Old Nov 17, 2012, 10:57 PM
Biggz is offline
Find More Posts by Biggz
Joined Jul 2012
Removable Verticle Stabilizer
Does anyone have a good method for making a removable verticle sabilizer on kit builds (balsa) so transportation in an RV is easier than the bulky configuration of all tail feathers in place? The kit I'm building (an EVA Bipe) doesn't allow for the horizontal stabilizer to be removable as I have done on other planes..
Any ideas????????
Biggz is offline Find More Posts by Biggz
Old Nov 18, 2012, 05:02 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You could use piano wire into tubes for removable surfaces, basically the same as removable plug in wings, but at a smaller scale.
The limitation for removable horizontal and vertical stabs is having to disconnect any control, elevator, rudder, etc, each time.
I have built a few models with removable surfaces simply to aid transporting. You just need to decide how to arrange the control links for easy removal if required. I have also had a few models with all-flying horizontal stabs to eliminate the control link problem.
A vertical stab would be the same.
eflightray is online now Find More Posts by eflightray
Old Nov 18, 2012, 09:07 AM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Go to 'scale sailplanes' forum in the '1/6 scale 1932 BS2 Balestruccio' thread p2, entry #17. Shows how to make removable stab-elevator. Otherwise mount rudder on brass tubes and have pull-pull with clevis to detach from horn for rudder removal. You can use same method to secure rudder as done on stab of Balestruccio.
ARUP is offline Find More Posts by ARUP
Old Nov 18, 2012, 09:41 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Typically a lot of the inspiration for the optimum method comes from looking at the plans and structural details. Otherwise it's too easy to suggest options which simply are not easy to execute.
BMatthews is offline Find More Posts by BMatthews
Old Nov 19, 2012, 01:34 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Nice buildlog! Lots of interesting innovations.
Especially the tail fixings
http://www.rcgroups.com/forums/showthread.php?t=1602512
rick.benjamin is offline Find More Posts by rick.benjamin
Old Nov 21, 2012, 02:08 PM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
+1-mr. Matthew's statement,although disengaging a rudder can hardly be any worse than the wings ! Two rods in the rudder,two recievers in the fuse,plug in a servo lead-Bazinga !
I had a 12' Connie that released the entire empennage.,which had a receiver,switch, battery and servos all contained inside.Four plywood 'tongues' inserted into sockets in the fuse.-4 nylon bolts,and turn on the switch=ready to fly. Ha! I could range check it,off the airplane !
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Nov 21, 2012, 10:38 PM
kwmtrubrit is offline
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
Go to the Sailplane threads and look for, "planepainter." He built a RIser 100 and make a bloody good job of removable tail feathers.
kwmtrubrit is offline Find More Posts by kwmtrubrit
Old Nov 23, 2012, 07:56 AM
ARUP is offline
Joined Mar 2010
I agree but I know what this airplane looks like and would never recommend a method if it didn't suit the airframe in question.
Black Verticle IPhone Charging Port palomo Non R/C Items (FS/W) 0 Nov 04, 2012 01:02 PM
Discussion trouble removing the stabilizer bar -- mx400 BOING Mini Helis 2 Dec 31, 2006 08:06 PM
Anhydral stabilizer w/forward position verticle... Spaaro Modeling Science 2 Aug 23, 2003 03:14 AM
Lite Stik-What is best way to make removable stabilizer? Ron MIller Parkflyers 4 Jul 02, 2001 01:23 PM
