Old Nov 18, 2012, 01:46 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
Originally Posted by RightcoastRC View Post
Hey! I like that idea! smaller pieces for less shipping!
So far, a Slicko V2 Rf model will only need new vertical braces under the wings...
EDIT: Um, wait a minute, is that aileron servo hole upside-down? is the servo going to be upside-down?
lol, you caught the ailerons servo before I could mention it. The other thing you'll notice is the cut outs for the standoffs, and other items.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Nov 18, 2012, 01:49 PM
RightcoastRC is offline
Find More Posts by RightcoastRC
Professional Pixel Flyer....
RightcoastRC's Avatar
United States, VT, Weathersfield
Joined Dec 2005
You know me, I am a fan of SFGs!
Yeah she is still sitting there like that waiting for me to install the new Aileron servo and ESC...
RightcoastRC is offline Find More Posts by RightcoastRC
Old Nov 18, 2012, 02:01 PM
Utah USA
Joined Jun 2002
Ok, I'll mess around with SFG's.
Site Sponsor
Old Nov 18, 2012, 02:26 PM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Originally Posted by khen View Post
Any feed back is welcome!
Do you use 1.3# EPP? If so, would it be possible to use 1.9# EPP to eliminate the CF bracing and fences and still yield a more rigid airframe?
Also...a larger canopy would be nice to generate more side area for lift for knife edge maneuvers, etc.
STLAV8R is offline Find More Posts by STLAV8R
Old Nov 18, 2012, 02:35 PM
Joined Dec 2005
Khen I just ordered a couple tubes of Welders and 4 more Gemfan 8x4.5 props from you, gotta make sure My Slicko is ready!
Old Nov 18, 2012, 04:09 PM
Utah USA
Joined Jun 2002
The EPP will be thinner (7-8mm) and a little more dense. I probably won't go as heavy as 1.9# on this small of plane, but something closer to 1.5# possibly CNC cut vs saw cut. I've tried all differen't densitys and thicknesses of EPP both hot wire and saw cut. Of course there are trade off's to each. If it is preferred by everyone I will drop the fences and carbon struts/LE. That's something I've been contemplating in my mind a lot. I don't necessarily like the looks of them, but nothing I know of gives an EPP wing that kind of rigidity with a low weight gain. The wing feels closer to a plank of wood than foam. But it won't be as noticeable without them on this size/weight of plane.
Site Sponsor
Old Nov 18, 2012, 05:57 PM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Thinner.. Less drag GREAT,sharper crisper flight,durability slightly down but that should be offset by slightly higher density foam. Ive flown both and really.. thinner cuts sharper lines and just flys better than 9mm regardless of foam type in the 32'' size stuff. Struts and fences work very well but that could be left up to the builder,ive seen plenty of kits and some do add extra bracing but many seem to be happy without it and may not notice the difference depending on flying styles and cell counts used. The leading edge strip im all for,gives a little extra rigidity and lots of tear protection if you fly around trees or fences or anything that can shear or tear chunks out of the front of the wing,but again that is easy enough to add on your own if you prefer the added protection for the wing during the assembly. I was flying something today and im sure while trimming branches etc the leading edge carbon saved me a couple times.
Get Real is offline Find More Posts by Get Real
Latest blog entry: The Blade Chroma ROCKS!
Old Nov 18, 2012, 08:01 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
I'd love to try (BUY) a plane with SFG's.
3flyguy3 is offline Find More Posts by 3flyguy3
Old Nov 18, 2012, 08:06 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
...I will drop the fences and carbon struts/LE.
What are fences and carbon struts/LE?
Old Nov 18, 2012, 08:26 PM
Utah USA
Joined Jun 2002
The wing fences are the 2 EPP pieces standing up on either side of the wing. The struts are the carbon fiber go down from the fuselage, through the fence and into the wing. The LE carbon is the strip glued to the lead edge of the wings on either side.
Site Sponsor
Old Nov 18, 2012, 09:15 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Got it
Old Nov 18, 2012, 11:08 PM
Utah USA
Joined Jun 2002
Thanks all for your great feedback on Slicko V2.
Here is an updated picture with the following changes so far.
1- Enlarged upper fuse and canopy. You can see the silhouette of the original shape. I exaggerated it for testing and will alter after flight tests.
2- Aileron servo moved forward and tail servo's moved back for a wide range of battery placement options.
3- Wing fences, gone.
I'll be trying different SFGs and various other tweaks mentioned.
Keep the feedback coming.
Site Sponsor
Old Nov 18, 2012, 11:28 PM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
OK, I had to join this thread...Khen, when I got the wing struts glued inplace on the current build ( over in the other thread ), I twisted the wing at the tips and it did not have much strength, the fences really do their job to make the wing "surfboard strong". When you place a plane on the bench, and then try to twist the wing with the struts and fences, you will see the carbon rods make an "S" bend as they are resisting the forces, and it is the fences that are dampening that...
maxxnut is offline Find More Posts by maxxnut
Old Nov 18, 2012, 11:45 PM
Utah USA
Joined Jun 2002
Hello maxxnut, yes, I agree it is the combination of the fences and struts that make the magic for a really stiff wing. On the new kit I'm thinking of eliminating both the struts and fences. I think the looks deter a lot of people as well as the added complexity. For those that still want it they can add them easily enough. I've got a prototype on the way and will really put it to the test.
Site Sponsor
Old Nov 19, 2012, 04:28 AM
EZglider is offline
Find More Posts by EZglider
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
I really like the looks of V2. Is it gonna be 32 in ws? If so, I'll wait til it's available, and go that route for my next!
EZglider is offline Find More Posts by EZglider
Discussion FMS 1400mm FW-190 Owners Thread Orion Pax Electric Warbirds 8029 Today 03:02 AM
Discussion TechOne Owners Thread wolfewinde 3D Foamies 2251 Apr 28, 2016 03:53 PM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1526 Apr 20, 2016 06:15 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
