Old Nov 17, 2012, 02:27 PM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Mini-HowTo
Pivot Cut by Tailwind Gliders
Tailwind Gliders is offering a FREE 12-minute instructional video on cutting highly tapered wing cores using a Pivot Cut method.
This is a 618Meg download. It is in a zipped .mp4 file format.
Download here:
http://www.twg.tailwindgliders.com/TWG/Pivotcut.zip
To learn more about Cutting and Bagging Foam Wings or making Composite Pod and Boom Fuselage's please visit here for more details and Sales.
Comments are always appreciated.
Curtis Suter
www.TailwindGliders.com
Curtis Suter is offline Find More Posts by Curtis Suter
Old Nov 17, 2012, 05:25 PM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
heliwill10 is offline Find More Posts by heliwill10
Old Nov 25, 2012, 09:12 PM
MarkRebuck is offline
Find More Posts by MarkRebuck
Joined Oct 2006
Nice! I tried your method while cutting some DLG tails today. Your method was every bit as effect as my method, but easier to set up... which surprised me, because I didn't think my method could have been any more simple.
MarkRebuck is offline Find More Posts by MarkRebuck
Old Nov 29, 2012, 06:29 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Really like your video, Curtis!
As you know I've been cutting foam for a long time and am always looking for new ways! Just love yours! Even us old dogs can learn new tricks!
If you guys don't have his videos, they are money well spent ! And this one is a freebie!
Thanks and Blue Skies........................Tim
RWCLOUD is offline Find More Posts by RWCLOUD
Old Dec 06, 2012, 08:37 AM
Red Merle ALES
Joined Apr 2002
It's building season in the Northern Hemisphere so don't forget this may be useful to you. It's FREE!
Curtis
Old Dec 16, 2012, 12:38 PM
Red Merle ALES
Joined Apr 2002
reserved
Old Jan 24, 2013, 10:50 AM
Red Merle ALES
Joined Apr 2002
http://tailwindgliders.com/Tips.html
Curtis
Old Mar 03, 2013, 01:17 AM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Got a chance to try this tonight.
According to your foam calc sheet, I needed a longer bow for the cores I need.So I dug out the first bow that I ever made way back in 1978! And updated it to my current design. Been wanting to do this anyway and for a long time.
Since I like wooden style legs and a Spanish windlass tension system , I needed a slightly different pivot system. No problem a piece of tubing was hiding out near the workbench and kept saying " use me!" so I did. Just cut a slot in it for the wire to nest in and the leg rests on the workbench surface, Just fine!
The cores are 17.937 inch long , the root is 12 inch and the tip is 6.188 inch so your calce said the core needed to be 18.9 inches from the pivot point. And that is exactly where it needed to be!
The first cut was made, and I gotta say, not quite what I expected! Really? this thing is cutting this smooth? Then the top cut was made. Wow! is it really this easy? Proof of the pudding is lifting off the core beds!
NICE! Best tapered beaded styro cores that I have ever cut! Next the other wing half was cut, This time backward, just like in your video! Man this is too easy!
Thanks Curtis!
And Blue Skies.......................Tim
Old Mar 04, 2013, 10:46 AM
plane_tech is offline
Find More Posts by plane_tech
Theoretical balsa dust maker
plane_tech's Avatar
United States, MI, Kalamazoo
Joined Oct 2007
Curtis,
Another great video. I have tried this method a couple of times before, but I see where I was making my mistakes. Can't wait to try this out!
plane_tech is offline Find More Posts by plane_tech
Old Mar 09, 2013, 08:31 AM
Red Merle ALES
Joined Apr 2002
Tim,
Nice, very nice! Thanks for the kind comments and for sharing your excellent results.
Curtis
Old Mar 10, 2013, 02:39 PM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
One more little tip.
I cut several sets of these wings, but didn't figure this out until almost finished.
Put pieces of masking tape on the table where the blanks line up! DUH! Then lay each blank in the masking tape lines, guess that was to simple for me!
Blue Skies....................Tim
Old Mar 10, 2013, 03:45 PM
plane_tech's Avatar
Joined Oct 2007
Tim - I really like the design you used for the bow, but how to you adjust the tension? I have one similar to the one Curtis used in the video, but my tension always seems to be off and I can not seem to keep it constant so I am looking for an alternative idea.
Old Mar 11, 2013, 11:55 PM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
At the top of the bow a piece of winch line tied in a loop. The stick in the middle is twisted until enough tension is reached. This is called a " spanish windlass" and is quite springy! I can very easily break a wire with it! When the wire heats up, the spanish windlass maintains tension well. And it can easily be adjusted if needed.
The legs pivot on bolts through plywood plates glued and screwed to the cross bar.
After making my very first bow many moons ago, I thought I needed a Feathercut bow. Hated the thing, so I sold it, like wood more better!
Blue Skies......................Tim
Old Mar 12, 2013, 12:41 AM
plane_tech's Avatar
Joined Oct 2007
Thanks Tim.
I see a new tool in my future...
Discussion Tailwind Gliders ALES Scoring Spreadsheet Curtis Suter Electric Competition Soaring-F5J/ALES/e-Soaring 38 Jun 04, 2015 08:27 AM
Discussion Tailwind Gliders New Tips Page Curtis Suter Sailplane Talk 9 Feb 09, 2013 02:17 AM
Alert Tailwind Gliders DVD's now Available as Download! Curtis Suter The Builders Workshop 2 Aug 26, 2012 07:13 AM
Wanted Tailwind Gliders DVD's artasb Aircraft - General - Miscellaneous (FS/W) 2 Aug 26, 2012 07:11 AM
For Sale RCA Handlaunch & Tailwind gliders DVDs Dani123 Aircraft - Sailplanes (FS/W) 3 Jun 28, 2012 10:20 AM
