This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Nov 17, 2012, 01:30 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
Servocity pan/tilt notes
It's an extremely heavy duty machined, high quality camera mount. It has potential mounted on a heavy duty tripod for making panoramas, but it's not precise enough to make timelapses or aim a telescope.
After some shock at the lack of potentiometers for determining the angles, it turned out the servos are multi-turn winch servos & the gears are designed to convert the complete range of the servos to exactly 1 360' turn.
They take the standard 50Hz 1ms-2ms servo PWM. The servos turn quite slowly & there's a long delay, which means you'll need an IMU to know where it's pointed at any instant.
The $50 dual servo controller saves time in figuring out the protocol, but does nothing but generate PWM. There's no feedback from onboard position sensors. It has no voltage regulator.
Most of the cost goes to having it made in a strange country.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Old Nov 18, 2012, 06:09 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I looked at the pictures first before reading the text, and was thinking "Yeah. It's $45 because it's made in the US" when you nailed it with even a better description.
I've been following all your blogs with great interest. Keep 'em coming.
acetech09 is offline Find More Posts by acetech09
Sold ServoCity SPT-200 Pan/Tilt Setup healthyfatboy FPV Equipment (FS/W) 4 Oct 20, 2012 03:20 PM
Yippee! ServoCity Pan & Tilt Sale - 15% off select kits ServoCity ServoCity.com 0 Jul 16, 2012 03:50 PM
Sold ServoCity Pan & Tilt $10 pedantik FPV Equipment (FS/W) 2 Nov 07, 2011 11:01 PM
Cool Video of ServoCity SPT200 Pan & Tilt System ServoCity ServoCity.com 0 Sep 12, 2011 02:20 PM
Discussion NEW Pan & Tilt System from ServoCity Tech Aerial Photography 23 Jul 26, 2007 07:53 AM
