Old Nov 19, 2012, 04:44 PM
Chris Lee
St. Louis, MO
Joined Oct 2005
Z06 Tony,
Yes! Very nice platform you built there. And running 6s, very cool, I take it those MT motors are working well for you? I was leaning toward the Avroto 2814 on 4s that I saw you also carry. I'm sure you've got a very happy customer.
So, are you running the same blade pitch on all the motors, or did you vary the pitch on the lower props? And if so, did you go through a phase of trial and error or more the TLAR method?
Chris
lineofsight is offline Find More Posts by lineofsight
Old Nov 19, 2012, 09:14 PM
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Originally Posted by lineofsight View Post
I question the notion that a Y6 configuration is "half" as efficient as a standard hexacopter, can you offer some evidence for this claim?
No one would be doing Y6 conversions of the DJI F550 frame (or making Y6 configurations at all) if that were the case; 50% efficiency is a major loss for an aircraft propulsion system where power-to-weight ratio is at a premium. I've seen numbers reported from 10-40%, but no indication if any optimization was done for "balancing" the motor thrust between each coaxial pair. Hence this thread.
I'm willing to do the tests myself, as long as some of the experts out here can verify my logic that there should be a connection between amp draw and a "balance of powers."
yes. Bambucopter quad and bambu copter y6 frame. Exact same motors, props, escs. 7 minutes vs 12
daign is offline Find More Posts by daign
Old Nov 19, 2012, 11:17 PM
Chris Lee
St. Louis, MO
Joined Oct 2005
Thanks for your thoughts, 7/12 is a 42% efficiency loss, right on the high-side of what I've heard. Not really the scale I'm looking at though.
Also, you didn't vary prop pitch, which is what this thread is about: determining how much more prop pitch is best for efficiency. It's a foregone conclusion that increased pitch on the lower motor is necessary.
I will try some tests with an amp meter and see if I can learn a bit more about how the two ESCs and motors work in combination. I've considered building a thrust meter as others have done, but that gets a bit more complicated/time consuming than I really wanted.
Chris
Old Nov 19, 2012, 11:33 PM
daign's Avatar
Joined Feb 2011
Very true...
One of these days maybe I'll try a heavy lift Y6. I still have those avroto 2814s I bought a while back from you. I just haven't found an airframe worthy of them yet.
Perhaps my Flyduspider or a rusty frame.
-D
Originally Posted by Z06 Tony View Post
I am assuming he wants to build a camera ship not a micro Y6.
Big difference.
Your Y6 is loud as you are prolly running 5" props with 2000kv motors.
As far as efficiency its def not 50% with a typical Y6.
I have built many Y6's and they are my favorite platform for AP.
They cut through the wind better than a flat hex.
Here is 1 I just finished for a customer running 6s spinning 14" props.
I dont think its loud at all
http://www.youtube.com/watch?v=g9ieKB_bz-Q
http://www.youtube.com/watch?v=_KZNs10KQrE
Old Nov 20, 2012, 02:33 AM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Z06 Tony,
Chris
Yes same pitch/prop size top and bottom on every Y6 and X8 I have built.
I have yet to see "proof" that a coaxial setup will fly any better with different size/prop pitch for upper and lower.
I am 100% confident that if I put 2 exact same coaxial setup in the air and 1 had all the same props and 1 had diff prop pitch on the bottom you would never ever tell the difference.
If this is true is it really worth the effort worrying about it?
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Nov 21, 2012, 12:18 AM
Chris Lee
St. Louis, MO
Joined Oct 2005
If it were true, then the answer would be no.
But I don't know that for sure. I hope to know more after some experiments.
Discussion Coaxial configuration prop directions IconFlyer Multirotor Talk 0 Sep 11, 2012 06:39 PM
Question Magnetic prop balancer, questions about balancing hubs RknRusty 1/2A Planes 13 Mar 25, 2012 11:07 AM
For Sale Various Props and prop balancer Dr. J Aircraft - Electric - Power Systems (FS/W) 0 Mar 12, 2012 08:00 PM
Off Site DuBro Micro Servo Arms, Micro Servo mounts, Hitec gearset, Great Planes prop balance Scirocco14 Aircraft - Electric - Micro & Indoor Airplanes 2 Jan 12, 2010 09:54 AM
APC SF 9x7.5 prop balance/mount issues? sbmon Power Systems 12 Oct 03, 2005 10:50 AM
