Old Nov 16, 2012, 09:53 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Expected long - now available
Take the bearings out of the superchief, add a satellite and what do you get? 4Plus... now available in cf?! Check out the sized below...
Dimensions: Weight: 42 grams Diameter 21mm front 4eckig: 22x22mm Hole circle: 25 4 hole M3 24.6 mm total length (without shaft) Wavelength: 18mm shaft: 6mm (Steel) Softw r:
GRP EDITION 4Plus molded: 29-35-37-39 mm Optional Available: Torque pinion 8mm wide, 3.17 mm for shaft, flange, Loctite, high performance grease.
http://www.reisenauer.de/artikeldetails.php5?aid=1509
la528it is offline Find More Posts by la528it
Old Nov 16, 2012, 11:43 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
You forgot to mention that it is rated up to 4KW
Andy told me that it has been successfully used at even higher powerlevels!
In my personal experience even the small Microedition NL is reliable at more than 3KW (rated at 400W continuous and 1000W for 10 sec.).
I will order next week!
Yello
Mreyello is offline Find More Posts by Mreyello
Old Nov 16, 2012, 12:28 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
This is for 3.17 shaft motors only?
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 17, 2012, 02:22 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
I don't think so... you may be able to use kontronik pinion... I need to count teeth
New Product EzUHF, the long range EzOSD companion, AVAILABLE NOW! ssassen FPV Talk 1722 Yesterday 01:57 AM
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14076 Jul 18, 2016 08:25 PM
Discussion HPP-22 program file V1.15(0) now available. A.T. Hitec/Multiplex USA 0 Mar 05, 2012 02:13 AM
