Old Nov 16, 2012, 08:08 PM
Boris13 is offline
Find More Posts by Boris13
Joined Oct 2012
Possible to fly 2 (or more) helis simultaneously from one transmitter ?
I would be really interested to know if it's possible to bind 2 helis to the same channel and fly them simultaneously side by side from a single transmitter.
Would be equivalent to flying two stunt kites from one set of lines.
Does anyone know if this can be done ?
Boris13 is offline Find More Posts by Boris13
Old Nov 16, 2012, 08:28 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Not really possible to fly two heli's simultaneously. But it might be fun to try. Some 2.4ghz systems won't let you bind more than one RX to a TX but some others will though. You could also use 72mhz and use as many as you like then.
I do remember years ago a fellow used to build and fly a group plane using four separate Blue Angels jets attached together on a frame with the engine up front, using a diamond shape, he had the left plane be the left aileron and the right plane the right aileron and the rear plane was the elevator. When the setup flew it looked like it was four planes flying in tight formation. It was pretty cool like that too.
So you could tie the two or more heli's together on a common framework and then it would be much more doable for flying them in formation.
earlwb is online now Find More Posts by earlwb
Old Nov 16, 2012, 08:31 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
Define "heli" - 1 blade, coax, quad? Is a stabilization system allowed?
karlik is offline Find More Posts by karlik
Old Nov 16, 2012, 09:28 PM
Boris13 is offline
Joined Oct 2012
-You wouldn't happen to know if that's possible with the Walkera Devo transmitters by any chance ?
Old Nov 16, 2012, 10:18 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
On a 2.4 radio? Maybe if you use "Fixed ID" and use the same ID number on all your helicopters? Anybody with two walkera helis willing to give this a try?
I know two transmitters can't connect to the same helicopter. The binding process means the TX sends a unique ID number to the heli which the heli saves in memory and will ignore all other packets with the wrong ID. But the data protocol i saw doesn't actually specify an ID for the RX, only the TX, so the packet doesn't actually specify a destination. If you can manually set that ID and set it for all your heli's, maybe?
Hajile is online now Find More Posts by Hajile
Old Nov 16, 2012, 10:44 PM
Boris13 is offline
Joined Oct 2012
-yes that's exactly what i was thinking
I only have one devo 2.4G heli, otherwise I would have already tried it
Maybe somebody out there can test this for us
Old Nov 17, 2012, 12:30 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
If you have Futaba or something without ModelMatch, you can control two aircraft at the same time with the same signal. The receivers don't know there's another receiver turned on out there. With Spektrum you can do it with the micro stuff - you can defeat ModelMatch by binding two aircraft to the same memory slot of a Spek radio. ModelMatch simply uses a different ID for each memory slot - so, you're binding to a memory slot, not the radio as a whole. Futaba binds the radio as a whole.
So yeah, it is possible to have two aircraft listening to the same control signal. I've heard of a 700 electric flying off the table because of this - the person uses Futaba, and they forgot to unplug the battery of their 700E and they went out to fly their nitro, and sure enough, the 700E responded to the nitro's control signals just fine, and whomped itself off the table.
However, your question was more "can the same control signal fly two aircraft" and the answer is a definitive no. The problem is the two aircraft won't stay in sync with each other - one will get a wind gust that the other one doesn't get and from that point on, they're going in different directions - error would build up until one or both aircraft were in impossible attitudes.
Flying two aircraft at the same time with two radios has been done.
One Pilot Two Planes (3 min 11 sec)
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 17, 2012, 01:10 PM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
That.......
......is VERY impressive....
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Nov 17, 2012, 01:34 PM
Boris13 is offline
Joined Oct 2012
Originally Posted by jasmine2501 View Post
...So yeah, it is possible to have two aircraft listening to the same control signal.
- Sure they're just dumb robots we're flying really. So in theory it should be easy to trick them like this.
- Well if you had altitude + position hold on both helis you could switch that on to bring them back into sync with each other (if they get seriously out of shape). Then once re-synched, you could carry on flying 'em.
I suppose landing could still be a problem. Or just land one, unplug his battery, then land the other.
Old Nov 17, 2012, 04:23 PM
karlik is offline
Closed Account
Joined Apr 2010
[QUOTE=Boris13;23292837
[/QUOTE]
That's what I asked earlier. I think some of the multi rotor stuff and stabilization systems just might make it possible - as long as you don't expect any fancy flying.
Old Nov 17, 2012, 06:19 PM
ewoodcox is online now
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
I saw a guy in our local gym fly two vapors at the same time, they started out in sync and slowly drifted appart until it became impossible to keep one of them from bumping into something I bet that would happen fast on a heli
ewoodcox is online now Find More Posts by ewoodcox
Old Nov 17, 2012, 07:49 PM
Rocket Programmer
Joined Jul 2007
Yeah you would need a lot more than altitude hold. A friend of mine has a mode on his quad where it moves with the stick regardless of orientation... forward stick always makes the helicopter move due north, left stick it goes west, and spinning it around doesn't change that. Should be possible to fly two of them for a little while in formation that way, but unless you could control location absolutely, they would still drift apart.
Old Nov 18, 2012, 12:19 AM
Boris13 is offline
Joined Oct 2012
Yeah you would need a lot more than altitude hold..
- Altitude hold and position hold would work to get them back in sync. They'd both be standing motionless in mid-air.
After they've stood still for a few seconds the gyros would re-align just as if both helis were on the ground, and they would thus be synched up and ready to carrying on flying in formation.
(maybe heading hold facing due North would be needed too.)
Old Nov 18, 2012, 11:51 AM
Rocket Programmer
Joined Jul 2007
Clearly you've never flown a helicopter before...
I can't be done with a single control signal unless the birds are fully autonomous.
Old Nov 18, 2012, 02:03 PM
Boris13 is offline
Joined Oct 2012
Maybe you're delibrerately misunderstanding everything I say
I never said to fly the helis all the time with altitude and position hold switched on.
I said you could use that military heli style positional hold just to re-sync the 2 helis when they get out of shape. Once re-synched you switch it off and carry on flying.
I don't think that's really such a hard concept to grasp ? I've repeated this simple idea about 4 times now, but the message just doesn't get through.......
Sold One /Size 250 BNF MWC More Pictures and Fly Video Added terriwang Aircraft - Electric - Multirotor (FS/W) 6 May 31, 2012 12:37 AM
For Sale NEW Bison Pitts Style Muffler for SuperTigre G60 and Possibly Others >>One more try<< old_dude Aircraft - Fuel - Engines and Accessories (FS/W) 3 May 30, 2012 11:03 AM
Discussion Is it possible to run 2 motors from one ESC? 4stripes Foamy EDFs 15 Jul 10, 2011 07:35 PM
Question Operating two recievers simultaneously with one transmitter? PSV Captain Radios 7 Apr 13, 2010 10:58 PM
Discussion one transmitter 2 recivers?? possible powerblimp Radios 9 Nov 17, 2008 09:33 AM
