Closed Thread
This thread is privately moderated by bobepine, who may elect to delete unwanted replies.
Old Dec 30, 2012, 11:18 PM
Registered user
Joined Jun 2011
Trader Rating: 140
Originally Posted by nerwin View Post
As per my email, I'd like to order:
2 x CNC 355's w/anodized center plates
2 x Spare arms
You're on the list, Sir.
Thank you.
Best,
Chris
bobepine is offline Find More Posts by bobepine
Old Dec 31, 2012, 12:09 AM
United States, TX, Spur
Joined Sep 2011
Trader Rating: 2
Chris, Without the hard case, the Hero2 HD GoPro is 42mm tall by 60mm wide by 30mm thick.
The GoPro 3 as best as I am able to tell since I don't have one is the same but only 20mm thick.
Thurmond
T3PRanch is offline Find More Posts by T3PRanch
Old Dec 31, 2012, 12:12 AM
Registered user
Joined Jun 2011
Trader Rating: 140
Thurmond
This information is incomplete and does not qualify for a free sample.
Thank you.
Chris
Old Dec 31, 2012, 12:15 AM
Joined Sep 2011
Trader Rating: 2
Thank you.
Chris
That is OK since I don't have the money to buy a GoPro 3. You at least have the GoPro 2 measurements from my own.
Still I am certain that the GoPro 3 dimensions will be correct when someone with one responds.
Thurmond
Old Dec 31, 2012, 12:46 AM
cmeisteriii's Avatar
United States, NV, Carson City
Joined Jun 2012
Trader Rating: 3
HI CHRIS
HERE ARE THE DIMENSIONS AS REQUESTED
The cameras have dimensions of 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm) (HERO2)
HERO 3 Dimensions: 2.30 x 1.55 x 0.08 inches GOT THIS FROM FOLLOWING LINK
http://gizmodo.com/5959046/gopro-her...ss-fixer-upper
cmeisteriii is offline Find More Posts by cmeisteriii
Old Dec 31, 2012, 01:29 AM
Sky Surfer
itsme1's Avatar
Ferndale Wa
Joined Apr 2009
Trader Rating: 7
Thought I'd share this with you guys, i just received a 808 #16 keychain cam for FPV flights with my HK Bixler and i hooked it up to receiver on the quad, it shows a lot of promise, here is short vid of it.
MINI0007 (0 min 32 sec)
itsme1 is offline Find More Posts by itsme1
Old Dec 31, 2012, 01:31 AM
Sky Surfer
itsme1's Avatar
Ferndale Wa
Joined Apr 2009
Trader Rating: 7
Here is fpv footage of today's flight, enjoy!
Bixler 2 808 #16 keychain cam FPV (2 min 45 sec)
Old Dec 31, 2012, 10:42 AM
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Trader Rating: 2
Originally Posted by kapteinkuk View Post
This is new for me. My design have 45mm hole spacing. HK did ask me to use 44mm but I said no because it breaks the current standard of 45mm. I know some older designs used 44.something mm, (mikrokopter?) but as far as I know, new designs use 45mm. Also all frames I have seen uses 45mm.
So they changed it without telling me. Not good. I does not know what their obsession with 44mm is.
This partially clears me of the "traces to close to hole" problem, see pictures below.
You can drag the holes outwards a bit to get 45mm, no problem. There is no traces in that direction.
Chris,
have you noticed the change in the hole spacing on the KK2 boards? Is there sufficient oversize in your center plate FC mounting holes to shift the spacers enough so it doesn't matter?
cheers,
Andrew
Banjo5 is online now Find More Posts by Banjo5
Old Dec 31, 2012, 12:37 PM
Joined Sep 2011
Trader Rating: 2
Originally Posted by cmeisteriii View Post
HI CHRIS
Those hero 3 dimensions can't be correct. Look at the side view in the link you provided. .08" - 2.032mm thick, I think not!
I have e-mailed a friend with a Hero 3 and will get the correct dimensions.
Thurmond
Old Dec 31, 2012, 12:46 PM
United States, CT
Joined Mar 2011
Trader Rating: 20
@ Banjo5, he mentions adjusting the f/c mount bolts in the frame assembly video:
http://www.rcgroups.com/forums/showp...77&postcount=6
i used a vise to squeeze mine in a little, would have been nice if HK made the boards correctly.
adrenahelin is offline Find More Posts by adrenahelin
Old Dec 31, 2012, 01:08 PM
Registered user
Joined Jun 2011
Trader Rating: 140
Hi,
This was valid for V1 CNC plates. For V2 and V3 CNC plates, the FC fits dead on. I have corrected this beginning with the introduction of V2. Basically, the V1 were cut using my directions to use 45mm hole to hole but this did not work perfectly. For V2 and V3, I gave a KK2 board to the CNC factory to copy the hole pattern perfectly and they did. I still use the same video for frame assembly instructions but it's to show how the frame goes together only. The holes will line up and no need to adjust anything. I guess I need to put together a new frame assembly video.
And no, I have not noticed any changes on the KK2 in terms of holes spacing.
Best,
Chris
Old Dec 31, 2012, 01:12 PM
Cotton-Headed Ninny-Muggins
Creepy1's Avatar
Canada, ON, Kapuskasing
Joined Mar 2012
Trader Rating: 6
Put together a little something to help against my obsession with french kissing the ground. On another note I've now reached 60 in stick handling. YAY!
Creepy1 is offline Find More Posts by Creepy1
Old Dec 31, 2012, 01:19 PM
Joined Sep 2011
Trader Rating: 2
I LOVE pool noodles. I never fly without them.
Thurmond
Old Dec 31, 2012, 01:49 PM
Creepy1's Avatar
Joined Mar 2012
Trader Rating: 6
Thurmond
Yup, I know what I'll be buying come summertime!
Old Dec 31, 2012, 02:06 PM
Registered user
Joined Jun 2011
Trader Rating: 140
http://www.youtube.com/watch?v=-ntfS...ldi_xQmmFfybJQ
Awesome video clarity for a keychain. Nice video. I think you have the record for the highest altitude with an Armattan quad. It's WAY up there for a while. Well done. That looks like a lot of fun.
Best,
Chris
Closed Thread
For Sale Armattan Quads Announcement: Upgrade Parts bobepine Aircraft - Electric - Multirotor (FS/W) 16 Oct 13, 2012 12:07 PM
Sold RX Ready Custom Sports Quad: Armattan 362 bobepine Aircraft - Electric - Multirotor (FS/W) 9 Sep 24, 2012 01:24 PM
Sold Open Pilot CC quad with aluminum Frame/ leds.Update listing 18 Jan price lowered tc3wins Aircraft - Electric - Multirotor (FS/W) 8 Jan 18, 2012 07:35 PM
Sold Quad frame for sale!!! previously listed. as full quad. tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Aug 25, 2011 08:56 AM
