This thread is privately moderated by bobepine, who may elect to delete unwanted replies.
Old Dec 22, 2012, 09:48 PM
Banjo5 is offline
Find More Posts by Banjo5
Trader Rating: 2
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Trader Rating: 2
Change to 2822-12 1800kv motors?
Originally Posted by N3SHXX View Post
Andrew, I went with the "RCX 2822-12 1800kv motors", amazing power, smooth and I am getting at least 10 minutes time with just the cheap Zippy HK 2200mah 20c batteries.....!!!
Hey Chris,
apologies in advance, but is it too late to change the motor choice for my CNC355 DIY kit to these ones (RCX 2822-12 1800kv)?
The more I think about it, I think they're a better match for the kind of flying I'll be doing for quite a while to come.
If it's too late, then that's OK.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Dec 22, 2012, 10:17 PM
T3PRanch is offline
Find More Posts by T3PRanch
Trader Rating: 5
Team Armattan
United States, TX, Spur
Joined Sep 2011
Trader Rating: 5
Originally Posted by Bryan's Flyin View Post
C'mon Man!!!! At least email me a pic! You killin' me over here!
+1 for sure Chris. Hex is GOOD!
I was about to e-mail you to ask about a Hex center plate and cost of 2 extra arms for Brian's first design. Now I am glad I did not order the first Bryan frame yet.
Thurmond
T3PRanch is offline Find More Posts by T3PRanch
Old Dec 22, 2012, 10:56 PM
Ayodhya is offline
Find More Posts by Ayodhya
Trader Rating: 1
WRX STI V - EJ22 - 35.3 PSI
Ayodhya's Avatar
Malaysia, Selangor, Puchong
Joined Nov 2012
Trader Rating: 1
Hey quick question folks, I'll be running the 2826 motors 30amp escs... In time to come. Yall think I should get a set of extra 7 inch props too? That way I'll have 8 and 7 inch props.
U think I'll get more flight time with those? I mean I can always switch when it Fancys me, i.e if I need a longer flight time...
Cheers
Ayo
Ayodhya is offline Find More Posts by Ayodhya
Old Dec 22, 2012, 11:03 PM
Ayodhya is offline
Trader Rating: 1
Ayodhya's Avatar
Joined Nov 2012
Trader Rating: 1
I believe you to be exactly right about the cooling effect of the alumi against the esc.
I have come to believe that the natural cooling effect of the prop wash against the metal and the actual esc itself is beneficial for cooling the esc's as most metals will retain the ambient temperature and the rotors blowing down on the arms which should cool them down somewhat and that would be transmitted to the esc via proximity. That said, I wonder if removing the shrink wrap on the esc's opens it up to more damage in a bad crash, ie blade strike....or to moisture, causing a short. Or if flying in hot climates, will that heat from the sun be transmitted more easily through the alumi arms and affect the esc's? In this case, I would probably want to use white heat shrink to reflect the heat of the sun......
Personally, my next Armattan builds are going to be with shrink wrap removed and positioned on top of the CNC arms. There is a new spray coating coming out that will eradicate any moisture problems very soon.
Great comment, T3PRanch
Yea the new spray coating works fine... I have the Ar done and its spray coated and it works fine ..i.e all electronics... Still doesn't mean one should drop it off at the nearest lake or pond tho lol
Old Dec 23, 2012, 12:11 AM
Ayodhya is offline
Trader Rating: 1
Ayodhya's Avatar
Joined Nov 2012
Trader Rating: 1
Oh and u guys ( Bryan &chris BC) let us know how your BC fpv design is coming along my best to both u 2 geniuses ! Keep it coming lol
Ps- cant wait to see the video... Had a wet dream about the little orange/ black power house , hehe !
Old Dec 23, 2012, 01:20 AM
TayNinh68 is offline
Find More Posts by TayNinh68
Trader Rating: 0
Mosquito 6
Joined Jun 2012
Trader Rating: 0
Originally Posted by bobepine View Post
Thanks for the kind words,TayNinh68. I can't believe this thread has reached 50 pages already. I'm very flattered. And still, no major problems reported.
For that you are to be applauded Chris, and I sincerely wish for your continued success.
On a separate note, I have not had time to work on a FPV design yet, mostly because I'm a bit humbled at my lack of knowledge as to what needs to go on such frames, and where it needs to be positioned- This even includes the FC position on the frame.
Flattering others by emulating their designs is an international pass-time Chris, but typically the Forward orientation of the FC is between two legs, so that a fixed azimuth camera can look between them .. sound familiar .. lol. Lack of mounting area between your center plates (only 4mm) would need to be mitigated by creating an additional equipment layer .. most likely above your PD disc position. The FC should be on top layer, so the pilot can see diagnostic led's .. adjustment pots .. USB port etc. Then you have the Rx ,, Vtx, OSD stuff .. antennae .. GPS mast and other goodies that an individual builder may want to install such as separate Rx, Vtx, and camera/gimbal batteries. It's like going from a dirt bike to a swamp buggie
Now, that said, I have been working on something else. Bryan's Flying asked if I could put together a hexa design and I spent a couple hours at the CNC factory yesterday working with the boss on the drawing board. I put a very strong emphasis on keeping the design light this as to not need to redesign it again and again, and I think I have a final design that is simply awesome. Samples will be made this week and will be shipped to Bryan for testing next week. I have ordered two different sets; One using 1051 grade alumi, 1.6mm thick, and one using 6061 aircraft grade alumi, 2mm thick. The 2mm ones will be heavier but also incomparably stronger.
