Old Nov 15, 2012, 05:50 AM
derpron is offline
Find More Posts by derpron
darn you, kakka carrot cake.
derpron's Avatar
Australia, WA, Perth
Joined Aug 2012
turnigy 2wd 1/10 desert buggy/SCT overheat
a certain 35 amp ESC of mine (turnigy 2wd 1/10 sct) cuts out after 2 minutes, i think its the temperature overload safety thingy but it must be faulty because these things are meant to be run for 30 minutes, not 2. its really annoying. anyone know what the problem is or how to fix it? also the motor gets really hot, i dunno if that makes the ESC cut out.
or mabey how to cool them?
the 2wd sct is the same as the desert buggy, just so you know.
update, i took off the wheels and ran the motor full throttle and the motor still gets very hot. so its a motor problem not an esc problem.
derpron is offline Find More Posts by derpron
Old Nov 15, 2012, 07:04 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What gearing? What battery pack? What conditions (flat pavement, sand, long grass, etc)?
wparsons is offline Find More Posts by wparsons
Old Nov 15, 2012, 07:44 AM
yamar6 is offline
Find More Posts by yamar6
Joined Aug 2005
make shure the pinon is not to tight on the spure even the wheel nuts.it could also be a bad motor.
yamar6 is offline Find More Posts by yamar6
Old Nov 15, 2012, 06:27 PM
derpron is offline
derpron's Avatar
Joined Aug 2012
box stock gearing
2s lipo, minimum
road
Old Nov 15, 2012, 07:49 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Check for binding anywhere in the driveline, especially the gear mesh on the pinion/spur. It should barely be getting warm on 2s with the stock gearing.
Discussion Turnigy 1/10 Brushless 2WD Desert Racing Buggy kenstogie Off-road Cars 137 Apr 28, 2016 09:53 PM
Mini-Review Turnigy Stadium King 2wd 1/10 RTR Truggy vini_itu Off-road Cars 21 Dec 29, 2012 06:09 PM
Discussion Help with a Turnigy 1/10 2WD Dessert Buggy Joe26 Electric Power Cars 7 Jul 23, 2012 10:01 AM
Sold 1/5 Baja 5B Desert Buggy (29CC) 2 Stroke 2WD Baja, Gas Powered rcexpress123 Cars - Cars and Parts (FS/W) 10 Sep 19, 2011 01:41 PM
