Old Dec 01, 2012, 12:49 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
I've had a look at the Gluonpilot site.
The GP seems to share a lot of features with the UavDevBoard (I own a UavDevBoard).
Did you add a magnetometer ?
I would like to fly high and bring back some nice video but I dare not because I did not add a magnetometer to my UavDevBoard. This means that my autopilot will go berserk if the plane encounters high winds (if my plane flies backwards).
Paul_BB is offline Find More Posts by Paul_BB
Old Dec 01, 2012, 09:38 AM
icebear is offline
Find More Posts by icebear
icebear's Avatar
Helsingborg, Sweden
Joined Sep 2001
You're right - I think there are some similarities. I have not altered the GP in any way so I dont have a magnetometer.
However when planning a flight I try to allow room (speed!) for stronger winds at altitude but I have the downlink showing the plane's speed, altitude etc so I can abort if headspeed gets to slow.
What normally happens is that you get an swaying motion if the winds get to strong but I havent lost control becuase of high winds (yet!).
/Björn
icebear is offline Find More Posts by icebear
Old Dec 01, 2012, 09:38 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
Gluonpilot does look interesting. I have a plane outfitted with UDB3, and it does a very good job with speed and altitude control, but sometimes it doesn't follow waypoints very well. I have considered buying a GP setup, but spending $500 or so dollars on electronics isn't very high on the priorities list right now. I've enjoyed following your threads, though.
Tony
t-turley is offline Find More Posts by t-turley
Old Dec 03, 2012, 08:55 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Hi Tony,
What do you mean by "it sometimes does'nt follow waypoints very well"?
I have not encountered this problem with my UDB.
I do have found that sometimes the GPS position can drift, sometimes as much as 50 yards, but that is not due to the UDB but to the GPS system.
Rgards,
Paul
Old Dec 04, 2012, 10:01 AM
t-turley is offline
Joined Mar 2001
Paul,
My aircraft will usually follow a sinusoidal pattern between waypoints, rather than flying a direct path. Sometimes it will skip a waypoint entirely, or veer way off course before suddenly veering toward the next waypoint. Honestly, I never considered that it might be a problem with the GPS and not the board itself. I'm using the EM406A GPS.
Tony
Old Dec 05, 2012, 12:22 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Hi Tony,
Obviously, the lateral gains are not well tuned. Is your airplane fitted with ailerons or is it rudder only ?
Paul
Old Dec 05, 2012, 01:39 PM
t-turley is offline
Joined Mar 2001
Paul,
Both, but set up with aileron nav only in options.h.
Tony
Old Dec 06, 2012, 12:59 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
You could:
- Try to increase the YAWKD_AILERON gain to dampen the turn.
- You may also decrease the ROLLKP and YAWKP_AILERON gains to soften the turn.
- If you notice some roll oscillations then increase the ROLLKD gain or decrease the YAWKP_AILERON and ROLL_KP gains.
Old Dec 06, 2012, 10:02 AM
t-turley is offline
Joined Mar 2001
Thanks Paul. Sorry to hijack your thread, Björn.
Tony
Old Dec 07, 2012, 05:00 PM
icebear is offline
icebear's Avatar
Helsingborg, Sweden
Joined Sep 2001
Tony
That's OK! I agree with Paul - sounds like a tuning issue with the UAVDevboard even if I have no experience with it.
When correctly setup the GP manages spot on navigation
Cheers,
Björn
Old Dec 08, 2012, 10:53 AM
t-turley is offline
Joined Mar 2001
Here's an example of how my plane follows waypoints; sometimes it has been even worse.
Tony
Old Dec 09, 2012, 12:10 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Hi Tony,
The result is pretty good by my standards. I think the gains values are pretty good. The wobble could be due to some wind gusts.
Did you let the algorithm estimate the wind by circling the plane around you a few times before switching the auto mode on ?
You can also switch the speed control on and choose a reasonable airspeed value. The algorithm has some difficulties to control the plane if the plane flies near its stall speed. And I suppose you know that in the real world the values of the control gains depend upon the airspeed, so it is better to keep the airspeed as constant as possible.
You should also try the CROSSTRACK option. It will help maintain the airplane true on track during long legs.
Did you keep the plane level during initialization ?
I hope I can help.
Paul
Old Dec 09, 2012, 09:02 AM
t-turley is offline
Joined Mar 2001
Paul,
I did circle around a few times before going to auto. According to Multiplex, the stall speed is 7 m/s, so I set the speed at 12 m/s. I also had the plane level during initialization. Speed control and altitude control were both very accurate. I tried CROSSTRACK once, but I don't think I had it set up correctly. I'll try again some time. Thanks.
Tony
Old Dec 10, 2012, 06:51 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Tony,
Increase YAWKD_AILERON by 30% and try the CROSSTRACK option.
I found on my simulator that the cross track control is a little stiff. This stiffness induces slight oscillations around the desired ground track. You can try, in the navigate.c function, to change the CTMARGIN value from 16 to 32 and the CTGAIN value from 2 to 1.
Note: CTGAIN * (CTMARGIN - CTDEADBAND) should equal 32.
CTDEADBAND is equal to zero.
The cross track control will be really sluggish this time but this will rule out any problem from it.
Paul
Old Dec 10, 2012, 03:16 PM
t-turley is offline
Joined Mar 2001
Thanks Paul.
Tony
New Product 2012 New arrival Double Horse 9117 2.4G 4CH RC Helicopter Aaron qin Mini Helis 56 Aug 18, 2012 03:44 AM
New Product New arrival Double Horse 9117 2.4G 4CH RC Helicopter Aaron qin Large Electric Helis 4 Jul 25, 2012 07:59 AM
Rave My Slow Hawk has Arrived! Buck Shot Ornithopters 18 May 22, 2012 12:54 AM
