Old Nov 26, 2012, 09:08 PM
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, BC, Summerland
Joined Nov 2012
Originally Posted by Brush Hog View Post
2 minutes of max throttle on the ground with no air flowing over your components isn't a terribly good idea...
Originally Posted by everydayflyer View Post
Depends on the setup.
Some power system setups can be smoked if ran 15 seconds WOT static.as they are designed to be ran WOT in flight for not more than 3 seconds at a time. Some others are only ran for less than 10 seconds WOT , one run per charge. On the other had some can be ran WOT the whole 30 min. flight or static without warming up much above ambient temperature.
Charles
You guys are right, i didn't stop to think about this before posting my 'do it yourself and hope your rig doesn't catch on fire' advice.
I always have larger than necessary ESCs so got a little too comfortable with sloppy practices i suppose.
CrashAffinity is offline Find More Posts by CrashAffinity
Latest blog entry: DJI F550 build w/naza
Old Nov 26, 2012, 09:53 PM
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
same chemistry diffrent manufacture/dealer
lectroglide is offline Find More Posts by lectroglide
Old Nov 27, 2012, 03:01 PM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Originally Posted by boingk View Post
Casual flyer? No, not worth it.
I fly Turnigy packs alsmost exclusively, with some Rhino and Flightmax packs in there for 'variety' - pretty sure they're the same in reality.
I've had zero problems, except with a few Turnigy and Rhino packs that I flew to the absolute limit of their power output, regularly. These three or four packs are now exhibiting bad cells and have been taken apart and disposed of after a saltwater discharge.
If you're a competition flyer or want sustained high-amp draw then I think spending a bit more is justified.
Cheers - boingk
You dont have to be a comp flyer to appreciate quality, the pro fliers arent the only ones that is flying a lot, the extra € spend for an honest rated good quality and long lasting batterie makes it worth it. If i buy a batterie i want to know what i am buying, capacity and discharge performance, i havent found any HK liPo battery that dont have a false rating. If you test and messure the performance of there packs and also open it up to see how bad they are made, then one understands how/ why they are so cheap.
Jocke is offline Find More Posts by Jocke
Old Nov 27, 2012, 06:17 PM
boingk's Avatar
NSW, Australia
Joined Feb 2011
Fair enough, but notice I also said people who want a sustained high discharge pack - not just competition flyers.
For me I have found the Turnigy NanoTech range to be good in this regard, and they do NOT cost a fortune. All my other models get Zippy/Flightmax/Compact lipos from HK without problems.
Personally I tend to use packs way below their rated max output, and totally ignore any claims on 'burst' outputs or similar 'temporary max discharge' rating. At the end of the day I'd rather use a slightly larger pack where I can, then a small one with a high 'C' rating.
The fact that I have my original generation of lithium polymer batteries still going strong after almost 2 years of use should back up my claim that almost any pack that is looked after should last the distance.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Nov 27, 2012, 06:39 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
How about close to 4 years and well over 300 flights?
Note TP PP45
http://www.rcgroups.com/forums/showp...15&postcount=1
Old Nov 28, 2012, 09:03 AM
Live from Mount Grassfield
Joined Feb 2011
Keywords there. Almost any pack will last if well cared for. For some reason it seems like the tiny ones don't. I have 4 of these Turnigy 1600mAh 1S:
http://www.hobbyking.com/hobbyking/s...mpatible_.html
They worked fine last winter, never been ran to LVC, always kept at storage charge. When they were not in use they were in the foam lined case with the micro heli's in a closet in the basement so temp was cool and pretty consistent. They sat for I would guess 7 months unused in that state. Now that we have snow on the ground I pulled them out last weekend and charged all 4 up. Only 1 out of the 4 was good, the other 3 hit LVC right after takeoff. These all worked perfectly last winter and now after 7 months of storage all but 1 are trash.
grimbeaver is offline Find More Posts by grimbeaver
Old Nov 28, 2012, 11:38 AM
Williamsburg, Va, USA
Joined Jul 2001
It all depends on your definition of "worth it"
I can say that I have had much longer life out of Thunder Power batteries. My first batteries were Thunder Power and I have one with a cell date (TP used to print cell dates on the pack) of 2005. It probably has 150 flight and is nearing the end of life with only about 75% of original capacity and still is not swelling.
I do buy cheaper packs for combat and experimental planes were they may be damaged. If have been impressed with the Hobby People batteries for the price. They have good output when new but after two years they still have about 85% capacity but they are starting to get soft.
The other cheap battery that I am impressed with is the Zippy Flightmax. It seems good so far but I only have it about a year.
jb753 is offline Find More Posts by jb753
Old Nov 28, 2012, 01:52 PM
Rugby, UK
Joined Feb 2007
Grimbeaver,
Are you sure that this is not just a function of lower temperatures?
