Old Nov 16, 2012, 07:44 PM
aerografixs is offline
Find More Posts by aerografixs
aerografixs's Avatar
Canada
Joined Nov 2002
OMG servos
OMG SERVO REVIEW
After receiving some sample servos from OMG company of China, HDT064200C, and LDT062200B, coreless and brushless respectively, I unpackaged them and what I found were very nice , well engineered servos.
They both have aluminum center case anodized in green for better cooling, both have TG (titanium gears) for long lasting without slop.
The brushless servo example I received is of the low voltage variety, meaning 5to 6 volts, while the coreless servo is of the high voltage , 6 to 7.2 volts.
Both servos have 20 kg of torque and the speed is .18s/60 degree for the coreless and .07s/60 degrees for the brushless.
Now for the test.
First, the coreless “HDT064200C”, was set up for centering precision, and speed, on lipo battery.
The centering test showed repeated precision, to be as good as any I used or tested.
As for speed, it is as fast as claimed, but what I was amazed at, was the response time from the transmitter , again better then most I have seen.
Now for the Brushless “LDT062200B”, using lower voltage, of 6 volts .
The speed and centering is absolutely first class. But one thing I did notice, the brushless was much more quiet then the coreless, although the coreless was well within the noise level of other digital servos, and a bit more quiet then many.
For the not so good part:
The only thing I didn’t like was the servo wheels included , they are OK lower class servos, but I believe better servo arms should accompany these first class servos.
With this being said, most people using these servos will most likely go with after market arms…
I am now building a 55% Scale Pitts S2A and will be using these servos for controls…
OMG servo centering test (1 min 10 sec)
aerografixs is offline Find More Posts by aerografixs
Old Nov 18, 2012, 07:36 AM
omgsales is offline
Find More Posts by omgsales
omgsales's Avatar
Hong Kong, New Territories
Joined Aug 2012
Thanks,Roger!
Just wish you can enjoy it
omgsales is offline Find More Posts by omgsales
Old Nov 19, 2012, 08:04 PM
omgsales is offline
omgsales's Avatar
Joined Aug 2012
Thanks for Leonardo's video.
Wish you could enjoy it!
http://www.youtube.com/watch?feature...&v=PrN_L7y1xtE
Old Nov 29, 2012, 09:19 AM
omgsales is offline
omgsales's Avatar
Joined Aug 2012
Brushless Low Profile Digital Servo is Coming!
Item No. HDT045070B
Type Digital
Operating Voltage Range 6.0 -7.4Volts DC
Bushing or Bearing Bearing
Bearing Type Dual Ball Bearings
Speed (s/60░@6.0V/7.4V) 0.06/ 0.05
Torque oz./in. (6.0V/7.4V) 76/97
Torque kg./cm. (6.0V/7.4V) 5.5/7
Size in Inches 1.58 x 0.79 x 0.99
Size in Millimeters 40.2x20.1x25.2
Weight oz. 1.59
Weight g. 45
Motor Type Brushless motor
Control System +Pulse Width Control 1500usec Neutral
Required Pulse 3-5 Volt Peak to Peak Square Wave
Operating Temperature Range(F) 14░ - 122░
Operating Temperature Range(℃) -10░ - 50░
Idle Current 4mA/5mA
No Load Running Current (6.0V/7.4V) 300mA/400mA
Stall Current (6.0V/7.4V) 3200m/3900mA
Dead Band Width 2Ás
Potentiometer Type Rotating(Max.220░)
Connector Wire Length 11.8 in. / 300 mm.
Connector Wire Gauge 25 AWG
Connector Type JR
Gear Type Titanium gears
Shaft 6mm 25T
Old Dec 07, 2012, 11:53 AM
omgsales is offline
omgsales's Avatar
Joined Aug 2012
A new test of HMC065150I!
OMG Servos Test by AcroRC.com (6 min 27 sec)
Old Mar 02, 2013, 03:16 AM
omgsales is offline
omgsales's Avatar
Joined Aug 2012
That is Tony whiteside test of RC OMG's LDT025022C and LDT025025C.
Thanks for Tony's Test.
Camp hardcore and the compass atom 500 (3 min 46 sec)
Discussion RC OMG's Servo omgsales Product Announcements 26 Jan 07, 2013 01:46 AM
Discussion Omg samwei1950 Electric Heli Talk 3 Sep 21, 2012 12:31 AM
Poll OMG! Not another noob asking about PID tuning! MikeyToo Multirotor Electronics 1 Sep 06, 2012 01:11 PM
Alert !! OMG, Coal Industry uses "Stock" photos on website. OMG!!! F7X Life, The Universe, and Politics 6 Aug 27, 2009 09:17 PM