Now .. I've read all 50 pages, and one thing that stuck in my craw is your "1051" materials designation, so I guess it was not a typo. It is not a common designation here in the states excepting the 1xxx series which is basically pure unalloyed aluminum such as full-soft Aluminum 1100 "tinfoil". The 6061-T6 alloy can be effectively cold formed without effecting it's mechanical properties as long as minimum bend radius for a given material thickness is observed, and in your latest published application design, brakes (bends) should always be perpendicular to the grain. Heating is not necessary, and most likely deleterious.
I hope you are successful in going from 4mm to 2mm material thickness as weight is always a factor, but I expect some additional forming may be involved for rigidity; and if so, I suggest you prototype in both grain orientations for effects on rigidity. Still, even 2mm (0.080" here) weighs 1.13lbs (512.5 grams) per square foot .. that's gonna be challenging.
I don't actually want to show this design yet, not even to Bryan, because it's a surprise. That's how awesome the design is. I will be producing these frames if the demand is there for it, but I won't be selling them as RXR. I'll only be selling the frames. Stay tuned, guys.
Yep .. frames only .. good choice amigo. Builders can pick and acquire what they choose. No way you wanna finance an inventory of MT4008's for instance, at a hundred bucks a pop per rotor (motor and esc retail).
Best,
Chris
Wishing All Success
TayNinh68 is offline Find More Posts by TayNinh68
Old Dec 23, 2012, 07:35 AM
DbleX is offline
Find More Posts by DbleX
Trader Rating: 72
USA, TX, Corpus Christi
Joined May 2005
Trader Rating: 72
Chris, this is the beauty of the word FREE MARKET Society. You are challenging the majors, keeping a competitive price and providing a valuable service to your customers.
I actually am waiting for the FPV frame set up for a quad. Look whats out their and make it your own. FPV needs landscape and the board needs to be accessible. The TBF design is great, aka (flying squirrel or aka dead cat)
But then make it yours!
DbleX is offline Find More Posts by DbleX
Old Dec 23, 2012, 08:27 AM
bobepine is online now
Find More Posts by bobepine
Trader Rating: 198
bobepine's Avatar
Joined Jun 2011
Trader Rating: 198
Wishing All Success
You clearly know a lot more about metal than I do. That said, the boss at the CNC factory has been in the business for over 40 years. I have a feeling that if he wanted to use heat to make the squid arms, he had a good reason for doing so. Perhaps he just wanted to be on the safe side.
Anyways, you seem to be misunderstanding what parts use what metal, which is probably my fault for not writing this succinctly enough. The arms remain 4mm. And the center plates remain 1051 1.6mm. Just one extra set of center plates will be cut using 2mm 6061alumi.
Weight is always something I have to try to cut down and future releases will keep getting better in that department, though, at some point, reducing weight will affect strength too much so it's a matter of finding the right balance. One thing is certain, I'd rather build something that is slightly heavier than most models out there that use G10 and CF because that just breaks too easily. This is how this whole frame making thing started. I wanted to make something strong for myself because I was tired of breaking frames every second flight. So the idea is to use make up for the weight addition with the proper specs. Mind you, the 355 clocks in at only about 30 grams heavier than the Whartox frame. I also have a V3 version in the works for the Armattan CNC frame and I think I will be able to reduce the weight by about 25 grams while retaining very good strength. The idea is to remove metal wherever it doesn't add structural strength and this is where the difference will be made with the V3. This same idea is implemented on the new hexa design.
Stay tuned...
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Dec 23, 2012, 09:14 AM
Ayodhya is offline
Trader Rating: 1
Ayodhya's Avatar
Joined Nov 2012
Trader Rating: 1
And to everyone on this thread.....MERRY CHRISTMAS & A HAAAAAPPY NEW YEAR! :beer:!
Old Dec 23, 2012, 10:18 AM
Bryan's Flyin is offline
Find More Posts by Bryan's Flyin
Trader Rating: 34
United States, MO
Joined Apr 2009
Trader Rating: 34
Thank you very much for the kind words, but all credit should go to Chris. I just have had a couple of ideas I have written down while pounding some tall Crown & Coca Colas. So, all credit goes to Chris.
Chris takes my crude drawings and turns them into the final product and tweaks them into the beautiful works of iron you see today. He sent me a pic of the V3 center plates.........Holy SH*T!!!! They are SUPER nice!!
The spray coating I am talking about has not been released to the public yet, but let me tell ya...it's a game changer. In the company videos I have seen, they coat just the outside of an iPhone and then submerge it in a bowl of water and it keeps working UNDER water for over an hour with only the exterior of the phone being coated. I'll keep you guys posted with updates on the release.
