Old Nov 16, 2012, 07:51 AM
nalby is online now
Find More Posts by nalby
Professional Toothpick maker
nalby's Avatar
USA, NY, New Hampton
Joined Jan 2005
Multi4 error96
I have a multi4 and I keep getting error 96 at 1min 13 sec. I mainly use it for a123's but I tried some lipo's and still get the same errors.
nalby is online now Find More Posts by nalby
Old Nov 16, 2012, 11:20 AM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
This is usually an indication of a power supply issue, a failing power supply, a power supply that is too small for the job, or the wiring and/or connectors between the power supply and the charger. What is your power supply, how is it connected, and have you checked over all your wiring and connections between the PSU and the charger?
If you're getting this using an AC/DC power supply, try connecting the charger directly to a car battery and see if the problem goes away.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Nov 16, 2012, 12:21 PM
nalby is online now
nalby's Avatar
Joined Jan 2005
Thanks for the response.
I'm using a 47a 12v (12.64v) server power supply. But I also tested it on an 25a pyramid power supply set at 12.5v. as well as the battery in my car. Always the same error 96
Old Nov 16, 2012, 05:25 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
O.K. Then it's likely a problem with the charger. Please contact Howard and he'll work with you to exchange it, or get it repaired.
I would triple check to make sure it's not something simple like a bad solder connection at the input plier clips or something though.
Reach Howard at howard@fmadirect.com or (301) 829-5533 for additional assistance.
Tim Marks
Discussion Cellpro Multi4: set Charge Voltage to 4.3 - 4.35v for LiIo petekol FMA Direct 11 Apr 21, 2016 06:10 AM
Question Cellpro Multi4 and NiZn batteries? idonasch FMA Direct 7 Nov 06, 2012 05:12 PM
Discussion PL6 w/ HF Generator, Multi4 w/Beast lipos BrownEyedFool FMA Direct 5 Nov 01, 2012 11:41 PM
Sold Cellpro multi4 new in box java8297 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 17, 2012 12:41 PM
Discussion Multi4 arrived but I need adaptors raycalvino Batteries and Chargers 1 Jun 28, 2012 10:26 PM