Lots if flyers find that they take off in winter and the ESC hits LV after a few seconds. On the second attempt the flight is apparently successful, but that is only because the high IR has heated the pack on the first flight and reduced the IR.
I believe that this excess heating of the lipo causes damage which damages the cell and leads to "winter failure syndrome"
Could it be this is what you are seeing?
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Nov 28, 2012, 02:04 PM
Southern Pride
Which is why when it is 50F my LiPolys get warmed at home to 85 to 90F and they stay in my 12volt warmer until ready to be flown. If it is below 50F I stay inside as the cold hurts more each trip around the Sun.
Charles
Old Nov 28, 2012, 02:34 PM
Creator of the 1st 6S HT-Flip!
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Hey guys I'm wondering if either my thunderpower g6 prolite 3s 3300mah batteries are going bad or if my dragon OSD current sensor is way off. Everytime I fly my zephyr with 2 of the batteries listed above. I use 5500 of the available 6600 mah's and when I put my batteries back on the charger it only puts around 2400 mah back in each pack. I balance charge every single time and I always put batteries back on storage charge after a flight I never leave charged over night. And one of my batteries for some reason will not balance charge fast anymore. It takes over an hr n half and still isn't done. But the other is done in 20 minutes. I don't get what's going on but I've slowly been regretting paying $80 per battery. That's why I'm thinking about trying another cheaper brand like zippy or maybe gens ace. What do you guys think is going on with my batteries. My flight time has dropped by a 1/2 I'm only able to fly for about 15-17 minutes and when they were new I was flying for 20-30. Do you think it's my current sensor giving false readings?
flohio117 is offline Find More Posts by flohio117
Old Nov 28, 2012, 06:07 PM
Rugby, UK
Joined Feb 2007
The most likely cause is a dying cell in the pack which will not balance charge.
Does your charger read cell IR values and if so have you checked them?
Wayne
Old Nov 28, 2012, 07:41 PM
boingk's Avatar
NSW, Australia
Joined Feb 2011
tiny 160mAh lipos
Helicopters and small lipos are an interesting mix, personally I'd be trying the 300mAh units also available from HobbyKing. I have found that small lipos in helis fry particularly quickly as they tend to be right on the limit for safe, reliable current draw and also have no airflow.
If you are not warming them in your inside jacket pocket for at least 5 minutes before you fly in cold temps then, yes, you will most likely experience an early LVC due to the batteries chemical inability to provide current at the temperatures its being exposed to.
As an aside, I have a few of those 130 and 160mAh NanoTech lipos for my micro Parkzone models and have found them to be great. I've gotten a 16 minute powered flight from a HobbyZone Champ with a 130mAh NanoTech, and reliably get 10 minute flights. A 160mAh cell will generally give you longer than you will want to stay up. I particularly like the small NanoTech 1s packs and have found them to be brilliant performers.
Cheers - boingk
Old Nov 28, 2012, 08:42 PM
flohio117's Avatar
Joined Dec 2011
Wayne
I'm not sure if my charger reads iR values what is ir like infra-red?
Old Nov 28, 2012, 08:57 PM
Joined Nov 2012
I believe he's referring to internal resistance value, if I am correct in my thinking.
Quick question, have you encountered this disparity between OSD stated usage and charger values on any other batteries? or are you stuck with just the batteries you got?
Old Nov 28, 2012, 09:31 PM
Joined Feb 2011
Grimbeaver,
Wayne
I didn't think the batteries were cold yet when I was using them. I was flying indoors but it was a cold indoors (golf dome). The batteries had not been in the cold that long so I didn't really think of that. Later in the night I warmed some of my mCPX batteries with my hands because I knew they were cold. Also someone handed me a battery out of their pile right after mine failed, and his had been exposed to the cold for just as long as my batteries and his worked fine.
So I just went and retried the batteries. One of them hit LVC in about half the time it should have, the other though it made it a full flight but didn't have anywhere near the punch of my new ThunderPower cells. Either way I think I'll keep using the ThunderPower for my micro helicopters and the old cells might get downgraded to the less demanding micro t-28.
Discussion Are Blade Heli's really worth the extra cost? slothy89 Electric Heli Talk 23 Jun 15, 2012 12:41 PM
Data Which discount batteries are worth the money? fosjef67 Batteries and Chargers 11 Mar 18, 2012 02:34 PM
Question Flight simulators are they worth the cost? hyed Beginner Training Area (Aircraft-Electric) 40 Sep 21, 2010 07:01 PM
Discussion Flight simulators are they worth the cost? hyed Electric Plane Talk 41 Sep 12, 2010 09:02 PM
Are AXIs worth the cost? lsnover Power Systems 17 Jun 26, 2005 10:44 AM
