Old Nov 18, 2012, 06:49 AM
Ramidan is offline
Find More Posts by Ramidan
Joined Mar 2011
Battery Concerns on In flight Arm Cluster
As some of you may or may not know, I bought a rotomast V-22 and have been working deep with autonomy in java. I am now to the point that I want to try to get my on-board computer cluster working using a LiPo battery set. My concern is that the discharge rate is to high to use successfully use in my little cluster.
The cluster is made up of 4 ARM boards and a teeny 4 port switch running Ubuntu, all in all weighing less than 8oz. The power requirements are 7.5v @ 1A for the switch, and each ARM board requires 5V @ 2A. I'm still not 100% clear on the "discharge rates" of a LiPo battery. I'm torn between the added weight of a dedicated battery, or tapping into the current system battery and the BEC, so I guess that is my question here.
I have the craft running on 4 Turnigy 2200mAh 4S 30C Lipo Packs instead of the 2 it initially took. Would it be better to:
A - use a BEC and tap into the 5v output there, build a dc/dc stepper circuit and convert a leg of that to 7.5V for the switch ~or~
B - create a custom shunt and voltage converter circuit and use a separate battery?
Ramidan is offline Find More Posts by Ramidan
Old Nov 18, 2012, 10:47 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Your question is a bit confusing, at least for me it was, because you seem at first to be concerned with the current ratings of your batteries, but then you ask questions about the various voltage requirements of your system. As far as the current ratings of the batteries are concerned, yours look like they are plenty big enough to power the computer "cluster". The computer and switch, as you may or may not understand, will only draw as much current as they need to work, the batteries won't discharge too much into them. The discharge rate of the batteries simply indicates how much current they can safely provide if the load requires it, not what they will force or pump into the load.
As for the voltage requirements, I'd suggest you build a voltage regulator with the 2 outputs you need (5 and 7.5 volts), and power it with the batteries you have. No need for a separate battery, those four 4S 2200mAh packs will never know the computer and switch are even there.
dmccormick001 is offline Find More Posts by dmccormick001
Old Nov 18, 2012, 06:49 PM
Ramidan is offline
Joined Mar 2011
dmc,
yeah sorry, I'm a little scatterbrained here on this. I have about 50 different spaghetti strands that I am trying to put together. Sorry if it was confusing. This is after I have put in 2250 feet of tile and revamped a back door to my house.
Let me say this. I am concerned that the batteries will push too much current only because I have fried 3 multimeters trying to get readings off of them (directly). I guess I'm gun shy to test on my cluster because it's a $1K piece of equipment, and if I fry it being too cavalier on testing I'm gonna bash my face into the wall.
Thanks for the clarification on the current, I couldn't remember if it force pumps it into it or not. So realistically, I shouldn't rely on the BEC to power the 5v systems? Having to build a voltage regulator to support dual outputs will not be too hard.
Old Nov 18, 2012, 07:03 PM
rmteo is offline
Find More Posts by rmteo
User
Colorado
Yikes!!! Have been connecting the battery packs directly to the multimeter probes while it is set to (high) current measuring mode? That is guaranteed to blow the shunt resister in it.
rmteo is offline Find More Posts by rmteo
Old Nov 18, 2012, 07:39 PM
Ramidan is offline
Joined Mar 2011
yeah,
I figured that out a little too late.... lol
Old Nov 19, 2012, 09:04 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
They don't "push" current. They provide the current "drawn" by the circuit.
Ohms Law tells you how it all works together.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 19, 2012, 03:21 PM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
I would strongly suggest you get someone who understands the basics to check what you are wiring up.
LIPOs are really explosive devices in battery packages, treat them wrong and they will explode in a large fireball.
srnet is offline Find More Posts by srnet
Old Nov 19, 2012, 07:29 PM
Ramidan is offline
Joined Mar 2011
It's been YEARS since I've even remotely built any circuitry (since my college days) - 8 years ago. I am just researching building a LM7805 regulator. (trying my hand at making something simple yet useful)
Old Nov 19, 2012, 08:13 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Errrmmm.... Not exactly.
Piece is offline Find More Posts by Piece
Old Dec 01, 2012, 06:49 AM
Ramidan is offline
Joined Mar 2011
Well instead of re-inventing the wheel, I ran an internet search for an adjustable DC-DC voltage regulator. Most were rather large and bulky, but I did manage to come across a 10W and 25W adjustable regulator:
http://www.robotshop.com/ca/dimensio...regulator.html or even looked on ebay for a 12-24V to 5v Dc-Dc converter. Found a new small non adjustable ones.
Old Dec 01, 2012, 08:17 AM
rmteo is offline
User
Colorado
$3 DC 3~40V to DC 1.5~35V Voltage Step Down Transformer Module
Old Dec 02, 2012, 08:10 PM
Ramidan is offline
Joined Mar 2011
Oh man, thank you so much. I just ordered 5 of them.
Old Dec 02, 2012, 08:15 PM
rmteo is offline
User
Colorado
Pretty amazing isn't it - $12.50 for 5 with free shipping. Should arrive in the USA in about 14-20 days or so.
Old Dec 03, 2012, 08:06 AM
Ramidan is offline
Joined Mar 2011
I actually paid $16 total. I ordered 5 because they might not be the best quality. They also have a ton of arduino parts and shields on there. I might have to pick up some extra parts.
Discussion Batteries concerns.. gsfakian Multirotor Electronics 1 Oct 22, 2012 01:12 PM
Help! Should a Phoenix HV45 arm on a two cell battery? Art Horne Castle Creations 8 Jul 20, 2012 10:52 AM
Discussion Groups Concerned Over Arming Of Domestic Drones wannabe Life, The Universe, and Politics 32 May 24, 2012 01:10 PM
Alert noticing dangerous body, hand, and arm positions when plugging in flight battery MikeontheBike Beginner Training Area (Aircraft-Electric) 41 Mar 30, 2012 11:32 PM
Question how to set up a system using two lipos in parallel and an on board flight battery? rosemark Power Systems 3 Mar 30, 2012 08:29 AM
