Old Nov 18, 2012, 12:38 AM
RussellTate is offline
Find More Posts by RussellTate
RussellTate's Avatar
Sydney Australia
Joined May 2009
Mini-HowTo
How to make a Dumas shift lever in brass
After ordering an un-plated 1:8 scale Dumas Shift lever that arrived broken in two ...and reordering a replacement that also arrived broken in two,
I finally got one that was complete.
After filing sanding, cutting, and polishing I was preparing it for plating when it too broke in half.
So, I thought maybe I'll just try and make one myself out of brass, I know that won't break anytime soon.
I had some brass rod that was about the right size but couldn't figure out how to get the sides flat?
I hit on the idea of making a trench between 2 tiles and grinding the edges of the rod flat to the level of the tiles. It worked OK but was a little bit lumpy.
Next I put a sleeve over the area that was going to be the handle and jacked it in the pillar drill so I could get a nice hard edge on the handle before it went into the flat area.
Once I had that under control I put 2 needle files in a vice and pushed and pulled the brass rod back and forth till i got the flat sides nice a level
(I turned them over periodically to keep both sides even)
When everything was true I Dremel-ed off the top of the handle in roughly the right spot and rounded the top with a sanding disk.
After a rubbing with sandpaper (400 gridt up to 2500) I polished it with rouge compound and it came out looking pretty good.
I won't cut the bottom of the lever off until after plating as it will give me something to grip hold on to when i'm going through the process.
Hope this is of some use if you feel like making a lever yourself!
RussellTate is offline Find More Posts by RussellTate
Old Nov 18, 2012, 10:18 AM
oldtribefan is offline
Find More Posts by oldtribefan
oldtribefan
oldtribefan's Avatar
United States, GA, Kennesaw
Joined May 2007
Interesting solution to the problem. Your mini how-to's are great - keep them coming!
oldtribefan is offline Find More Posts by oldtribefan
Old Nov 18, 2012, 10:20 AM
Gravman is offline
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Very nice! That was clever to use the files in a pair like that. I have never seen that before. It sure came out great. I have always enjoyed watching metal work. Thanks for taking the time to post and share.
Gravman is offline Find More Posts by Gravman
Mini-HowTo Making parts in brass + Plating RussellTate Scale Boats 10 Nov 11, 2012 11:37 PM
For Sale GWS Naro JR/Airtronics Shift Receiver Make Offer AZcrashpro Aircraft - General - Radio Equipment (FS/W) 0 Sep 19, 2012 05:49 PM
For Sale Dumas #3112 3 bladed brass propellers mike wiese Boats (FS/W) 0 Aug 10, 2012 01:27 PM
Question How to make an airfoil in speed position? soholingo Hand Launch 2 Apr 23, 2012 08:23 AM
