Old Nov 16, 2012, 11:30 AM
jmrpb is offline
Find More Posts by jmrpb
jmrpb's Avatar
Lisbon, Portugal, Europe
Joined Nov 2009
Cool
Mig 1.44 or Rafale with twin vertical rudders? - You decide!...
Mig 1.44 or Rafale with twin rudders? - You decide!...
With Functional Canards
(Version 2)
This is my late Mig 1.44 or Rafale with twin rudders. It has functional canards mixed with the elevator channel and four servos. The elevators and ailerons are linked together (like elevons).
This babe can manoeuver like a 3D airplane, and it can also be very fast or very slow (canard mixing help a lot).
It has a simple way of vectorial thrust, like some of other pusher planes. It does almost any 3D manoeuvre that you can think of, with a very good vertical performance. And, of course, it is also very forgiven and stable if you want to. Most of the times, I catch it by hand on landings.
It has KF airfoil number 4 (symmetrical 6mm up and down - Acro) for aerobatics. Like you can see it works great!!
The power system is the great secret for good low speed and high speed performance.
The specifications are:
Motor: Axi 2208/34 gold line;
Propeller: Graupner 9” 6” Slim Cam (This is because the 9” 6” is perfect for acceleration from slow speed and high AoA and also have great behavior at high speeds);
Batteries: #1 Lipo 3 / 850 mA/h with 30C;
Speed controller: Jeti 8A (yes; just only 8 Amps, but this is more than enough. With this power system I can maximize my flight times around 9 minutes with 3D and Acro performance or 12 minutes plus with gentle use of the throttle stick (this is, if you can control yourself with this kind of bird ).
The ailerons and the elevators are linked together by one carbon tube.
The canards are mixed together with the elevator channel for slow flight and high angles of attack - like ‘F1 Wanna Be’ have suggested (Thank you!).
Roughly, the dimensions are:
Front to tail: 80 cm (overall length);
Front to leading hedge of the wing: 30 cm;
Wingspan: 60 cm;
Leading hedge swept angle (wing): 60º;
The tip of the wing (outer far part of the wing is): 12 cm (with ailerons);
Ailerons have: 8 cm (at the widest point);
Dimensions of rudder (at widest point): 18 cm tall by 13 cm wide (at the bottom);
Weight: 350 grams or ~ 12,5 oz to ~ 13,5 oz range. Ready to fly (with this set up and battery).
The front part is made of red ‘polypropylene’ that makes it almost, and I say ALMOST, indestructible. The canards are made of thin (2 mm or, approximately, 1/10 of an inch) orange ‘polypropylene’.
I hope that this brief description helps.
I will post a video as soon as possible.
It looks great in the air with this painting scheme (tiger camouflage) and it’s guaranteed that you’ll receive all the attention of other RC fellow pilots!
Check out the photos below.
Follow your dreams and fly like there is no tomorrow! .
Happy flights and happy landings!
Please enjoy as much as I do.
José Bernardo
jmrpb is offline Find More Posts by jmrpb
Old Nov 16, 2012, 11:33 AM
jmrpb is offline
jmrpb's Avatar
Joined Nov 2009
Still Pictures:
Old Nov 16, 2012, 11:35 AM
jmrpb is offline
jmrpb's Avatar
Joined Nov 2009
This is a compilation from my fourth and fifth flights, after all the trimming process. Hope you enjoy as much as I do.
Video with some 3D aerobatics below:
Mig 144 Rafale HD (6 min 18 sec)
Old Nov 16, 2012, 11:36 AM
jmrpb is offline
jmrpb's Avatar
Joined Nov 2009
This is a small movie with some construction still images.
Rafale Mig 144 JB+.wmv (1 min 18 sec)
Old Feb 02, 2013, 09:02 AM
jmrpb is offline
jmrpb's Avatar
Joined Nov 2009
This airframe is very good for aerobatics.
Please note the steady vertical roll at 2’:54’’. I can assure you that this maneuver is very difficult and demanding for the airplane to achieve it.
José Bernardo
Old Feb 02, 2013, 09:17 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
!.44 ?, I decided to go a little bigger.
And slower
eflightray is online now Find More Posts by eflightray
Old Feb 11, 2013, 08:53 AM
jmrpb is offline
jmrpb's Avatar
Joined Nov 2009
Wow! That is an airplane, sir! Very, very nice. Any videos and aerobatics?
José Bernardo
Cool Mig 1.44 or Rafale with twin rudders? - You decide!... jmrpb 3D Foamies 4 Feb 02, 2013 08:57 AM
New Product DT rx 43d 4 ch servo or act, twin esc with tho diff. what you think? nemoskull Scratchbuilt Indoor and Micro Models 13 Apr 20, 2012 11:44 PM
Build Log MIG 1.44 Flatpack Profile f1wanabe Pusher Prop Jet Models 14 Apr 01, 2012 09:42 PM
Gallery Real or RC, You Decide? paroflyer Aerial Photography 0 Mar 17, 2012 12:36 AM
Wanted MVVS 1.20 or 1.44 Twin sarg96 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 28, 2010 10:19 AM
