Old Jan 16, 2013, 11:46 AM
SBOTI74 is offline
Find More Posts by SBOTI74
I fly em', there for I am.
SBOTI74's Avatar
United States, CA, Tehachapi
Joined Feb 2009
gotta figure out the settings for the Pro 2.0 board. I'm going to read through the link you sent and I think that may help me tones! That and about 4 more spare arms just incase.
SBOTI74 is offline Find More Posts by SBOTI74
Old Jan 16, 2013, 11:48 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by subaru4wd View Post
The chances of this actually happening are extremely rare.
In my eyes, rotating props are a safety concern.
I always let my props spin at idle - for safety reasons.
That way I know if the FC is armed or not.
Ever accidently kicked the throttle when it was armed? Me too...
kinderkram is offline Find More Posts by kinderkram
Old Jan 16, 2013, 12:21 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Nope... Ever since day one I have made it a habit to approach my quad with the throttle stick in the lower/left (disarmed) position. And on every successful landing before I even move, I disarm the board & then test wether or not it is disarmed by increasing throttle to make sure the props are not going to come back to life.
AcroFPV is offline Find More Posts by AcroFPV
Old Jan 16, 2013, 12:30 PM
SBOTI74 is offline
SBOTI74's Avatar
Joined Feb 2009
Good suggestions all the way around. I recently found out how dangerous these props are on these quads. Black ones you can hardly see when powered.... Anyway, my lovely 4 legged family member (12yr old Jack-Russel Terrier named Harlie) slipped past the doggy door and as I was about 2" off the deck, she went to grab the 4 armed flying bird thing. Well, we now call her Scar-Face. Not as bad as it could have been but none the less, I'm liking the suggestions. Even though it wouldn't have helped me with Harlie, it's something to think about.
Cheers.
Old Jan 16, 2013, 12:34 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
subaru: I don't need that "approach" - I know when it's armed or not.
When I connected the whitespy Flip first (with motor_stop) I thought "heck, why don't you arm"?
My first 2 copters (GAUI 330x and AC1) had the motors stop and in the beginning I accidentally kicked the throttle too often. I simply hated not knowing if it's armed or not.
But as already said: it's more of personal taste and what you're used to...
Old Jan 17, 2013, 01:35 AM
TimeTrave1er is offline
Find More Posts by TimeTrave1er
United States, CT
Joined Oct 2012
read through this: http://www.multiwii.com/wiki/index.php?title=Config.h
All of your problems can be solved by editing config.h
I installed Arduino 1.03 and I have my board plugged in via USB and it is detected on COM5.
How do I open the config.h that is on my board in Arduino? I am very unfamilar with this software.
TimeTrave1er is offline Find More Posts by TimeTrave1er
Old Jan 17, 2013, 01:38 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
You do not "open the config.h on your board".
You store the MultiWii files on your computer, and you open the "MultiWii.ino" file using Arduino 1.03
Once that is done, you will see a TON of code. You will also see some tabs above that code. The tabs are seperate files, so look for a tab labeled "config.h"
Once you make your changes to the config.h file, you will want to save it and then upload the new code to your board.
Old Jan 17, 2013, 01:50 AM
United States, CT
Joined Oct 2012
Ah thanks. I thought you could read from the board and then make changes and write them.
So I store the multiwii files on my computer. But where do I get the multiwii files? Do I download them?
Thanks a lot
Old Jan 17, 2013, 01:53 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Thanks a lot
http://code.google.com/p/multiwii/downloads/list
Old Jan 17, 2013, 01:59 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Thanks a lot
The settings you change ON the board are PID values and flight mode programming, etc... This is all done through the Windows GUI. There are a couple available to chose from.
Config.h is for initial setup for the type of flight controller you are using, options like GPS and Sonar, Motor Layout etc...
A copy of MultiWii 2.1 that has been pre-configured to operate this flight controller in quad-X formation can be found here:
https://hotfile.com/dl/182006241/a57...0_gps.zip.html - GPS version
https://hotfile.com/dl/182006221/6f8...a2__0.zip.html - No GPS
Old Jan 17, 2013, 02:58 AM
United States, CT
Joined Oct 2012
I downloaded those files. And I connect to my board using the Win GUI but I still can't find where to lower the motor speed. I'm lost
Old Jan 17, 2013, 03:01 AM
United States, CT
Joined Oct 2012
I tried MultiWiiConf_2_1 and it is very similar to Win GUI, I can't figure how to change the motor speeds.
Old Jan 17, 2013, 09:12 AM
Breezemont is offline
Find More Posts by Breezemont
Joined Feb 2009
Motor speed is in the Arduino sketch:
MultiWii Tutorial (6 min 19 sec)
Breezemont is offline Find More Posts by Breezemont
Old Jan 17, 2013, 09:39 AM
Gordon2 is offline
Find More Posts by Gordon2
Joined Nov 2012
https://hotfile.com/dl/182006241/a57...0_gps.zip.html - GPS version.
This download has a config.h that has FREEIMUv04 as the board which is un-commented and used.
I was under the impressionism that TimeTraveler was using a MultiWii AIO PRO v2.
Is that the correct board selection for a MultiWii All in One Pro V2? Even if its a Hobby King Clone?
Gordon2 is offline Find More Posts by Gordon2
Old Jan 17, 2013, 12:44 PM
pdc3ven is offline
Find More Posts by pdc3ven
Joined Apr 2008
just bought the multiwii pro 2.0 board with the witespy ublox neo 6m gps module, the one with the blue mounting backplane
http://witespyquad.gostorego.com/fli...backplane.html
i only have two questions, which way is 'forward' for the gps? i have it so that the writing on top of the ceramic antenna is right side up when the nose of the quad is at 12 o'clock
anddd...when it acheives a gps 3D lock, what color will this gps led turn? it has only been red, and red with a once per second yellow flash (searching for satellites?) but it has found up to 9 satellites in the gui.... how many satellites are usually required for a 3d fix?
ok that was 3 question
pdc3ven is offline Find More Posts by pdc3ven
Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module benybee UAV - Unmanned Aerial Vehicles 418 Nov 20, 2015 07:32 PM
Discussion MegaPirate NG on HK MultiWii PRO Flight Controller w/MTK GPS Module jabram Multirotor Electronics 2099 Mar 24, 2014 05:22 PM
Discussion need GPS recommendation for use with multiwii FC doughboy Multirotor Talk 4 Apr 18, 2013 01:15 AM
Sold Warthox FPV v2.0 multiwii FC $40 shipped! kicekilla Aircraft - Electric - Multirotor (FS/W) 3 Sep 10, 2012 02:37 PM
Sold MK, Navi,Mag and GPS and clone 2.0 FC G-unit Aircraft - Electric - Multirotor (FS/W) 4 Mar 30, 2012 01:41 AM
