Espritmodel.com Heli Air
Old Nov 16, 2012, 11:24 AM
CFrench's Avatar
United States, MD, Rockville
Joined Nov 2000
Plane retrieving telescoping poles
Looking for some info on plane retrieving poles. I have seen one of these the 40 foot verson and its very nice but a tad pricy. Wondering what else was on the market or what folks use to get planes out of trees.
CFrench is offline Find More Posts by CFrench
Old Nov 16, 2012, 01:56 PM
slopemeno's Avatar
United States, CA, Mill Valley
Joined Jan 2003
Ettore Steccone made some really nice window washing extension poles. Janitorial Supply houses carry them.
I prefer the "wrist-rocket-with-a-fishing-reel" approach. Everything you need fits in a small paper bag.
Get a Whamo wrist rocket and a cheap open-face fishing reel. Cut off the top of the "T" that is used to hold the reel to your fishing pole. Glue the reel into the base of the wrist rockets grip, with the reel facing forward. Put about 250' of 100# line on the reel. Tie a 1 oz fishing weight to the line.
Launch 1 oz fishing weights over the tree that your plane is caught in. Tie a 200' piece of 1/4" polypropelene rope to the 100# line and pull the 1/4 rope up and over the branch. Now pull like crazy- get the tree swaying. If you tie a loop in the rope big enough to putt your foot through you can really shake the tree. Your plane will fall out, hopefully with minimal damage.
We've also used the extension pole approach, but a pole stiff enough to get high enough is heavy enough to need multiple people, and a bear to thread up through the branches. The best technique is to push the plane up and out, until it's on the outside of tree's canopy, and then let it fall off the tree.
slopemeno is offline Find More Posts by slopemeno
Latest blog entry: F-20 update
Old Nov 16, 2012, 02:54 PM
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
I stuck my glider up about 60-80 feet in the one tree in the field within 200 feet of us - yes I did!
I bought a childs compound boy from Dicks sporting goods - drilled a hole through the arrow, stuck in some 60# fishing line (also used for spoilers on my older gliders) and after about 1 hour - the plane was down. Yes, it took a while to get the unit working but certainly worth it.
Scott
PS - it was about $40 + another $10 for spare arrows i never used
ScottSails is offline Find More Posts by ScottSails
Old Nov 16, 2012, 02:57 PM
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
Got one stuck about 30-40 feet up in a tree, used pvc pipe but it tends to bend when extended to that length.
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Nov 16, 2012, 04:27 PM
Norm Furutani's Avatar
United States, CA, Gardena
I use a 31' Jackite pole, but it looks like the price has gone up! Here's the link: http://www.jackite.com/product_info....roducts_id=133
- Norm
Norm Furutani is offline Find More Posts by Norm Furutani
Old Nov 17, 2012, 06:49 AM
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Sometimes you have to go to the problem
Piper J3 is offline Find More Posts by Piper J3
Old Nov 19, 2012, 09:46 PM
Ready to string launch!
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Those are electricl linesman poles. I think 3-400. My rocket club has one and uses it frequently.
Ryan
rdwoebke is online now Find More Posts by rdwoebke
Old Nov 20, 2012, 06:17 AM
CFrench's Avatar
Joined Nov 2000
Ryan
Thanks linesman poles search came up with better reults then telescoping fiberglass poles ~ found the same pole for $100 cheaper. http://www.jharlen.com/hasfibhv240.html# This will be a club puchase and a long term investment that will pay off over time.
Old Nov 20, 2012, 06:23 AM
rdwoebke's Avatar
Joined Feb 2004
What you have linked to is exactly what my rocket club has.
Ryan
Old Nov 20, 2012, 07:20 AM
the flying is good
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
They used to make a 65 foot pole. I've used that a bunch of times and though heavy, if the plane was within reach it came down.
Now I usually keep a set of metal tent poles in the van to assemble and sometimes some light carbon tubes to add but a bow and arrows with line is becoming my fav.
Yes, the number of trees I've hit is still climbing!
Dennis
dephela is offline Find More Posts by dephela
Old Nov 22, 2012, 07:07 AM
R.M. Gellart's Avatar
Joined Nov 2005
If you go to this link, http://www.hfgp.com/fb-catalog/files...e/index.html#9
These are one of three companies that make some form of what is used in the electric utility business called extendosticks or tel-o-poles that allow lineman to do some jobs from the ground while having a tool that insulates them from the line current. The company I work for sells them, www.americansafety.com
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Nov 22, 2012, 08:01 AM
CFrench's Avatar
Joined Nov 2000
Yes thanks for the link we ordered an ST-240
Old Nov 22, 2012, 09:56 AM
rdwoebke's Avatar
Joined Feb 2004
It should be pointed out, that although these poles are designed for electrical work when used in actual electrical work they are tested and certified regularly. To us non professional electrical workers, don't ever attempt to get something off an electrical line ever.
Old Nov 22, 2012, 08:46 PM
United States, MA, Waltham
Joined Dec 2001
I've used 4 sections from a roof rake. I can stick those on a 10 foot piece of (very small) sailboat mast. I could stick an 18 foot telescoping pole I have on the other end for a total of something like 46 feet, though I'm not sure I could handle it.
lincoln is offline Find More Posts by lincoln
Old Nov 27, 2012, 07:51 PM
Sdr
Scott R
Sdr's Avatar
I have one of those poles. My cousin's husband is a lineman for our local power company and I asked him about getting one that has been retired from service. When I first asked it didn't sound too promising. He told me the company test the poles every two years and those that don't pass get sent back to the mfg. for recoating.
As Luck would have it he did find one in a corner of the shop that was missing the second section and he got permission from a supervisor to take it.
FYI he knew it as a "switch stick" should anybody ask their local lineman to see if he can get one.
Sdr is offline Find More Posts by Sdr
Discussion Suggestions on a telescopic pole rcmaverick Electric Plane Talk 19 Oct 04, 2012 09:04 PM
Discussion Suggestions on a telescopic pole rcmaverick Electric Plane Talk 0 Oct 01, 2012 05:53 AM
Yippee! Telescoping Pole AP Camera Build Thread! Bluecor Aerial Photography 438 Apr 09, 2008 09:12 PM
Discussion Telescoping Poles Cincy E-Flyer Toledo Weak Signals RC Expo 9 May 07, 2007 06:11 AM
Discussion Great deal on telescoping pole (for getting plane out of tree) sleeper33 Beginner Training Area (Aircraft-Electric) 4 Dec 16, 2006 08:06 AM
