Old Nov 22, 2012, 01:31 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Originally Posted by ruzam View Post
The fact that you have returned batteries that didn't perform as expected is only adds to the evidence that expensive lipos are not necessarily better lipos.
And there's the rub. ALL of the batteries that I had to send back were indeed 'less than premium' packs. I have never had to return what I consider to be a premium lipoly.
There are good batteries, and there are better batteries, and the cost has to be balanced against the battery's total 'useful' life.
Absolutely agree.
My experience has shown that my premium packs are cheaper on a cost-per-flight basis. Here's the ongoing saga of my 2100-2200 size 3S lipolys: http://www.rcgroups.com/forums/showthread.php?t=1450517.
Note that the Hyperion packs are over 3 years old and show very little signs of degradation. The others have either been retired at less than 100 discharges or are certainly starting to fade. All used in the same application, same flight characteristics, same flight time, same charge rate, etc., so it's a very fair comparison.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 22, 2012, 01:34 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I normally get cheap packs for cheap planes and nice packs for nice planes. Why? Because I don't know if I will still have the cheap plane by the time the cheap packs start to die, but the nice planes certainly have a longer lifespan, so I get good batteries to go with it. My radian and foamies are powered by GensAce and SkyLipo... the foamies start to break down after a year or two, and the Radian is soon going to be sold for a better glider. I'm putting TP's in the better glider.
acetech09 is offline Find More Posts by acetech09
Old Nov 22, 2012, 06:00 PM
MarkF is offline
Find More Posts by MarkF
Battery Puffer
United States, NV, Las Vegas
Joined Nov 2001
Rebel, I merley posted that quote to show I was buying my cells from the factory not the assembly plant. I don't know what else your talking about.
Mark
MarkF is offline Find More Posts by MarkF
Old Nov 22, 2012, 06:11 PM
IIIHorseman is offline
Find More Posts by IIIHorseman
United States, OR, Beaverton
Joined Jul 2012
I like Turnigy, the are fairly priced and can be charged higher than 1C
IIIHorseman is offline Find More Posts by IIIHorseman
Old Nov 22, 2012, 09:01 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Originally Posted by MarkF View Post
I am done with this thread and the graphs I posted speak for themselfs.
Mark
The graphs you posted are meaningless. Your posts do not document the test procedure, how/when the tests were performed and under what conditions the tests were performed, age and number of cycles being tested, etc. Your posts/graphs do not indicate IR. Additionally, the tests do not indicate long term performance as they only represent a few discharges. I assumed those graphs were posted by someone trying to market their own products and I assumed correctly. It would have been appreciated if you would have provided such a disclaimer up front.
Ohmic is offline Find More Posts by Ohmic
Old Nov 22, 2012, 09:47 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Thanks! That was/is an informative read, without all the 'mine are better' pee fights.
ruzam is offline Find More Posts by ruzam
Old Nov 23, 2012, 09:55 AM
MarkF is offline
Battery Puffer
Joined Nov 2001
Ohmic, I'm sorry I don't have the info you want. That graph was sent to me buy a customer and I did email him asking your questions. I do have some graphs another customer sent me showing IR numbers. I don't own any testing equipment so have to rely on customers and people like Mark Forsyth and Charles. I do get the feeling it doesn't matter what I post because someone will try to find a way to attack it. I believe you will find your answers in the test Mark F did. I apologize to everyone else for the mess I seemed to have made of this thread.
Mark
Old Nov 23, 2012, 10:28 AM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
Ohmic, I'm sorry I don't have the info you want. I don't own any testing equipment
If you're "in the business" spending the relatively small amount for IR testing equipment would seem a good investment. Even if it was just used for your own "race" batteries. But then you couldn't feign ignorance?
t.edwards is offline Find More Posts by t.edwards
Old Nov 23, 2012, 10:30 AM
GREG A is offline
Find More Posts by GREG A
Joined Nov 2012
Short lipo life cycle
I seem to get about a dozen cycles out of my lipo packs, be it a 160mah 1s or my 3300 mah 3s 25c gens ace. Hot weather seems to take its toll with puffing. I try not to over discharge but they get real warm in 85+ degree weather. I've never seen any instructions with the batteries concerning care and feeding of them. Have a triton2 eq balancing charger and charge per the chargers instructions. Really dissatisfied with high cost and short lifespan of batteries. Flying glow is about 3 times less expensive. Am i doing something wrong or do i have crummy equipment? Tried to buy good stuff.
GREG A is offline Find More Posts by GREG A
Old Nov 23, 2012, 11:08 AM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Thems fighten words.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Nov 23, 2012, 11:42 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Greg
I think you are running the batteries down too low while flying. Or You may have a defective battery charger.
Did you reset ALL of your ESCs to the HIGHEST cutoff voltage ? Hopefully there is a 3.1 volts or higher setting.
cyclops2 is offline Find More Posts by cyclops2
Old Nov 23, 2012, 12:12 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps this will help.
http://www.rcgroups.com/forums/showp...61&postcount=1
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Nov 23, 2012, 01:29 PM
cyclops2 is offline
Joined Mar 2003
getting REAL WARM & puffy do go together. Do you know how much current each plane is pulling out of the battery at maximum power ?
Can you safely measure that for us ? It would be a BIG HELP in seeing why your batteries die so fast.
Old Nov 23, 2012, 01:40 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by GREG A View Post
I seem to get about a dozen cycles out of my lipo packs, be it a 160mah 1s or my 3300 mah 3s 25c gens ace. Hot weather seems to take its toll with puffing. ....
The link in everydayflyer's post is well worth reading
Unfortunately there are several things you could be doing wrong: Over-discharging is one thing, and over-amping is another. Taking your Gens Ace as an example, it should theoretically be capable of handling 3.3 x 25 = 82.5A, but in hot weather it's probably prudent to de-rate that value, and you should also assume that the manufacturer has exaggerated the C rating (or at the very best, measured it under ideal conditions), so everdayflyer's de-rating to 60%sounds prudent. Do you know how many amps your setup is actually drawing?
abenn is offline Find More Posts by abenn
Old Nov 23, 2012, 09:00 PM
GREG A is offline
Joined Nov 2012
Flying a great planes electro stik with rimfire 42-40-100kv and gp ss45a brushless esc. I fly 10 min at half throttle for the most part. Like to get up high and try to catch thermals while shooting video with a very lite cam. I throttle down while gliding. I don't know exactly how much i'm drawing. Just notice that the motor starts surging after 3 or 4 minutes with the gens ace 3300 25c 11.1v. The battery then will only take about 900mah charge to get to 12.6v charge. Then goes down quickly to around 12.3-12.2v. Can't get these batteries to take a good charge after about 10 cycles.
Discussion Are Blade Heli's really worth the extra cost? slothy89 Electric Heli Talk 23 Jun 15, 2012 12:41 PM
Data Which discount batteries are worth the money? fosjef67 Batteries and Chargers 11 Mar 18, 2012 02:34 PM
Question Flight simulators are they worth the cost? hyed Beginner Training Area (Aircraft-Electric) 40 Sep 21, 2010 07:01 PM
Discussion Flight simulators are they worth the cost? hyed Electric Plane Talk 41 Sep 12, 2010 09:02 PM
Are AXIs worth the cost? lsnover Power Systems 17 Jun 26, 2005 10:44 AM
