Old Nov 16, 2012, 01:00 PM
BamaBasher is offline
Find More Posts by BamaBasher
BamaBasher's Avatar
United States, AL, Orange Beach
Joined Oct 2012
Help!
Want to light up my Champ - advice needed
So I want to light up my HZ Champ for night flying. I've been reading around here and at wattflyers but I'm getting very lost in it all.
I get 12v. If I had 12v it would be no problem. That's what I'll do for my Super Cub eventually.
All the premade kits I've read about seem to not be available so I was thinking I might build my own.
I saw a YouTube video that used these Radio Shack 4 pin LEDs in white green and red on a Champ.
That appeals to me because I could solder them up and use them tonight. Here's where I need help.
Lets say I get 4 of these. They need 3.5v so I should be able to run them on a 1S right?
I don't understand resistors and such. If my batt is pushing 3.7v and these will take a max of 4v can I just run wire from battery to LED1 wire to LED2 wire to LED3 wire to LED4 and then from LED4 back to the battery?
At an 80mA draw should I wire them into the flight battery or plan on a separate one?
Why 4 pins? What is there besides positive and negative that I have to solder up?
I don't see weight listed in the specs and I'm really worried about that. The champ is so light even 2 glow stick bracelets overpower it (yeah I tried it).
Maybe there is a better option that's just as bright or brighter and/or lighter weight. I'm open to suggestions and willing to order online from Hobbypartz or whoever if my current idea isn't very good. I've just gotten overwhelmed with all the information out there and I'm lost.
Thanks in advance for any help.
BamaBasher is offline Find More Posts by BamaBasher
Old Nov 16, 2012, 03:26 PM
BamaBasher's Avatar
Joined Oct 2012
Oh! After going to RS and seeing what those are that's not what I want after all. Those are for push buttons on stuff. They seem heavy to me.
Back to the drawing board and trying to figure out what to get from Hobby King or Hobbypartz I guess.
Old Nov 16, 2012, 06:42 PM
branflakes is offline
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
gorillabobs rc is the best online lighting store I could find. I have over 200 bucks in lights alone, led strips, from them on two planes. they have both 5v and 12v options, email Robert there he will tell you exactly what you need there's no better store. hk sucks compared to this guy.
branflakes is offline Find More Posts by branflakes
Old Nov 16, 2012, 08:28 PM
BamaBasher's Avatar
Joined Oct 2012
Thank you! I read several positive comments about Gorilla Bob's during my researching the past few days but I couldn't remember their name to google them.
You are da man!
Old Dec 04, 2012, 09:17 PM
Thirston is offline
Find More Posts by Thirston
United States, NC, Charlotte
Joined Jul 2012
3 or 5mm leds should be what you are looking for. You can run them from a 1s or a button cell cr2032. The led will have just 2 leads unless its a multicolor and then it could have 3 or more. I can't offer you much in the way of wiring advice but I can offer you some 5mm leds of assorted colors, a female plug for your 1s batteries, as well as a 3v button cell and a battery holder if you'd like to tinker with them. Shoot me a pm if you are interested.
Thirston is offline Find More Posts by Thirston
Old Dec 05, 2012, 07:05 PM
Barn-E-Stormer is online now
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Would you consider some LED strip and a small 3 cell lipo to run them? The Champ could carry and extra 300mah 3s Lipo no problem. A few small sections of LED strip in strategic places is all you need. Much simpler to wire.
PM me if for ?????
I like the HobbyPartz.com strip.
Barn-E-Stormer is online now Find More Posts by Barn-E-Stormer
Old Dec 05, 2012, 07:55 PM
zooman is offline
Find More Posts by zooman
zooman's Avatar
Canada, AB, Jasper
Joined Feb 2007
The LED strips are the easy way to go. Peel and stick. Wire to 12v battery.
The 5mm LED are good to but there's alot of wiring and soldering. I use a cell phone battery 3.7v to power my 5mm LED's. 25 of them. Good for 5 or 6 12min flights.
zooman is offline Find More Posts by zooman
Old Dec 29, 2012, 02:13 AM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Have you considered the Micro lighting kit (bottom of linked page) from AuroraRC?
http://www.aurorarc.com/products-page
I have the Genesis kit on a 3D plane and they are very good. The videos of the larger ones are even more impressive, especially those flown by Joe Smith
http://m.youtube.com/results?q=aurora%20rc%20lights
ltc is online now Find More Posts by ltc
Old Dec 31, 2012, 02:06 PM
goly is offline
Find More Posts by goly
Joined Nov 2012
although using the 12v led strip is more simple, there is cost to it you will lose more energy on the resistor then 1s battery
few points:
1) most of the led works on 20mA (like the 5mm & 3mm)
2) every led have voltage drop(VD)
, meaning that every led need min voltage to start working
*red,orange ~2v
*blue,gren,white ~3-3.5v
you will have to look at datasheet of the led
or check VD with multimeter with high resistor
for 5v use check resistor ~300ohm
for 12v use check resistor ~700 ohm
** those resistor have higher value then need(curent will be lower the 20mA)
________________________________
(MaxVoltage-VD)/current[20mA]= resistor needed
example
for red led with VD=2, curent 20mA=0.02A with 1s bat the resistor will be
(4.2-2)/0.02=110ohm
goly is offline Find More Posts by goly
Old Dec 30, 2013, 10:45 PM
tackthekak is offline
Find More Posts by tackthekak
Joined Aug 2013
Lights sold on eBay for micro's:
http://www.rcgroups.com/forums/showt...3#post26940840
tackthekak is offline Find More Posts by tackthekak
Discussion Can I boost up my champs power dbdukeboy Scratchbuilt Indoor and Micro Models 26 Nov 04, 2012 08:40 AM
Discussion Need some advice setting up Virtualdub/deshaker Navigator53 Aerial Photography 1 Aug 08, 2012 06:29 AM
Question need foam touch up advice (sapac eurofighter) out of stock Foamy EDFs 2 Aug 02, 2012 09:33 PM
Discussion Can I plug two sets of 2022a Tiny Brite Lights and have 2x the lights on my Champ? newflyer100 Micro Ready-to-Fly 2 Jun 26, 2011 09:05 AM
Help! I need some advice on lighting up my AA saucer ICU Night Flying 4 Aug 18, 2008 03:07 PM
