Old Nov 17, 2012, 04:04 PM
in the beginning...
bm2thirsty's Avatar
United States, IL, Belleville
Joined Mar 2012
Reasoning for a Micro motor running slow?
Champ motor isnt running at full rpm's, barely wants to get off the ground on a full battery, what do i check or do here? Is it common? While holding it, it feels smooth and seems ok, I replaced the prop for a more balanced one,just not fast enough
thanks
boats
bm2thirsty is offline Find More Posts by bm2thirsty
Old Nov 17, 2012, 04:34 PM
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Sounds typical of a motor crapping out. These motors are hit and miss with some lasting a really long time and others not so long. The good news is they are cheap and easy to replace plus you can upgrade to the T-28/P51 motor which will make the Champ scream.
ForsheeMS is offline Find More Posts by ForsheeMS
Old Nov 17, 2012, 04:40 PM
in the beginning...
bm2thirsty's Avatar
Joined Mar 2012
hmm, ok time to do some research then. thank you
boats
Old Nov 17, 2012, 04:44 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
What batteries are you using, how old are they and how cold is it there?
Since Winter is coming, there is going to be lots of threads that say "my Champ/T-28/Etc doesn't have any power/shuts off early/pulses".
The answer is Batteries. Lipo's don't work in the cold and they don't last forever. 6 months is a lifetime for a 1S micro battery and 55 degrees or below will shorten flying times considerably.
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Nov 17, 2012, 05:37 PM
Joined Sep 2010
Don't get mad at me for asking - but is the replacement prop the same length and pitch as the original and have you checked to make sure it's on the right way?
bobly is online now Find More Posts by bobly
Old Nov 17, 2012, 07:20 PM
in the beginning...
bm2thirsty's Avatar
Joined Mar 2012
I will double check the prop if its on the right way honestly didn't think about that when putting it on, but it is the stock replacement,.. Its for sure not the batteries, after having issues I took em out and flew the p-51 around with em, tried 3 different batteries, same results.
Old Nov 17, 2012, 07:54 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If the batteries fly a P-51, its definitely not the batteries. A new 4 site motor is a good swap. these are usually cheaper than a mustang motor, but the same spec.
P/N EFL9052
Old Nov 17, 2012, 08:02 PM
in the beginning...
bm2thirsty's Avatar
Joined Mar 2012
Is it just as simple as swapping motors? Or are the gears etc..gonna need replacing also. If I used either a p-51 or 4 site motor?
Old Nov 17, 2012, 08:05 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
You just twist the old motor out and the new one in with needle nosed pliers.
Gears and plugs are the same. Mustang and 4 site motor wires are longer so they are easier to plug into the brick.
Old Nov 17, 2012, 08:57 PM
Joined Sep 2010
Assume you know this, but numbers on the prop go to the front, plane will still try to fly if prop is on backward, but have no power.
Old Nov 17, 2012, 11:06 PM
in the beginning...
bm2thirsty's Avatar
Joined Mar 2012
The prop is/was on properly, so i'm just gonna take it apart see if anything pops out at me, if not then i guess its time for a new motor...
@ungn, just to verify, this is the motor that you said will work without changing anything around correct? is that a stronger motor then the stock champ? or bigger?
http://www.amainhobbies.com/product_...FQeDnQodmXYA3Q
thanks for the help
boats
Old Nov 17, 2012, 11:27 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
thanks for the help
boats
The Motor is the Same size as the Champ motor, just more powerful.
You should be able to get one for about $11 shipped. If A-main has free shipping that is about the right price when ordering a single motor.
Old Nov 18, 2012, 12:00 AM
in the beginning...
bm2thirsty's Avatar
Joined Mar 2012
perfect, thank you
Wanted Trade my mCX2 for slow micro plane Brian VT Aircraft - Electric - Micro & Indoor Airplanes 3 Sep 05, 2012 10:03 PM
Found Looking for an OverSky XP12A HS for 120 size CP Micro running an HP08-2 motor HeliFlyer711 Aircraft - Electric - Helis (FS/W) 2 May 09, 2012 02:27 PM
Help! BLDC Motor, running slow Astiolo Power Systems 3 Apr 29, 2012 12:24 AM
Help! Thoughts on a Reasonably Priced ESC for a Springer Running a Graupner 700? Kcal Scale Boats 3 Dec 09, 2008 12:42 PM
Discussion How much power do I need to run a Slow stick for AP (motor size)? MikeOfAtlanta Aerial Photography 10 Sep 22, 2008 08:08 PM
