Old Nov 15, 2012, 06:20 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Motor deals!
We are having a clearance of some great motors. These motors were OEM and we have some left over. These were intended for EDF applications but can be used in prop planes too. We have the following available:http://www.neumotors.com/store/page1/page1.html
1410/2Y(1850 Kv) motor features a 5mm shaft and is 36mm in diameter. It is perfect for the MidiFan on 6S which will draw about 63 amps and produce 71 oz of thrust. On 7S this fan will draw 81 amps and give 92 oz of thrust. With prop a 7x7 on a 3S battery will draw 45 amps and of 3S a 8x5 prop will draw 52 amps.
MR-028-056-2300(2600Kv) It has 16x19mm M2.5 mounting holes on the front. It is the perfect match of the Minifan 480 . On 6S it will draw 50 amps and produce 60oz of thrust. For speed planes use a 3 to 5S battery. With 3S a 6x5.5 prop will draw 50 amps and on 5S a 5x5 prop will pull 63 amps. At $79 it is a great value!The motor is 28mm in diameter and is 56mm in length. Shaft size is 5mm
MR-028-056-1800(1925kv) It has 16x19mm M2.5 mounting holes on the front. It is the perfect match of the Minifan 480 . On 8S it will draw40 amps and produce 60oz of thrust. For speed planes use a 3 to 5S battery. With 3S a 7x6 prop will draw 42 amps and on 5S a 5.5x5.5 prop will pull 45 amps. At $79 it is a great value! The motor is 28mm in diameter and is 56mm in length. Shaft size is 5mm
Steve
sneu is offline Find More Posts by sneu
Sold Motor Package Deal BriGuy82 Aircraft - Electric - Power Systems (FS/W) 0 Sep 27, 2012 02:04 PM
Alert Anyone need a GREAT deal on 4s motors? scorpion1 Racing Boats - Electric 1 Sep 15, 2012 06:08 PM
Sold Brushless motor package deal jbest Aircraft - Electric - Power Systems (FS/W) 2 Sep 12, 2012 05:23 PM
Discussion Twin Motors Do I really want to deal with this. azflyingguy Power Systems 13 Aug 02, 2012 06:17 PM
For Sale Multiple Items. Wemo Fans/Arc Motors/ Etc Package Deal Pepperpete Aircraft - Electric - Jets (FS/W) 1 Jul 10, 2012 07:22 PM
