Old Nov 17, 2012, 02:59 PM
Endolf is offline
Find More Posts by Endolf
BMFA Heli Examiner
Endolf's Avatar
United Kingdom, England
Joined Nov 2012
HK550 FBL servos
Hi
I'm in the process of build an HK550 FBL, I've got a second hand beastx and I've got a hobbywing 100a ESC and CC BEC Pro. The next item I'm thinking about is servos.
The DS610s are undoubtedly good servos, but pricey. The Align 700 comes with DS615s and are not that much torquey than the 610s, so I wonder how much torque the 550 really needs.
So, what servos would be good for the 550 FBL?, what servos have people tried?, any that I should rule out?
Turnigy, or at least items from HK would be handy, I need to orders some 450 parts after I tried drowning mine in a stream
Endolf
Endolf is offline Find More Posts by Endolf
Old Nov 17, 2012, 03:41 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I have BLS 451s in mine but I know these are a short servo and will fit with no probs
Gaz-b is offline Find More Posts by Gaz-b
Old Nov 17, 2012, 03:48 PM
Endolf is offline
BMFA Heli Examiner
Endolf's Avatar
Joined Nov 2012
Hi
Thanks, what do you mean by a short servo?, do you have any experience of those ones?, or heard anything specific about them?, just trying to get as much info as I can before splashing out on anything.
Endolf
Old Nov 17, 2012, 04:51 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
I'm running Hyperion DS20FMD's on my cyclics and a DS20GCD on the tail on mine. Good fast accurate high torque servos and available from Robotbirds right here in the UK.
Paul 1968 is offline Find More Posts by Paul 1968
Old Nov 17, 2012, 06:19 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Originally Posted by Endolf View Post
Hi
Endolf
the base to lug height is short most servos need spacers between the frame and the servo mounting lugs to stop them needing to occupy the same space in the centre of the frame. on my bls 451s I have two plates under each servo and they just touch each other.
Old Nov 17, 2012, 06:23 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
the link I gave is also UK stock.
Old Nov 18, 2012, 01:33 AM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Just an alternative Gaz, the Turnigys look fine and are actually cheaper too. If I had not already had my servos I would have probably bought the ones you have linked to.
Paul
Old Nov 18, 2012, 02:09 AM
Endolf is offline
BMFA Heli Examiner
Endolf's Avatar
Joined Nov 2012
Thanks for the replies so far. The turnigy servos are faster than the DS20FMD's but not as strong, they are 10.5kg and 0.09sec v.s. 16.4kg and 0.13sec, the DS610 are 12kg and 0.08sec. As I don't think all of the torque of the 610s is needed on a 550 I think the Turnigys for cyclic are looking pretty good.
What servo are you running on the tail?, Paul mentioned the DS20GCD.
Endolf
Old Nov 18, 2012, 03:33 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Before I fitted all brushless servos I was using this.
I had no issues with it and it worked perfectly I only changed them because I like the Heli so much I swapped the kit over from another machine.
Old Nov 18, 2012, 03:54 AM
Endolf is offline
BMFA Heli Examiner
Endolf's Avatar
Joined Nov 2012
So 3 TGY-1257TG on the cyclic and the HK47110DMG on the tail sound like a good mix?
Do those all run at 1520u 333mhz?
Endolf
Old Nov 18, 2012, 08:39 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
1520 is just the centre pulse so pick the closest spline and then subtrim on the frequency I don't know I would expect them to but they don't state what it is.
Old Nov 20, 2012, 06:23 AM
Endolf is offline
BMFA Heli Examiner
Endolf's Avatar
Joined Nov 2012
Just ordered 3 TGY-1257TG on the cyclic and the HK47110DMG. That just leaves batteries and motor to be decided
Endolf
Old Nov 20, 2012, 01:43 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
I am using these in both a 600 and a 700 size scale bird with great results , they are super fast and smooth so they work well with FBL units.
Unfortunately they ar out of stock currently.
http://www.hobbyking.com/hobbyking/s...dproduct=10966
cap231ex is offline Find More Posts by cap231ex
Old Nov 20, 2012, 02:52 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
unfortunately at 29mm they would need a shed load of spacers on a 550.
Old Nov 22, 2012, 02:24 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Endolf
You probably won't be running the cyclic servos at 333Hz. what controller will you be using? The ZYX runs cyclics at 110Hz, and BeastX has options up to 200Hz.
2Doggs is offline Find More Posts by 2Doggs
Discussion HK550 or indeed any 550e clones hedgeheli Large Electric Helis 6 Jan 03, 2014 04:29 AM
Rave Hk550 tt fbl Paul 1968 Large Electric Helis 322 Jun 14, 2013 01:43 AM
Sold Align Trex 500 pro FBL airframe with servos and FBL unit HD Hucker Aircraft - Electric - Helis (FS/W) 2 Aug 31, 2012 02:38 PM
Discussion New hk550 Foam boy Large Electric Helis 2 May 25, 2012 12:48 AM
Sold Align 450 Pro V2 FBL Super Combo kit less Servos and FBL unit. HD Hucker Aircraft - Electric - Helis (FS/W) 1 Apr 18, 2012 11:08 AM
