Old Nov 18, 2001, 11:50 AM
cavande is offline
Find More Posts by cavande
TX
Joined Aug 2000
What kind of planes are you flying with the Astro 010 brushless?
I've got an Astro 010 brushless with the proportional speed controller with no home. I was wondering what models people were using with that motor.
cavande is offline Find More Posts by cavande
Old Nov 18, 2001, 01:43 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Just about any speed 400 model with a target weight (400 powered) of 16 ounces or less works great with the 010 and small 720/700mah AAA NiMH cells.
I personally have expereince with pylon racers (Skat, Sokol, Stinger) and sport models (Wattage Mirage, Hacker Funny biplane, Wattage Hawk which is one of my favorite 010 powered models, Wipa Speedy). Even on a Piccolo heli briefly although never got much more than a erratic hover on that model before I sold it.
I'm sure I have forgot a few, but you get the general idea. I am sure one would even fly the Wattage cub well geared on 10 cells. Most of my applications were on 10 cells at about 5.5 amps.
Have fun and let us know what you fly it in!
Steve McBride
Steve McBride is offline Find More Posts by Steve McBride
Old Nov 18, 2001, 05:10 PM
JeffD is offline
Find More Posts by JeffD
Joined Mar 2000
Mine has found a home in a Herr Mini-Sport
JeffD is offline Find More Posts by JeffD
Old Nov 18, 2001, 07:13 PM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
I thought I've read that guys are using this motor in the Jim Ryan warbirds.
Sal C is offline Find More Posts by Sal C
Old Nov 18, 2001, 07:21 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
I'm flying one in a Champion, geared, with 10 720NiMH cells. Only gripe is the Astro gearbox that weighs as much as the motor.
KeithK is offline Find More Posts by KeithK
Old Nov 18, 2001, 08:29 PM
Agra, Oklahoma
Joined Feb 2000
Looking around the ol hangar I found a couple more - Flying Styro F-16 as a pusher, Hacker Arrow (briefly), and a few flights on an FMA Razor with 10 cells for thermal/duration flights (ho-hum performance though).
Steve
Old Nov 18, 2001, 11:21 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
I have the little House of Balsa micro electric cub that was designed specifially for the 010. Sadly it hasn't flown yet as I need to get the 010, but have been lacking money. (Poor College student)
--Paul Susbauer
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Nov 19, 2001, 05:33 AM
dvint is offline
Find More Posts by dvint
Indpls.,In.
Joined Oct 2000
My direct drive 010 (7 600AE cells with 6-3 folder) is in a Merliner
(plans from British Magazine) fuse with a 200 sq. " yard bee airfoil
wing. Wt. 13 oz.
dvint is offline Find More Posts by dvint
Old Nov 19, 2001, 10:22 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
I flew one on an UrbanFlyer. Certainly out-performed the stock GWS370.
Doug Binder
www.mountainmodels.com
CoClimber is offline Find More Posts by CoClimber
Old Nov 19, 2001, 11:00 AM
GoEFlight is offline
Find More Posts by GoEFlight
AeroMicro
GoEFlight's Avatar
Santa Clara, CA
Joined Sep 2001
I use Astro 010 on my Lil Hornet and the perfermance is excellent.
It's geared with a modified GWS EPS DX A version gearbox (3.75:1 gear ratio), APC 10x7 SF prop, and 10-cell Sanyo 720mah AAA nihm. The rpm is 4,200.
My Lil Hornet has about 788 flights as of today, however, GWS EPS DX A with APC 8x6, 8-cell Sanyo 720 Nihm were used for the first 700 flights. After changing to Astro 010, I am totally amazed by its performance with the right combimation.
GoEFlight is offline Find More Posts by GoEFlight
Old Nov 19, 2001, 04:02 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
GoEflight, any idea what your amp draw is on the above setup?
MKH
MKH is offline Find More Posts by MKH
Old Nov 19, 2001, 08:30 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Stinger (pylon) - 010, 4.7x4.7, 8x720NiMH. 9oz all up weight, 60mph or more level, 10 minute flights..
..a
Old Nov 19, 2001, 09:06 PM
AeroMicro
GoEFlight's Avatar
Santa Clara, CA
Joined Sep 2001
Hello MKH:
I set my flight time at 7 minutes full throttle for non-stop aerobatics with my Lil Hornet. It comsumed less than 600 mah, therefore, the caculated current draw is about 5.14 A.
I don't have the right setup for measuring the current, however, the above value might help to get the idea.
Old Nov 19, 2001, 10:09 PM
cavande is offline
TX
Joined Aug 2000
What's the full setup in your Mini-Sport (cells etc.) It looks pretty easy to build and could be kitbashed into resembling something else pretty easy.
Old Nov 19, 2001, 11:02 PM
JeffD is offline
Joined Mar 2000
Herr Mini-Sport setup
Astro 010 with 6x350mah cells and 6x4 APC prop. AUW 8oz. Modified wing to barn door style ailerons. Flying this model more than any other one I have right now. Really nice to have a full house park flyer that can be flown in the wind. Going to be going to 8x720NiMH cells next spring.
What kind of amps are you guys running through the gp2200s? argarre High Performance 23 Feb 03, 2005 05:41 AM
Question What kind of receivers are you guys using in your ap planes? Picoflyer Aerial Photography 29 Aug 27, 2004 08:38 PM
What kind of features are you loooking for in a built-up wood scale model? Ron Daniels Electric Plane Talk 2 Jan 30, 2003 06:00 PM
What kind of lifespan are you getting with your 720 NiMHs? Albig Electric Heli Talk 6 Jul 29, 2002 05:32 PM
Question What kind of batteries are you using? KevinW Hand Launch 8 May 22, 2002 02:06 PM
