Old Nov 18, 2012, 04:51 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
NGH 38cc 4 stroke
Turk showed a pointer to this engine a little while back. Looks interesting. Anyone tried it yet? I dont mind tinkering, but I dont want a project engine. More interested in flying.
http://www.himodel.com/engines/NGH_G...ol_Engine.html
Edwin
edwin1 is offline Find More Posts by edwin1
Old Nov 18, 2012, 09:50 AM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
http://www.rcuniverse.com/forum/m_11298314/tm.htm
turk1 is offline Find More Posts by turk1
Old Nov 18, 2012, 09:55 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I want to get one too, but I have to wait a while, as I am short on funds at the moment. Good thing they sold out fast, so I didn't have to fret about it much. HiModel has been pretty good on getting parts out, even when out of stock or back ordered. I ordered some parts and it didn't take them all that long to fill the back order either.
earlwb is offline Find More Posts by earlwb
Old Nov 18, 2012, 10:53 PM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Hi Earl, maybe you can ask Agape why still no offer from their site.Maybe transportation takes time.
Old Nov 19, 2012, 05:56 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It just came out. If I remember it took several months after the 9cc engine came out before other dealers in the USA started selling the engines. Since they have a network in place now, I assume it will be a few weeks. Like you stated it takes time to ship them across the ocean to the stores.
Himodel seems to get them first before everyone else does.
Old Jan 07, 2013, 08:34 PM
JeffEE is offline
Find More Posts by JeffEE
Deadstick
United States, MN, St Paul
Joined Nov 2004
I have mine, and so far its not too bad. I think the only "cheap" part is the exhaust tube. Its like the cheapest softest aluminum. But the motor runs fine so far.
JeffEE is offline Find More Posts by JeffEE
Old Jan 07, 2013, 10:03 PM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
The power results I've seen for the NGH 38 quoted are 7300 RPM W/an 18X8 prop.
Back in the spring when I was testing E-85 pump gas in my C&H CDI Saito FA150 I was seeing 7500 RPM W/an 18X8. Even if 200 RPM is lost using 10% ethanol pump gas instead of E-85, the FA150 gas conversion will still make as much power in a lighter package that vibrates a lot less.
This enginje does not even seem to be in the same power classs as an FG30 let alone an FG36 Saito.
What's the weight?
SrTelemaster is offline Find More Posts by SrTelemaster
Old Jan 08, 2013, 12:34 AM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
What's the weight?
Those engines are so newly arrived that none of them has a complete break in yet let alone have a good tuning after(timing etc).So, give some time to evaluate them.
Old Jan 11, 2013, 12:33 PM
I HATE GLOW PLUGS!
Joined Feb 2012
It will have a long way to go from 7300 W/an 18 X 8 to live up to the Saito FG36 that is is competing with.
8000 W/an 18X8 is about where a gas burning 4-stroke engine of this size should be running.
That's just under 3HP, the RPM listed is about 2.2HP. More on the order of a 25cc gas 4-stroke level of power.
Old Jan 11, 2013, 01:29 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well one thought is it has a Walbro carb and uses a RCexl ignition, both of which work. Some people have been pretty vocal about having to upgrade their Saito gas engines to get them to work.
Old Mar 03, 2013, 03:19 PM
affas is online now
Find More Posts by affas
Lier, Norway
Joined Nov 2003
Phoenix Model Mustang P-51, 50cc and NGH GF 38 FS fourstroke gas engine (6 min 55 sec)
affas is online now Find More Posts by affas
Old Mar 03, 2013, 04:09 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Just how did you get your field like that.
Here in missouri USA we have a bunch of snow on our field and unless you have skis it cannot be flown off of
kerwin50 is offline Find More Posts by kerwin50
Old Mar 03, 2013, 04:26 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I happened to see that NGH released a "PRO" version of the 38cc four cycle engine.
http://www.himodel.com/engines/NGH_3..._GF38-PRO.html
It has three piston rings on it instead of the two on the regular engine. They also put in four prop bolts instead of just the single center prop nut on the regular engine. Looks like it has black anodized trim in lieu of the blue anodizing trim. Plus it uses a radial mount setup and does not have lugs on it for beam mounting.
Old Mar 04, 2013, 12:14 AM
affas is online now
Lier, Norway
Joined Nov 2003
We so have a deal with the local farmer and his tractor/snowblower
If it is just 10-15 cm we do use this manual snowblowers.
And if it is just some few cm we do use two europall upside down hatched together behind a car and drag rhis unit along so the surface is just as smooth as silk....
Old Mar 04, 2013, 09:44 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Help! .54 4 stroke v's .91 4 stroke? clambert24 Fuel Plane Talk 7 Sep 17, 2012 08:00 PM
Sold new magnum 4 stroke xl 70 and new evolution 46 nx 2 stroke jsteil1098 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 07, 2012 12:15 PM
Question 2 stroke fuel vs 4 stroke fuel sweatybetty Fuel Plane Talk 18 Jul 25, 2012 09:33 AM
Sold airplane engines 2 stroke & 4 stroke jeff jerdon Aircraft - Fuel - Engines and Accessories (FS/W) 8 Apr 16, 2012 12:28 PM
Wanted wanted NGH 2,4 ghz standar or advanced receive FPV junglew Aircraft - General - Miscellaneous (FS/W) 0 Aug 30, 2009 12:31 PM
