Old Nov 16, 2012, 10:25 PM
preelude is offline
Find More Posts by preelude
Canada, ON, Ottawa
Joined Dec 2011
Build Log
Airbus A319 | 1:20 Scale | EDF | Dollar Tree Foam
After watching Mike Neff's beautiful depron airliners on youtube and following demondriver's amazing builds I wanted to build my own for over a year now. With the recent introduction of Dollar Tree stores here in Ottawa, Ontario this is finally possible. I just picked up 25 sheets!
I decided to build an Airbus A319-100, although I am unsure of what livery I will use yet.
Here's what I have planned:
- 66.5" Length
- 67.0" Wingspan
- 8.0" Fuselage Width
- 2x 2650mah 3S batteries
- 2x EDF Systems (Unsure of what to use yet)
The plan is to make it as light as possible for scale flight, hopefully in the 3.5-4.5 lbs. range.
Any suggestions on EDF systems? Right now I am considering the EDF55 from HK: http://www.hobbyking.com/hobbyking/s...ed_199_8W.html
I already own one and the claimed thrust on 3S is 470g (16.5 oz.)
preelude is offline Find More Posts by preelude
Old Nov 16, 2012, 10:30 PM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Here is the progress so far. I started this morning but have been busy since afternoon, I am hoping to continue tomorrow and majority of Sunday.
Old Nov 16, 2012, 11:08 PM
WAGliderGuy is offline
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Looking great preelude, I am looking forwards to more sir! I see you are doing the narrower IAE tubines but are you sure 55mm EDFs at the scale you are building will have enough mmmph? I would personally go with 64 if not 70mm especially with the two batteries.
Nice work!
Ethan
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Nov 16, 2012, 11:27 PM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Nice work!
Ethan
Thanks Ethan,
Yes I am doing the IAE's, are they actually narrower or do they appear that way due to length?
So you say 64 or 70 huh? I think thats a good idea. Do you know what the E-Flite 777 uses for EDF's? Mike Neff seems to use that setup in a number of his airliners.
Peter
Old Nov 16, 2012, 11:40 PM
Airliner Builder
Joined Feb 2010
Originally Posted by preelude View Post
Thanks Ethan,
Peter
Peter,
I am just guessing they are narrower then the other CFM engines but I might be wrong. Depending on where you place the EDF though, the longer nacelle will take away some thrust.
Neff uses the E-Flite Delta Vs I believe but I prefer the newer (and much cheaper) AEO motor/fan combos or if you have a large budget the ChangSun fans with a compatible motor.
I just started building a 63'' Douglas DC-9 and I am going to use these 64mm AEO fans on a 3S. I have ran them up and I am happy with the balancing, plus the six blades (instead of the four on the E-flites) give a slightely more realstic sound.
Because the nacelles are wider (always a nice thing ) I recommend the 70mm 8-blade AEO fans. They give a realistic look with the number of blades and the sound in the long nacelle would definitely have some turbine flyers turn their heads.
There are a number of EDF options out there, I am still new to these type of propulsions systems so I stick to the combos
Ethan
Old Nov 17, 2012, 12:10 AM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Peter,
Ethan
Cool, just did some quick research on the AEO 70. Sounds awesome! Plus HB has them for $18.48.
Old Nov 17, 2012, 12:03 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Prelude . . . ..Where have you been Hiding your sweet A319? Looking Great!
Sub-Me-Up-Scottie!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Nov 17, 2012, 02:41 PM
3DFoamieFlyyer is offline
Find More Posts by 3DFoamieFlyyer
Closed Account
Joined Nov 2012
Btw at the larger fan sizes 50mm and up longer thrust tubes straightens the Efflux and makes it more efficient thus producing some more thrust
3DFoamieFlyyer is offline Find More Posts by 3DFoamieFlyyer
Old Nov 17, 2012, 04:02 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
Subbed
Good work so far
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Nov 17, 2012, 07:20 PM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Thanks guys. I'm really excited about this build.
Excellent news!
Old Nov 17, 2012, 07:22 PM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Worked on the canopy area today. Here's the progress so far.
What could I use as a putty to fill gaps that would be relatively lightweight?
Old Nov 17, 2012, 08:34 PM
Winter Is Coming
Joined Feb 2010
Looking good.
Find this at you local hardware store ( home depot, lowes ..)
http://www.homedepot.com/Paint-Patch...1#.UKhIPWt5mSM
Where are you located?
Old Nov 17, 2012, 08:48 PM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Originally Posted by Doushiyou12 View Post
Looking good.
Awesome. Thanks.
I'm in Ottawa, Ontario. I'm sure the local Home Depot has it as well.
Old Nov 17, 2012, 09:17 PM
Up-Out-&-Gone
Joined Mar 2007
Your A319 Nose looks great!. . . .. Very Nice work Preelude!
Old Nov 17, 2012, 11:01 PM
preelude is offline
Canada, ON, Ottawa
Joined Dec 2011
Thanks demon!
Question Foam question...Depron vs Dollar Tree Foam. Disco Stew Foamies (Scratchbuilt) 27 Apr 25, 2014 02:36 PM
Build Log A319 using dollar store foam rmackelvey RC Airliners (Commercial, Cargo, Troop Carrier) 126 Sep 02, 2013 03:42 PM
Discussion one sheet dollar tree foam board flying wing 63 nova The Builders Workshop 1 Mar 12, 2012 04:18 AM
Question Baking Dollar Tree Foam in a Jig ?? Wilfor Foamies (Scratchbuilt) 25 Feb 25, 2012 06:17 PM
German foam Airbus A319 - any experience or info available? Ben_E Electric Ducted Fan Jet Talk 5 Feb 21, 2003 05:07 PM
