Old Nov 15, 2012, 07:25 PM
marair23 is offline
Find More Posts by marair23
Joined Aug 2012
Help with Setup-Newbie
I'm trying to get flying but not having much luck. I'm trying to get the 4 Channel Transmitter , receiver,ESC,servos to work with no luck.
I've boght from hobby king-no luck
and HeadsupRC -no luck- HOWEVER these guys are great and trying to help.
But nothing so far
Just though someone on the form might have the answer.
any help is appriciated
I turn on transmitter.
The esc goes through all but the last of its beeps.
It is suppose to beep 3 times then after 2 seconds beep twice then a long beep and it should be ready to go.
But after the 3 beeps it just goes beep,1 sec,beep,1 sec,beep,1 sec,beep, it just keeps doing this. Any suggestions HOW it setup this system
marair23 is offline Find More Posts by marair23
Old Nov 15, 2012, 07:49 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
My first question is have you bound the Receiver? If not follow the directions that came with the radio to bind the Tx and Rx. If you have bound them, can move control surfaces and but no throttle then I would say look at the throttle input. When powering on the Rx make sure the throttle lever is all the way down and the trim on the throttle is all the way down.
Let us know of the results after trouble shooting.
1fullbird is offline Find More Posts by 1fullbird
Old Nov 15, 2012, 10:32 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Could you link to the transmitter and receiver so we know what equipment you're asking about?
bartricky is offline Find More Posts by bartricky
Old Nov 15, 2012, 11:31 PM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
bind transmitter to receiver by the book make sure you go thru the whole thing. once you have done this, turn on transmitter, plug battery in plane (turn switch on if you have one) when the esc beeps it first set of beeps, go full throttle on the transmitter, then back to no throttle.
sometimes the esc needs to see the endpoints of your throttle to arm up. it usually only needs this done the first time. once it recognizes it your good to go. my flysky transmitter needed this.
DO THIS WITH THE PROP OFF THE PLANE THO!!!!!
hoghead5150 is offline Find More Posts by hoghead5150
Old Nov 15, 2012, 11:40 PM
marair23 is offline
Joined Aug 2012
It's a Radio Link T4EU transmitter 2.4ghz, Radio Link R7EH receiver
Old Nov 16, 2012, 08:08 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I found a copy of the manual if it helps -
USER MANUAL FOR T4EU&T4U
eflightray is offline Find More Posts by eflightray
Old Nov 16, 2012, 08:11 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Also this thread in the Radios forum -
help from manufacturer how to use Radiolink radios
Old Nov 16, 2012, 09:27 AM
marair23 is offline
Joined Aug 2012
Guys-Thank very much for your info! I'll go over everthing and see if I can get it to work.I'll get back to the post ASAP.
Old Nov 17, 2012, 10:14 PM
alibongo is offline
Find More Posts by alibongo
alibongo's Avatar
United Kingdom, England, Dorset
Joined Apr 2010
Well?
alibongo is offline Find More Posts by alibongo
Old Nov 18, 2012, 04:56 PM
teknokraze is offline
Find More Posts by teknokraze
Pro RC Boneyard Developer
teknokraze's Avatar
Canada, BC, Arrow Creek
Joined Jan 2012
I agree with hoghead 5150. If that doesn't work my guess is you have to reverse your throttle.
Regards...
teknokraze is offline Find More Posts by teknokraze
Old Nov 24, 2012, 09:55 PM
marair23 is offline
Joined Aug 2012
I sent everything back to Heads Up RC. They have received my package and sent me an email to let me know they didn't get to check everything out yet but received it. I did purchase a RTF Lite Hawk from them the same day I sent my return. I had a maiden flight Fri Nov. 29th. WHAT A THRILL to get up and flying!!! I know how the Wright Bros. felt!!! All went well with the Lite Hawk and Yes I did have some so so landings but I got 6 fights in and it was GREAT! I can't wait to get my stuff back and put it in the planes I built. Thanks for all the HELP! The info you guys provided was very usefull!!! And HEAD UP RC are SUPER on customer support! So support them! Thanks-marair23
Discussion Newbie Needs Help - Gaui 500x setup opusxxvii Multirotor Talk 1 Sep 08, 2012 11:09 PM
Help! Newbie Needs Help with 'Corn Setup FlyinWing Foamies (Kits) 0 Jan 09, 2007 11:37 AM
Discussion Newbie Needs Help with Unicorn Setup FlyinWing Flying Wings 2 Jan 06, 2007 09:52 PM
Help with setup (Another Newbie) OzzieFlyer Micro Helis 5 Apr 22, 2004 05:57 PM
Newbie -- Help with Corona tail setup bsumpter Electric Heli Talk 1 Jul 29, 2002 02:53 PM
