USA, ME, Ellsworth
Joined May 2008
Some info on planes that used that motor here:
Art Hobby Castor-EV 2.5M Build - http://www.rcgroups.com/forums/showthread.php?t=862800 ArtHobby Evolution-E - http://www.rcgroups.com/forums/showthread.php?t=781527 One of those mention a 12 x 6 prop, another mentions a 32mm or so motor, all you really need to do is find some info on the prop they used and you can work that backwards to a good motor to make it go around with. Added note: Here is a PJS 1200 motor, the 1400 is probably the same motor with a different Kv rating: http://www.arthobby.com/index.php?pa...ry=65&item=182 Motor KV (RPM/V) - 950 Current (A) - 17 - 21 Battery (LiPo) - 3 cells (1200-1600mAh) Propeller Range - 11.5x6, 12.5x6 CAM carbon Static Thrust ~1200 g / 42 oz. Weight - 68 g / 2.38 oz. Motor Diameter - 28 mm / 1.10 in. Motor Length - 35 mm / 1.38 in. Shaft Length - 22 mm /0.86 in. Shaft Diameter - 4 mm Looks like almost any 68 gram or so motor with a Kv around 900-1000 would be a good start for you. The 28mm may be key to fitting the motor into the fuselage. Jack |
USA, ME, Ellsworth
Joined May 2008
Your 35mm motor will be heavier and therefore more powerful too. And if I go here I can look at the details on the Castor EV-2.5M: http://www.arthobby.com/index.php?pa...ry=50&item=250 That lists a 35mm motor called the ART-2000 for the Castor. The details on the ART-2000 show it as a 35mm x 39mm, 650 Kv motor that weighs 157 grams. And the 3 Watts per gram rule makes it about a 471W motor. The ART-2000 motor details are here: http://www.arthobby.com/index.php?pa...b_category=65# So maybe you have a ART-2000? Or maybe the 1400 motor is a 35mm motor that is a little more motor than the 1200 and less than the ART-2000? Since the ART-2000 is listed as 35mm x 49mm long, the 1400 might be something like a 3536 or so motor. If you're sure you have a 1400, measuring the length of the body will get you in the ballpark on finding something similar. As an example, here is a 96 gram motor that measures 35mm x 36mm. It has a 970 Kv, weighs 96 grams, and that can be thought of as a 288W motor: http://www.headsuprc.com/servlet/the...ushless/Detail AH looks like they specialize in better quality gliders and they carry some of the better quality European accessories. Looking at their motors I would guess that they are a "house branded" Chinese motor and of average quality or maybe a little better than average if AH is a demanding buyer and applying some quality control to the process. I play with motor gliders a little but nothing of the size and quality of the EV line. So I have gotten involved in the details of glider power systems and accessories. There is a world of difference in the quality and performance of accessories between the European made stuff and the copies from China. For the most part I buy the better stuff when I buy props, hubs, yokes, and that kind of stuff. Is this your prop here? http://www.arthobby.com/index.php?pa...ry=55&item=207 That is a lovely thing for sure. I don't have one of those yet... But I certainly do appreciate the quality and performance of Graupner and Aeronaut folders over the cheap junk. Jack |
| Thread Tools | |
| Sold Art-Tech 950kv BL Motor With Art-Tech 30A BL ESC REDUCED | nitrodude71 | Aircraft - Electric - Power Systems (FS/W) | 3 | Aug 15, 2012 09:04 AM |
| For Sale Art Hobby 2M Boar, ready to fly, $180 | John Kim | Aircraft - Sailplanes (FS/W) | 1 | Apr 16, 2012 11:05 PM |
| Sold Art Hobby Thermic RES 2.5 | Hoody Pants | Aircraft - Sailplanes (FS/W) | 6 | Feb 29, 2012 12:09 AM |
| Help! Need a new Wing for my 2m Art-Hobby Sky-E | Avetikus | Electric Sailplanes | 1 | Feb 22, 2012 07:05 PM |
| Need motor recommendation for Art Hobby Kastor 1.65M | ferradas | Electric Sailplanes | 2 | Mar 21, 2002 01:48 PM |
