800-850 15-25C teha99 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 12, 2010 11:39 PM
Sold VAMPOWER 3s 25C 850 Mah BATTERIES (NEW) JBFergus Aircraft - Electric - Batteries & Chargers (FS/W) 3 Aug 08, 2009 01:43 PM
Sold 2 x Dualsky GT 850 mah 3S 11.1v 25C rivers Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 27, 2008 09:12 AM
