Old Nov 15, 2012, 06:00 AM
Palju is offline
Find More Posts by Palju
Palju's Avatar
Finland
Joined Aug 2012
Help!
Hitec Optic 6 Sport 2.4GHz PPM???
I have Optic 6 Sport 2.4GHz radio (http://www.hitecrcd.com/products/air...rt-2-4ghz.html) and now I have a small problem with it.
I'm trying to change the Hitec Spectra TX to FRsky DHT DIY, but I'm not able to get it working as it should. I can bind FRsky TX and RX, but when I connect servos on RX and turn it on, servos are moving all the time. Now I have doubt that my Hitec radio signal to Spectra TX is not PPM. Is it??? If it's not, is there a soldering point inside radio, where I can find PPM??
I'm trying to do this FRsky mod to Hitec, which is my son's radio. And the reason because I want my hole fleet to be flown both radio's without having to change RX's on them. I fly myself with Graupner MX-22 with FRsky DJT module.
For the record, I tested the same FRsky DHT TX in my Graupner MX-22 and everything worked like a charm
So any help for me...
Palju is offline Find More Posts by Palju
Old Nov 15, 2012, 01:40 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Hitec Optic 6 - Aftermarket 2.4Ghz Conversions
I'm trying to do this FRsky mod to Hitec, which is my son's radio. And the reason because I want my hole fleet to be flown both radio's without having to change RX's on them. I fly myself with Graupner MX-22 with FRsky DJT module.For the record, I tested the same FRsky DHT TX in my Graupner MX-22 and everything worked like a charm:
A very quick search provides:
. Optic 6 Sport - FrSky Conversion - video.
. Optic 6 Sport - FrSky V8HT - DIY pictorial guide.
. Optic 6 Sport (35<72Mhz) - FrSky module - DIY Conversion.
. Optic 6 Sport - Assan 2.4Ghz Conversion - DIY Pictorial.
More information on Optic 6 Sport available under sub section:
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Nov 16, 2012, 01:34 AM
Palju is offline
Palju's Avatar
Finland
Joined Aug 2012
Alan T.
These are great instruction if you have Optic 6 Sport FM radio. My son's radio is Optic 6 Sport 2.4GHz with Spectra AFHSS TX inside (Hitec's own 2.4GHz). This is not the same as FM versions of Optic Sport.
There are five points in the circuit board, which are CHG, RF+, G, B+ and S. I made the connection to points RF+ to FRsky +, G to FRsky - and S to FRsky Signal. With this connection servos are moving all the time, after I connect RX to the battery with TX on. I was eliminating possible FRsky TX or RX fault by connecting it to my own Graupner MX-22, and everything worked like charm. So I think that Optic 6 Sport 2.4GHz AFHSS is not using PPM from radio to TX????
The main reason I want to change Hitec's 2.4 GHz Spectra AFHSS to FRsky is that we fly sometimes same models with my son. Now we have to change RX inside the plane, because I'm flying with Graupner MX-22 and FRsky 2.4GHz. If we had both radio's with FRsky, then only to BNF (bind and fly) is all what's needed.
Old Mar 05, 2014, 10:29 PM
CarlosClav is offline
Find More Posts by CarlosClav
Australia, VIC, Ormond
Joined Jul 2009
Hi Palju,
I'm interested in doing the same modification to my 2.4Ghz Optic 6.
Could you solve the problem that you've posted?
CarlosClav is offline Find More Posts by CarlosClav
Help! Optic 6 Sport 2.4 ppm??? Palju Hitec/Multiplex USA 1 Nov 15, 2012 01:16 PM
Discussion Decision, hitec Optic 6, Optic 6 sport, dx6i OR?? MikeontheBike Radios 38 Sep 21, 2012 10:42 PM
Discussion Hitec Optic 6 Sport 2.4ghz issue relorre Hitec/Multiplex USA 5 Sep 10, 2012 07:01 PM
Sold Hitec Optic 6 Sport 2.4ghz TX DuaneV Aircraft - General - Radio Equipment (FS/W) 2 Jul 23, 2012 08:58 PM
Discussion buddy lead with 2 hitec optic sport 2.4ghz radio help RyThEm Beginner Training Area (Aircraft-Electric) 6 Apr 30, 2012 06:05 AM