This thread rocks, but only because of Chris and all you Armattan owners (and future owners) and contributors. A good, friendly thread where you don't get your head bit off for asking a question. Chris is a natural teacher and craftsman. He makes the people around him better through sharing his ideas and experiences with us. It just goes to show ya what we can do when we all work together!
Here is wishing you all a Merry Christmas and if you don't celebrate Christmas, I hope you have a good day anyway! PEACE
Bryan's Flyin is offline Find More Posts by Bryan's Flyin
Old Dec 23, 2012, 10:55 AM
Th3UmBrA is offline
Find More Posts by Th3UmBrA
Trader Rating: 40
AMA# 980507
Th3UmBrA's Avatar
United States, FL, Loxahatchee
Joined Feb 2011
Trader Rating: 40
This coating company wouldn't be Liquipel?
Th3UmBrA is offline Find More Posts by Th3UmBrA
Old Dec 23, 2012, 11:19 AM
Trader Rating: 34
United States, MO
Joined Apr 2009
Trader Rating: 34
No Sir! Triple top secret!!
Old Dec 23, 2012, 11:22 AM
Ayodhya is offline
Trader Rating: 1
Ayodhya's Avatar
Joined Nov 2012
Trader Rating: 1
Hi Chris ,
Rated this thread !
I only wish it had more stars to vote on hehehe
Now,
A brief history on what happened to me here, might help new guys like me to understand how unique this gents services and altogether personality is:
To begin with , I didn't know and still don't know squat or least much on quads. I came here kinda worried that I might get jumped or blown off for asking stupid questions... Never happened.
From day one Chris has been an absolute pleasure to deal with... He's put up with a lot of my annoying questions, explained away a lot of questions.. And done so in a manner where even a noob like me would understand. What I've learned about him is simple, he doesn't over charge, very considerate, and even though hes modest about his knowledge in reality he really does know what he's doing. Pure genius. Don't take my word for it, just see how many of these babies he's pushed off. Also notice the lack of complains of his product by buyers. No complaints = great product.
As you scroll down further you can also see how dedicated he is ... I mean the guy is pretty much like on call for each and every one of us to help us.. And Iv noticed he does this to not only ppl who buys he's stuff ... But ppl who are just curious. To me that itself is the trait of a great builder ! Not only does his works of art perform like bats out of hell, but just watching he's videos itself will show u how dedicated this guy is. He's doing what he loves and is excelling in it ,in everyway.
For me Chris was the first guy I went for a quad, and to me he will also be the last person. I can see myself buying a lot more than just the cnc 355 in the future because Chris knows not only to sell great quads but also keep us coming back for more.. He does this with honesty and principle.
Ok I'm gonna shut up now, but before i do, it also helps to have ppl like Bryan, n3shxx,mrexx, creepy1, noahb and all of you who are so helpful to noobs like me. You guys, big thank you, y'all make getting into this hobby a true pleasure as it is meant to be.
Makes ppl like us wanna come just hangout in this thread cuz this place is too damn comfortable just not to.
So guys, newbies, pros, whoever you are, as far as this thread , the ppl in it and the quads that are built in here just wanna say two words to best describe them " TOP NOTCH"
All of you guys have a great season and my best to you all with nothing but the best wishes to you, your families and loved ones.
Best regards
Ayo
(Pronounced ah-yo) hehehe
Cheers gents !
Old Dec 23, 2012, 11:43 AM
rexless is offline
Find More Posts by rexless
Trader Rating: 2
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Trader Rating: 2
What a great love fest! LOL
My two cents, I agree with the rest of the folks. Chris built me a great quad and although I haven't yet flown it to it's potential I have flown it enough to know it is well built and its exactly what he promised it would be. I have no doubt that once winter fades I'll be flying like a bat outta hell.
The group on the forum are great as well. I know I'll learn a ton and hopefully contribute along the way!
Now to see if I can find a good place to fly... There's 20cm of snow everywhere I look...
rexless is offline Find More Posts by rexless
Old Dec 23, 2012, 12:04 PM
Ayodhya is offline
Trader Rating: 1
Ayodhya's Avatar
Joined Nov 2012
Trader Rating: 1
hahah rexless , yea the holiday season got me dang mushy ! sniff sniff, dammit my woman is gonna whoop my ass when she finds out i bought this , the hubsan x4 and the ar drone 2.0 ... oh well , whats life without flying
Discussion Armattan Quads Announcement: Upgrade Parts bobepine Product Announcements 20 Feb 27, 2016 08:07 AM
Sold RX Ready Custom Sports Quad: Armattan 362 bobepine Aircraft - Electric - Multirotor (FS/W) 9 Sep 24, 2012 01:24 PM
Sold Open Pilot CC quad with aluminum Frame/ leds.Update listing 18 Jan price lowered tc3wins Aircraft - Electric - Multirotor (FS/W) 8 Jan 18, 2012 07:35 PM
Sold Quad frame for sale!!! previously listed. as full quad. tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Aug 25, 2011 08:56 AM
